ʵѵ»ùµØÂ¼ÒôÅïÉ豸ÅäÖ÷½°¸
¼ÒôÅï
¼ÒôÅï
ÐòºÅÉ豸Ãû³ÆÐͺŲÎÊýµ¥Î»ÊýÁ¿
1ÉùÒôÓ°Ïñ¹¤×÷Õ¾WaveDNA/NH650SΪרҵ¼ÒôÅïÉè¼ÆµÄÒôƵ¹¤×÷Õ¾£¬ËüµÄÌØµãÊÇÐÔÄÜÎȶ¨¡¢×¨Òµ¾²Òô´¦Àí¡£²ÉÓÃ2MMºñ¶Èרҵ¸ôÒô²ÄÁÏÎü¸½ÔÚ»úÏä×óÓÒ²à°å¼°Ç°Ãæ°å¡¢×ÜÓÃÁ¿´ïµ½1.35KG¡¢¿É¿ØÖƳ£¼ûµÄÏäÌå¹²Õñ¡¢ÏûºÄ¼°×è¸ôÖ÷»úÄÚÔëÒô´«²¥£¬ÃŰå²ÉÓÃ3²ãÉè¼Æ£¬ÄÚ²ã²ÉÓÃרҵÎüÒô²ÄÁÏ£¬¿ÉÓÐЧ×è¸ô¼°ÏûºÄ½ø·çͨµÀ·çÉÈÔëÒô¡£É¢ÈÈÓë¾²Òô±¾À´·Ç³£Ã¬¶Ü£¬ºÃµÄ¾²Òô¹¤×÷Õ¾»áÎþÉüÉ¢ÈÈΪ´ú¼Û£¬±¾¹¤×÷Õ¾²ÉÓÃͨ¹ýÖ÷Ãæ°å×÷Ϊ½ø·çͨµÀ£¬Ç°°å±êÅäË«12cm¿Éµ÷ËÙ¾²Òô·çÉÈ£¬Í¨¹ýÃÅ°å¿ØÖÆÔëÒô£¬¿ÉÐγÉÕýѹ²îÉ¢ÈÈͨµÀ£¬¹âÇýµ²°åÉè¼ÆÎª·À³¾Í¨·ç¿×¡£É¢ÈÈͨµÀÔÚ»úÏäµ×²¿£¬Ô¤Áô·çÉÈ×÷Ϊ¶àÓ²ÅÌÓû§½øÐи¨ÖúÐÔ³ö·çÉ¢ÈÈ£¬´Ë´¦ÔëÒôÓÉÓÚ¼õÕð½Åµæ¼°Î»ÖùØÏµ£¬¿ÉÓÐЧ»Ø±Ü´ó²¿·ÖÔëÒôÈí¼þ¼æÈÝ£ºAvid£¬Steinberg£¬Cakewalk£¬Merging Pyramix£¬Sonic Studio£¬Adobe£¬Autodesk£¬Waves£¬OzoneµÈ¡£Ö§³ÖÖ÷°åÀàÐÍ£ºATX\Micre-ATX\ITX
¡ï²ÄÖÊ£º£¾0.6MMºÚ»¯¸Ö°å/Ö÷Ìå0.6MMÈ«ºÚ»¯¡¢À­Ë¿Ñô¼«ÂÁ°å+ABSËܽº+רҵ¾²Òô²ÄÁÏÌØÉ«Åä¼þ£º3¼¶·çÉȵ÷ËÙ¿ª¹Ø\ ÏÔ¿¨±£»¤ÍмÜ
¡ïÇý¶¯Æ÷λ£º3*5.25¡¢4*3.5¡¢5*2.5À©Õ¹²Û£º7¸öÉ¢ÈÈϵͳ£ºÇ°°å*2¡¢ºó°å¡¢µ×²¿ÅäÖÃ12cm·çÉÈÖ§³Ö£º320mmÏÔ¿¨\157mm CPUÉ¢ÈÈÆ÷µçÔ´Ö§³Ö£º±ê×¼ATX PS2(·º³Æ´óµçÔ´£¬·Ç±êÅä)´¦ÀíºËо£º3.0GHz 8ºËµÚ¾Å´ú Intel Core i7 ´¦ÀíÆ÷£¬Turbo Boost ×î¸ß¿É´ï 