) f& {1 Q& Q2 D8 f+ U# wApple Logic Pro X v10.6.3 macOSX
* X1 {9 }4 `8 s" \
7 D8 l! e7 Q- ]. V( B8 g4 uLogic Pro X ÊÇÓÐÊ·ÒÔÀ´×îÏȽøµÄ Logic °æ±¾¡£ÓÃÓÚרҵ¸èÇú´´×÷¡¢±à¼ºÍ»ìÒôµÄ¸´ÔÓ¹¤¾ßÎ§ÈÆÏÖ´ú½çÃæ¹¹½¨£¬Ö¼ÔÚ¿ìËÙ»ñµÃ´´Òâ½á¹û²¢ÔÚÐèҪʱÌṩ¸ü¶à¹¦ÄÜ¡£
" f; S: [) ^* U/ B8 x9 m' d9 C9 c! a% ~: p, S0 {
Ç¿´óµÄ½çÃæ" Y3 N3 J! n. W7 k/ ~+ S, O( K
• ʹÓà Track Stack ºÏ²¢ºÍ¿ØÖƶà¸ö¹ìµÀ»ò´´½¨·á¸»¡¢·Ö²ãµÄÀÖÆ÷9 p$ N5 o8 @. x
• ÖÇÄܿؼþÈÃÄúÖ»ÐèÒ»´ÎÒÆ¶¯¼´¿É²Ù×ݶà¸ö²å¼þºÍ²ÎÊý; K' i9 P/ q, c' |. E6 \9 s* r( o! ?
• Ö§³Ö MacBook Pro ÉϵĴ¥¿ØÀ¸£¬Îª´´½¨¡¢±à¼Ìṩ·½±ãµÄ¿Ø¼þºÍµ¼º½ÄúµÄ¸èÇú
5 s" t/ W ~' N0 @• ×Ô¶¯±£´æÈÃÄúµÄ¹¤×÷°²È«ÎÞÓÝ# k7 ~" d3 q% o0 e
8 `- D( c. p+ r# JרҵµÄÒôÀÖÖÆ×÷- S) j& T$ z1 {0 Y: _
• ʹÓÃÒ»Ì×È«ÃæµÄ±à¼Æ÷ºÍ¹¤¾ßÂ¼ÖÆºÍ±à¼ MIDI »òÒôƵ& e4 Q, V1 J/ Z9 _; s3 X
• ʹÓûãÕûÎļþ¼Ð×éÖ¯»ãÕû£¬²¢Ê¹ÓÿìËÙ»¬¶¯°é×à¿ìËÙ¹¹½¨°é×à5 _ _, T" j, g
• ±¸Ñ¡¹ìµÀÈÃÄú¿ÉÒÔÔÚ²»Í¬µÄƬ¶Î²¥·ÅÁбíºÍ¹ìµÀÉϵıà¼Ö®¼ä´´½¨ºÍÇл»
1 D8 h' v4 M0 B. J+ N• ʹÓÃÑ¡Ôñ½«Ð§¹û²å¼þµÄÈÎÒâ×éºÏäÖȾµ½ËùÑ¡ÒôƵ»ùÓÚ´¦Àí8 ?" w6 h& Y# V. P3 n
• ʹÓà Flex Pitch ÐÞ¸´×ßµ÷µÄÈËÉù²¢¸ü¸ÄÂ¼ÖÆÒôƵµÄÐýÂÉ* T; G/ s; u' d
• ʹÓà Flex Time ÇáËÉ¿ØÖÆÈκμÒôµÄʱ¼äºÍËÙ¶È8 {+ m/ O, D8 U9 ^9 t
• È«ÃæµÄ»ìÒôºÍ²å¼þ²ÎÊý×Ô¶¯»¯¿ÉÒÔ³ÉÎªÇøÓò»òÇúÄ¿9 Q/ O1 r y8 d, t+ x( W
• ÔÚ·¿¼äµÄÈκεط½Ê¹Óà iPad »ò iPhone É쵀 Logic Remote ´´½¨ºÍ»ìºÏÒôÀÖ2 A% N9 m9 V; U1 e
• ʹÓÃÄÚÖõÄÀÖÆ×±à¼Æ÷Drum ProductionÖÆ×÷¼òµ¥µÄÖ÷×àÀ֯׻ò¹ÜÏÒÀÖÀÖÆ×
W# U. ~6 F/ K2 |
8 `# p( @; n) S+ `0 D$ G• ʹÓà Drummer£¨ÐéÄâ»á»°²¥·ÅÆ÷ºÍ½ÚÅÄÖÆ×÷ÈË£©´´½¨ÕæÊµµÄÔÉù¡¢µç×Ó»òÎû¹þ¹ÄÒô¹ì! q' t0 r6 F& ]/ l& ^( S, R8 K
• ´Ó 28 λ²»Í¬µÄ¹ÄÊÖÖнøÐÐÑ¡Ôñ£¬ËûÃÇ¿ÉÒÔÖ¸µ¼ÄúµÄ·½Ïò²¢ÑÝ×àÊý°ÙÍòÖÖ¶ÀÌØµÄÂɶ¯
8 G/ q' w- m3 p% z2 F• ʹÓà Drum Kit Designer ¹¹½¨Äú×Ô¼ºµÄÔÉù¹Ä×éʹÓÃһϵÁÐÉî¶È²ÉÑùµÄ¹Ä
; ^6 L4 W o# R/ b• ʹÓà Drum Machine Designer9 l& x B4 U2 o0 p& M
4 y# S* _2 g; k3 n9 q% Y. [¼üÅ̺Í! e. X$ e8 {# X5 h. N, I+ U1 v _
ºÏ³ÉÆ÷×Ô¶¨Òåµç×Ó½ÚÅĵÄÉùÒô• ´ÓÌṩģÄâ¡¢²¨±í¡¢FM¡¢¼Ó·¨¡¢¿ÅÁ£¡¢ÆµÆ×ºÍ½¨Ä£ºÏ³ÉµÄºÏ³ÉÆ÷¼¯ºÏÖлñµÃÁé¸Ð
: B' `2 r/ e8 r p1 H1 Z• ¿ìËÙÕÒµ½ÉùÒô»òʹÓÃÖÕ¼«Ñù±¾´¦ÀíºÏ³ÉÆ÷ Alchemy ´´½¨¶ÀÌØµÄÐÂ
" o6 K! p* N; QÀÖÆ÷ • ʹÓà EXS24 ²ÉÑùÆ÷ÑÝ×à»ò´´½¨¸÷ÖַḻµÄ²ÉÑùÀÖÆ÷
