SoundSpot Ravage v1.0.2 x32 | x64 WiN MAC Ê§ÕæÐ§¹ûÆ÷
ͨ¹ýÔö¼ÓÊÙÃüºÍÔ˶¯»ñµÃ¼ÓÈȹýÔØ ¨C ´ÓÁùÖÖÊ§ÕæÀàÐÍÖнøÐÐÑ¡Ôñ£¬Í¨¹ý¹ýÂ˺ÍÔöÒæËÜÔìÄúµÄÐźţ¬²¢Ê¹ÓÃ×Ô¶¨Ò廿֯µÄ LFO ÐÎ×´µ÷ÖÆ½á¹û¡£¾ø¶Ôϲ»¶Õâ¸ö²å¼þ¡£6 ÖÖÊ§ÕæµÄÖÊÁ¿·Ç³£ºÃ£¬ÔÚÕâÖÖЧ¹ûÉÏÓµÓе÷ÖÆ¾ØÕóµÄÁ¦Á¿·Ç³£ÓÐÓá£ÎÒ·¢ÏÖ Ravage ÔÚÖÖÀà·±¶àµÄÉùÒôÖзdz£ÓÐÓã¬ÕâÎÞÒÉÊÇÎÒÑ¡ÔñµÄÐÂÊ§Õæ¡£Soundspot µÄÁíÒ»¸öΰ´óµÄ¹¤¾ß¡£¨C Andy Moor ¨C ¸ñÀ³ÃÀÌáÃûÖÆ×÷ÈËºÍ DJ¡£
ÌØµã
*ʹÓà 6 ÖÖÊ§ÕæÀàÐͼÓÈÈ£ºÊý×Ö¡¢µç×ӹܡ¢¶þ¼«¹Ü¡¢ÏßÐÔÕÛµþ¡¢ÁãÆ½·½ºÍУÕý
*ʹÓÃ×Ô¶¨Ò廿֯µÄµ÷ÖÆÐÎ״Ϊ²ÎÊýÌí¼ÓÔ˶¯
*Destroy ²ÎÊýͨ¹ýÊ§Õæ´¦ÀíÆ÷ʹÐźŸüÃÍÁÒ
*ÔÚÁ¢ÌåÉù³¡ÖÐÆ½ÒÆÊ§Õæ
*ͨ¹ýÂ˲¨¡¢ÊäÈë/Êä³öÔöÒæºÍ°µ/ÁÁ¼ÓȨµ÷ÕûÊ§ÕæÏìÓ¦
*·´Ïò¡¢Æ½»¬ºÍµ÷Õûµ÷ÖÆÆ÷ÐźŵÄÂö³å¿í¶È
*×Ô¶¯Êä³ö¿ØÖÆÔÚÔö¼ÓÇý¶¯Ê±²¹³¥µçƽ
*Ä»ºóÖÇÄÜÉèÖùý²ÉÑùÒÔÈ·±£×î¼ÑÒôÖÊ
¡°¶àô°ôµÄÒ»Ì×¹¤¾ß¡£ÎÒ»¨Á˺ܳ¤Ê±¼äÀ´»ñµÃÕýÈ·µÄÊ§Õæ£¬ÓÈÆäÊÇÔÚÎÒµÄÖеÍÒô×éͨµÀÉÏ£¬Õâ¾ø¶Ô±ÈÎÒʹÓõļ¸ºõËùÓÐÆäËûÊ§Õæ²å¼þ¶¼ÓÐÓÅÊÆ¡£¼ÓÉÏÎÞÏÞµÄ LFO ͨµÀ¡­¡­Ì«·è¿ñÁË£¡ºÜ°ôµÄ¹¤×÷ÈËÔ±£¬ÏÖÔÚÎÒ¿ÉÒÔÔÚ¹¤×÷ÊÒÖÐʹÓÃÊ§Õæ²å¼þ£¬²¢Çҿ϶¨»á³ÖÐøºÜ³¤Ê±¼ä¡£¡± ¨C STANDERWICK ¨C Armada Music¡¢Roland
´ÓÁùÖÖ½¨Ä£Ê§ÕæËã·¨ÖнøÐÐÑ¡Ôñ£ºµç×ӹܡ¢Êý×Ö¡¢¶þ¼«¹Ü¡¢ÏßÐÔÕÛµþ¡¢ÁãÆ½·½ºÍÕûÁ÷£¬Ã¿ÖÖËã·¨¶¼Óв»Í¬µÄ¸öÐÔ£¬¿ÉÒÔΪÒôƵÌí¼ÓɳÀùºÍÎÛ¹¸¡£Ê¹Óà Drive ¿ØÖƸüÓÃÁ¦µØÍƶ¯Ðźţ¬²¢Ê¹Óà Destroy ²ÎÊýÍêÈ«·ÛËéÈκÎÒôƵ¡£°åÔØ¸ßͨºÍµÍͨÂ˲¨Æ÷£¬ÒÔ¼°ÓÃÓÚ¼ÓÈ¨Ê§ÕæÄÜÁ¿µÄ°µ/ÁÁ»¬¿é¡£
Get Heated Overdrive With Added Life And Movement ¨C Choose From Six Types Of Distortion, Shape Your Signal With Filtering And Gain, And Modulate The Results With Custom-Drawn LFO Shapes. Absolutely loving this plugin. The quality of the 6 distortions are superb, and having the power of a modulation matrix on this kind of effect is incredibly useful. I¡¯ve found the Ravage to be so useful across such a wide variety sounds that this is without doubt my new distortion of choice. Yet another great tool from the guys at Soundspot. ¨C Andy Moor ¨C Grammy Nominated Producer and DJ.
Features
* Heat things up with 6 distortion types: Digital, Tube, Diode, Lin Fold, Zero Sq and Rectify
* Add movement to parameters using custom-drawn modulation shapes
* Destroy parameter pushes the signal even harder through the distortion processor
* Pan the distortion across the stereo field
* Tailor the distortion response with filtering, input/output gain, and dark/bright weighting
* Reverse, Smooth and adjust Pulse Width for modulator signals
* Auto output control compensates level when Drive is increased
* Oversampling is set intelligently behind the scenes to ensure the best sound quality
¡°What a great piece of kit. I spend a long time getting distortion right especially on my mid bass group channels and this definitely has the edge on just about every other distortion plugin that I use. Plus unlimited LFO lanes¡­ thats insane! Great work guys, its now my reach to distortion plugin in the studio and will be for some considerable time for sure.¡± ¨C STANDERWICK ¨C Armada Music, Roland
Select from six modelled distortion algorithms: Tube, Digital, Diode, Linear Fold, Zero Sq and Rectify, each with a different personality for adding grit and dirt to audio. Use the Drive control to push the signal harder, and use the Destroy parameter to fully smash up any audio. There are high- and low-pass filters onboard, as well as a Dark/Bright slider to weight the distortion¡¯s energy.
REQ :[iNTEL] + [M1] Mac: OS 10.12 Sierra +
Plugin Formats: AU | VST | VST3 | AAX
PC: Windows 7, 8, 10
Plugin Formats: | VST | VST3 | AAX x32 | x64
https://plugincrack.com/plugins/soundspot-ravage-osx/