4.7GHz£¬Èý¼¶»º´æ12MB¡£Äڴ棺32G 2666MHz DDR4 Äڴ棬ºËÐÄ×î¸ß¿É´ï128G¡£´æ´¢£º512G M.2 NVme ¹Ì̬ӲÅÌ + 2TB 256MB 7200RPM Êý¾ÝÓ²ÅÌ¡£Í¼Ðδ¦ÀíÆ÷£º ¼æÈÝNVIDIAºËÐļ¼ÊõÏÔ¿¨¡¢×î´ó·Ö±æÂÊ 4096¡Á2304£¬Ö§³ÖÇåÎúÊÓÆµÊä³ö£¬Ö§³ÖHDMI,DP, DVI-D, D-Sub£¬´óÓÚµÈÓÚ2GÏÔ´æ¡¢Ö§³ÖË«ÏÔ¡£
¡ïÍâÖÃIO½Ó¿Ú£º1 x Type-C£¬6 x USB 3.1£¬2 x USB 2.0£¬1 x RJ-45 Íø¿Ú£¬3 x HD ÒôƵ²å¿×¡£
¡ï²Ù×÷ϵͳ£ºÖ§³Ö Microsoft Windows 10ϵͳ£¬³ÖÓмÒôʦְҵ×ʸñÖ¤ÊéÊÛºó¼¼ÊõÖ§³Ö¡£
̨1
2ͼÐÎÏÔʾÆÁÄ»ViewSonic/VX2780-2K-PRO1.Ãæ°å£ºIPS¼¼Êõ2.½Ó¿Ú£ºDP£¬HDMI£¬ÒôƵ/¶ú»úÊä³ö3.ÌØÕ÷£ºÐýתÉý½µµ××ù£¬¿É±Ú¹Ò£¬ÆäËû4.ÆÁË¢ÐÂÂÊ£º165HZ̨2
3ÒôƵ½Ó¿ÚFocusrite/18i20A-D ¶¯Ì¬·¶Î§£º109 dB A¼ÓȨ£¨ËùÓÐÊäÈ룩• D-A¶¯Ì¬·¶Î§£º108 dB A¼ÓȨ£¨Ïß·Êä³ö£©• Ö§³Ö²ÉÑùÂÊ£º44.1 kHz, 48 kHz, 88.2 kHz A 96 kHz• ʱÖÓ¶¶¶¯£º<250 psÂó¿Ë·çÊäÈë• ÆµÏ췶Χ£º20 Hz ~ 20 kHz +/-0.3 dB• ÔöÒæ·¶Î§£º-4 dB ~ +46 dB• THD£º-97 dB• ÐÅÔë±È(EIN)£º- 125 dB• ¶¯Ì¬·¶Î§£º106 dB (A-weighted)• ½Ï´óÊäÈëÔöÒæ£º+4 dBų1
4ÒôƵ¹¤×÷Õ¾AVID/Protools1.¿ÉÒÔͬʱÔËÐжà´ï512¹ìÒÔÉϵŤ³Ì2.¿ÉÒÔ¶àÈËʵÏÖÔÆ¶ËЭ×÷3.¸ß´ï 32 bit/192 kHz µÄ±ê×¼Â¼ÖÆÔ­Ê¼ÉùÒô£¬ÊµÏÖ¼¸ºõÁãÑÓ³Ù4.רҵ±ê׼¼ÒôËÞÖ÷Èí¼þ/º¬¼ÓÃܹ·5.Á¢ÌåÉù6.Ö§³Ö¿ìËÙµ¼³öÌ×1
5Êý×Ö¿ØÖÆÌ¨ICON/Qcon proX+XS8¸ö´¥ÃþÁéÃôµÄµç¶¯Í¨µÀÍÆ×Ó