0 X, F$ R% a2 s6 C* U• ʹÓÃÅÃÒôÆ÷Á¢¼´½«¼òµ¥µÄºÍÏÒת±äΪ·á¸»µÄÑÝ×à, j1 [2 D3 q. _) D. s. v5 h; N3 s
• ʹÓþŸö MIDI ²å¼þ½«¼òµ¥µÄÏ뷨ת»¯Îª¾«ÐÄÖÆ×÷µÄÑÝ×à
$ u2 a4 ~# i1 u6 X4 i1 V+ O" u• ÑÝ×ྵä·çÇÙ¡¢¼üÅ̺͸´¹ÅºÏ³ÉÆ÷µÄÖÒʵģÐÍ
" F, @+ O" x2 R2 ]3 y F
5 Z: i2 z( z$ T% C- h$ n¼ªËûºÍ±´Ë¾É豸1 \8 @! b( r/ T3 Y, o& |
• ¹¹½¨Äú×Ô¼ºµÄ¼ªËû»ò±´Ë¾Ê¹ÓÃÀÏʽºÍÏÖ´ú·Å´óÆ÷¡¢ÏäÌåºÍÂó¿Ë·çÓë Amp Designer ´îÅäʹÓÃ
( V# ~# t8 J, @3 U2 m3 |• ´ÓÑÓ³Ù¡¢Ê§ÕæºÍµ÷ÖÆÌ¤½ÅתÅ̵ļ¯ºÏÖÐÉè¼Æ×Ô¶¨Òå̤°å
& Q3 ], s4 H3 o" Q4 `• Ö»Ðèµ¥»÷¼´¿É·ÃÎʵ÷ÒôÆ÷ÒÔ¿ìËÙµ÷Õû
" d# F+ O3 M6 D) S' b8 f8 O$ p´´ÒâºÍÖÆ×÷Ч¹û4 H* j: v5 f* b- @
• ²¥·ÅÄúµÄʹÓà Space Designer ¾í»ý»ìÏìÔÚ±ÆÕæµÄÉùѧ¿Õ¼äÖз¢³öÉùÒô _# t2 E+ `- K* C Z. D; `9 o
• ʹÓÃһϵÁжà³éÍ·¡¢ÀÏʽ´Å´øºÍÁ¢ÌåÉùÑÓ³Ù
- m8 A* Z/ i( c6 @' j/ i• ʹÓø÷ÖÖµ÷ÖÆÐ§¹û- I4 T- a0 S- f; \) E" z5 X" j
7 x1 W: }/ d0 O9 S- s# G
ÒôÉ«¿âΪÄúµÄÇúÄ¿Ìí¼Ó¶¯¸Ð
) `0 Q; _& |5 i• ³¬¹ý 2800 ÖÖÀÖÆ÷ºÍЧ¹û Patch0 O2 H5 a) N( r1 g& A
• 1000 ÖÖ¾«ÐIJÉÑùµÄÀÖÆ÷& _4 r# Q- l8 W) F( y
• ³¬¹ý 7000 ¸ö Apple Loops£¬ÖÖÀà·±¶à
! U+ Y; L% a. J) B* {, s* a$ w2 D! o6 G# @; B% p
¼æÈÝÐÔ8 j, c" Q3 x- b( z+ m
• ʹÓõÚÈý·½ÒôƵÀ©Õ¹ÄúµÄÀÖÆ÷ºÍЧ¹û¿â¼æÈݵ¥Î»µÄ²å¼þ
( u# P: O- R. i% I0 i" y4 q& S6 \• ¹²Ïíµ½ GarageBand Ñ¡ÏîÔÊÐíÄúͨ¹ý iCloud ´Ó iPhone »ò iPad Ô¶³Ì½«ÐÂÇúÄ¿Ìí¼Óµ½ÄúµÄ Logic ÏîÄ¿: W6 l: }2 E. [+ v8 M5 U
• µ¼ÈëºÍµ¼³ö XML ÒÔÖ§³Ö Final Cut Pro X ¹¤×÷Á÷³Ì U+ K2 F9 K( M" _4 \# \
• ½«ÄúµÄ¸èÇúÖ±½Óµ¼³öºÍ¹²Ïíµ½ SoundCloud
* x; X3 _, z# J• ´Ó Logic 5 »ò¸ü¸ß°æ±¾´ò¿ªÏîÄ¿! t' r( R9 y6 }0 z" \
' m- \2 H2 O' z5 I
¼æÈÝÐÔ£ºmacOS 10.15.7 »ò¸ü¸ß°æ±¾% D) r/ J$ q6 s* g
4 H( Z2 t! B( Q4 V
Logic Pro X is the most advanced version of Logic ever. Sophisticated tools for professional songwriting, editing, and mixing are built around a modern interface that¡¯s designed to get creative results quickly and also deliver more power whenever it¡¯s needed.
" m% b& m# @/ x2 J9 {& h; g1 V# i2 I! g
Powerful Interface3 ^ w$ s, N/ s, p8 L1 Y
• Consolidate and control multiple tracks or create rich, layered instruments with Track Stacks8 D/ \. N$ a. Z5 x
• Smart Controls allow you to manipulate multiple plug-ins and parameters with a single move