12¶ÎLEDͨµÀµÄµçƽ¼ÆÁ¿1¸ö´¥ÃþÃô¸ÐµÄµç¶¯ÍÆ×ÓÖ÷ͨµÀ8¸öË«¹¦ÄܱàÂëÆ÷ÐýÅ¥£¨ÊäÈëºÍÐýת£©11¶ÎLEDָʾÐýתλÖÃÖÜΧµÄ±àÂëÆ÷¡£´óÐͱ³¹âÒº¾§ÏÔʾÿ¸öͨµÀµÄͨµÀÃû³Æ£¬¿ØÖÆÖµµÈ
12¶ÎLEDÏÔʾʱ¼äÏîÄ¿µÄλÖÃÔÚSMPTE»ò»ù´¡Ìåθñʽ¡£18·ÖÅä°´Å¥¹öÂÖ¿ìËÙËÑË÷ºÍ¿ØÖÆÂÖ´©Ëó
Ϊÿ¸ö°üÀ¨RECÆôÓÃͨµÀµÄÕÕÃ÷°´Å¥£¬¶À×࣬¾²Òô£¬Ñ¡ÔñºÍ¼à¿Ø6ÔËÊäÕÕÃ÷°´Å¥£¬°üÀ¨²¥·Å£¬Í£Ö¹£¬Â¼ÖÆ£¬»Ø·Å£¬¿ì½øºÍÑ­»·º¬8ͨµÀÀ©Õ¹½Ó¿Ú
̨1
6µç×ӹܻ°Í²·Å´óÆ÷Cavatina/P2-T1.Ë«VUµçƽ±í2.µÍÔëÉù¡¢µÍÊ§Õæ´¿AÀàµç·Éè¼Æ3.³¬¿íƵÂÊÏìÓ¦4.ƵÂÊÏìÓ¦£º1Hz¡«125KHz 5.¶¯Ì¬·¶Î§£º>120dB(A-Weighted)6.CMRR:>95dB7.THD:<0.005%(typical)8.×î´ó»°Í²ÊäÈëµçƽ£º+20dBu
¡ï9.×î´óÏß·ÊäÈëµçƽ£º+17dBu10.»°Í²ÊäÈë×迹£º 350¦¸/1250¦¸11.Êä³ö×迹£º 80¦¸
¡ï12.×î´óÊä³öµçƽ£º+20dBu13.Êä³ö×迹£º<47Ohms14.×î´óÔöÒæ£º75dB15.µÈЧÊäÈë¶ËÔëÉù£º£­125dBu
¡ï16.Ïû²¨Ö¸Ê¾µçƽ£º +27dBu17.µÍÇÐÑ¡Ôñ£º10-200Hz
¡ï18.¸ºÔØ×迹£º ¡Ý1000Å·Ä·£¬ËĄ̈һÌ××°
¡ï19.×î´óÉùѹ¼¶£º 124dB SPL(0Db SPLµÈÓÚ2*10-5 Pa)
¡ï20.µÈЧÔëÉù¼¶£º £¼21dB-A
̨1
78ͨµÀ»°Í²·Å´óÆ÷Focusrite/Scarlett OctoPre1.ScarlettϵÁл°Í²Ç°Ö÷ŴóÆ÷£º»°Í²/Ïß·ÊäÈë¶Ë¿Ú´øÓÐ8¸öÒôÖÊ´¿ÕýµÄµÚ¶þ´ú1.2¸öÀÖÆ÷ÊäÈë¶Ë¿Ú-´ø¸øÄãÔöÒæ±¥Âú£¬µÍÑÓ³Ù£¬µÍÊ§ÕæµÄ¹¤×÷ÊÒ¼¶±ð¼ÒôÌåÑé¡£2.Focusrite¸ß¾«¶ÈÄ£Êýת»»£ºÄãÖµµÃÐÅÀµµÄ109dB¶¯Ì¬·¶Î§µÄFocusrite¸ß¾«¶ÈÄ£Êýת»»¡£
3.¸ßÇåÒôÖÊ£ºÖ§³Ö24-bitÄ£Êýת»»£¬²ÉÑùÂʸߴï192kHz¡£
4.Ö±²åʽʹÓãºÁ½¸ö»°Í²·Å´óÆ÷´øÓи߶¯Ì¬ÓàÁ¿µÄÀÖÆ÷ÊäÈë½Ó¿Ú£¬ËùÒԺ͸ßÒôÉùÔ´Ö±²åʹÓÃÒ²
5.²»»á³öÏÖÏ÷²¨»òÊ§ÕæÎÊÌâ¡£
6.Ê®·ÖÊʺϹÄ×é¼Òô£ºÓÅ»¯ºóµÄǰÖ÷ŴóÆ÷ÄܺܺõØÕƿص׹Ä/¾ü¹Ä·¢³öµÄ¹ýÔØµçƽ¡£7.8¸öÏß·Êä³ö£ººÜÊʺÏÏÖ³¡Â¼Òô-µ±ÄãÒªÂ¼ÖÆÊý×ÖÊä³öÐźÅʱ£¬Ïß·Êä³öÐźſɷ¢Ë͵½ÏÖ³¡µ÷Òǫ̂¡£
8.¾«ÃܵÄÒDZíºÍµçƽ¿ØÖÆ£ºÃ¿¸öͨµÀ´øÓÐ5¶ÎʽLEDÒÇ±íµÆºÍÐÂÒ»´úÔöÒæ¿ØÖÆÐýÅ¥£¬ÌṩÁ˸ü¼Ó¾«ÃÜµÄµçÆ½ÉèÖá£
9.¼ò±ãµÄADATÁ¬½Ó£ºÍ¨¹ý¹âÏËÁ¬½ÓÏ߿ɰÑScarlett Octopre¿ìËÙÁ¬½Óµ½ÈκδøADATÊäÈë¶Ë¿ÚµÄÉù¿¨ÖС£Ë«ADAT½Ó¿ÚÖ§³Ö8¸öͨµÀ96kHzµÄ»°Í²/Ïß·/ÀÖÆ÷µÄÁ¬½Ó£¬176.4/192 kHzʱÊÇ4¸öͨµÀ¡£
10.48V»ÃÏ󹩵磺¿ÉΪÿ¸öͨµÀµÄµçÈÝ»°Í²Ìṩ48V»ÃÏ󹩵硣
11.ÏȽøµÄÊý×ÖʱÖÓ£º´øÓÐ×ÖʱÖÓ½Ó¿Ú£¬ÎªÊý×ÖϵͳÌṩ³¬¼¶Îȶ¨µÄʱÖÓÐÔÄܱíÏÖ¡£
̨1
8Êý×ÖЧ¹ûÆ÷TC/M2000Êý×ÖÊäÈëÊä³ö½Ó¿Ú£ºXLR(AES/EBU),RCA(S/PDIF)¸ñʽ£ºAES/EBU£¨24bit£©£¬S/PDIF£¨24bit£©£¬EIAJ CP-340£¬IEC958Êä³ö¶¶¶¯£ºHPF TPDF¶¶¶¯8-24 bit²ÉÑùƵÂÊ£º44.1kHz£¬48 kHz´¦ÀíÑÓʱ£º0.2ms@48 kHzƵÂÊÏìÓ¦£º20Hz-35.9 kHz£¬+/-0.01dB@48 kHzÄ£ÄâÊäÈë½Ó¿Ú£ºXLRƽºâ½Ó¿Ú(½Ó½Å2ΪÈȶË)×迹£º20kohm½Ï´óÊäÈëµçƽ£º+22dBu(ƽºâ)×îСÊäÈëµçƽ£º-10dBuÁéÃô¶È£º±£Ö¤12dB¶¯Ì¬ÓàÁ¿Ê±£º-22dBu-10 dBuÄ£Êýת»»£º24 bit£¨1 bit£¬128±¶¹ý²ÉÑù£©Ä£Êýת»»ÑÓʱ£º0.8ms@48 kHz¶¯Ì¬·¶Î§£º>103dB£¬>106dB£¨A¼ÆÈ¨£©THD£º-95 