- Q% u/ R" u K8 d% Z# U5 ^• Support for the Touch Bar on MacBook Pro provides convenient controls for creating, editing and navigating your songs
5 u7 E$ {5 d' B• Autosave keeps your work safe and sound4 E8 {+ _$ R, x
" ~# U% L5 V) T. z0 P
Professional Music Production( u! O' Y4 m3 f! D
• Record and edit MIDI or audio using a comprehensive set of editors and tools* [, {0 t, e6 N) C
• Keep takes organized with take folders and build comps quickly with Quick Swipe Comping/ P1 H- x3 h! {4 i; {( {
• Track Alternatives let you create and switch between different playlists of regions and edits on a track" a6 x0 ~# X" E; X: }
• Render any combination of effect plug-ins to a selection of audio using Selection-based Processing5 K1 u0 S, R' B, H9 a. [
• Fix out-of-tune vocals and change the melodies of recorded audio with Flex Pitch
+ C& B% B# X4 F' L• Manipulate the timing and tempo of any recording with ease using Flex Time
% {; k& ^& }! L/ l0 Q' W• Comprehensive mix and plug-in parameter automation can be part of a region or track
2 K. N3 n- f- V5 r6 D• Create and mix music from anywhere in the room using Logic Remote on iPad or iPhone2 H* F# @7 T+ @* _7 q+ W* ~$ ?. u9 @2 g
• Produce simple lead sheets or orchestral scores with built-in Score editor
" p1 E8 L) Y+ U; y* v; Y8 n9 U( p+ x& w2 e" O
Drum Production1 q( {; @7 [& }1 q$ ]8 W
• Create authentic acoustic, electronic, or hip hop drum tracks using Drummer, a virtual session player and beat producer2 L! o6 o) f% e' O
• Choose among 28 distinct drummers that can take your direction and perform millions of unique grooves& U% U* M+ G6 D- R- i
• Build your own acoustic drum kits with Drum Kit Designer using a collection of deeply sampled drums
: P- _( J* q: M+ } x• Customize the sound of your electronic beats using Drum Machine Designer/ ?0 R( z% d% a1 R& F
) {* [. _- t% Q8 ZKeyboards and Synths+ I8 z% k. v/ ~; N/ G1 q9 F
• Get inspired by collection of synths that provide analog, wavetable, FM, additive, granular, spectral, and modeling synthesis" A' G1 r m' Y3 X2 ?
• Quickly find sounds or create unique new ones with Alchemy, the ultimate sample manipulation synthesizer% t5 b$ M$ h. A1 p5 z3 f; N5 y
• Play or create a wide variety of rich sampled instruments with the EXS24 Sampler
7 `- [, @9 X, P4 |7 P: ~• Instantly turn a simple chord into a rich performance with the Arpeggiator
6 Q' \# G) s8 T l# \. Q g• Transform simple ideas into elaborate performances using nine MIDI plug-ins- D# S7 u; ^' c
• Play faithful models of classic organs, keyboards, and vintage synths
! q4 U! e9 {- C$ _3 {, q' @9 n/ r/ g& I* z- R4 ` F# s! B; c
Guitar and Bass Gear$ C9 \' [; B6 X" O( |
• Build your own guitar or bass rig with Amp Designer using vintage and modern amps, cabinets, and mics( m! X4 Z/ I1 }5 N) N+ ?4 w6 W# v3 C# @
• Design a custom Pedalboard from a collection of delay, distortion, and modulation stompboxes
4 ]' i/ }3 ^9 ]- }7 `• Access the Tuner with just a click to quickly get in tune2 I2 X' L. V L: j* h4 R9 g1 {
Creative and Production Effects
& a7 z* Q( O8 B6 @! c• Play your sounds through realistic acoustic spaces using Space Designer convolution reverb/ H. N4 V. w4 E4 C5 _5 m& I4 J
• Use a range of multi-tap, vintage tape, and stereo delays
1 P( |' k+ w3 C3 j5 X n( G1 D• Add movement to your tracks with a variety of modulation effects
7 }2 i/ G4 S; Q8 \/ Q; F6 S5 G9 c9 h1 s
* W: c5 O" D! [* fSound Library
y; F. `1 n( F4 a6 l, Y• Over 2800 instrument and effect Patches
- {7 G; X( y+ f; B# U' s• 1000 meticulously sampled instruments1 e2 R7 q) j( J- h i
• More than 7000 Apple Loops in wide range of genres
6 D* I |" h3 |" @$ t& M* o( g& q+ U
, |4 X4 U: J3 z% U, M5 nCompatibility
5 k- x- Q: a8 h) P8 Q& N• Expand your instrument and effects library with third-party Audio Units-compatible plug-ins
6 o9 f. q8 _; K% Z% w# N1 M• Share to GarageBand option allows you to remotely add new tracks to your Logic project from your iPhone or iPad via iCloud
5 i0 S D" b' U$ `$ d• Import and export XML to support Final Cut Pro X workflows
* }5 J; o1 a" J) B2 [• Export and share your songs directly to SoundCloud
7 K5 K3 f* P1 @) F4 r2 t6 N• Open projects from Logic 5 or later! \7 v( f. @0 K' E
5 H5 P2 C( |% c9 H5 L$ G
Compatibility: macOS 10.15.7 or later
; {+ [& `2 p- N% ]
& a7 ~4 F8 b1 A: i# Jhttps://www.macsoftdownload.com/logic-pro-x-mac-crack1/ |