dB£¨0.0018%£©@1 kHz£¬-9 DbFS(FS@+16 dBu)ƵÂÊÏìÓ¦£º10Hz-20 kHz£¬+0/--0.2dBÉ«¶ÈÁÁ¶È´®ÈÅ£º<-80dB£¬10Hz-20 kHz£¬±ê×¼-100 dB@1 kHzPCMCIA´æ´¢¿¨½Ó¿ÚÁ¬½Ó£ºPC£¬68Õ룬¿É²å1¿¨½øÐÐÒôÉ«À©Õ¹±ê×¼£ºPCMCIA2.0£¬JEIDA4.0À©Õ¹¿¨¹æ¸ñ£ºÖ§³Ö½Ï´ó2MB¾²Ì¬´æ´¢Ì¨1
9רҵĸ´ø´¦ÀíÆ÷BBL AUDIO/S8²ÉÓÃA280¸ß¹¦ÂÊ¿íÆµ³¡Ð§Ó¦ÔËËã·Å´óÆ÷¼æÈÝHybridϵͳ
Ô­´´2¼¶Ñ¹ÏÞ¹¤×÷Ô­Àí
Á¢ÌåÉù10¶ÎPEAK LED ָʾµÆ2¸ö¿¨Å©Ä¸Í·ÊäÈë2¸ö¿¨Å©¹«Í·Êä³öͨµÀÊý:Á¢ÌåÉù
×î´óÏì¶ÈÌáÉýÔöÒæ:20dBLEVELÐýÅ¥¿ØÖÆ·¶Î§:20dBƵÂÊÏìÓ¦(ȡֵ¡À0.5dB): 20Hz ~ 22kHzÊäÈë×迹:LINE in @22k OhmsÊä³ö×迹:600 Ohms
±¾µ×Ô룺£¼-70dBu @0dBÊä³öÔöÒæ¡£
̨1
10¼àÌý¶ú»ú¡¢ÓÃÓÚ¿ØÖÆÊÒFocal/Listen pro1.ÀàÐÍ·â±Õʽ£¬»·ÈÆÊ½¶ú»ú2.×迹£º32Å·Ä·
3.ÁéÃô¶È£º122dB SPL@1KHz¨C/1Vrms
4.THD£º 0.3%@1 kHz/100·Ö±´SPL
5.ƵÂÊÏìÓ¦£º5Hz¨C22kHz6.ÖØÁ¿£º10°»Ë¾£¨280¿Ë£©7.Ìṩ£º16Ó¢³ß£¨5Ã×£©Ö±µçÀ£¬4.5Ó¢³ß£¨1.4Ã×£©8.Á¬½ÓÆ÷£º3.5ºÁÃײåÍ·£¬´ø4¸ùµ¼Ïß
Ö»2
11¼àÌý¶ú»ú¡¢ÓÃÓÚ¸èÊÖAKG/K521.Åå´÷·½Ê½£ºÍ·´÷ʽ
2.Ö÷ÒªÓÃ;£ºÌ¨Ê½ÒôÏì,¼àÌý
3.»»ÄÜÔ­Àí£º¶¯È¦Ê½
4.ƵÂÊÏìÓ¦£º16Hz-28KHz
5.×迹£º55Å·
6.ÁéÃô¶È£º91dB
7.×î´ó¹¦ÂÊ£º200mW
8.Âó¿Ë·ç£ºÎÞÂó¿Ë·ç
9.²åÍ·£º¶ú»úΪMini-XLR½Ó¿Ú,Á¬½ÓÏßΪ3.5mm¶Æ½ðÖ±ÐͲåÍ·
10.µçÀ£º3Ã×
11.ÖØÁ¿£º240g12.¸½¼þ£º3.5mmת6.3mm¶Æ½ð²åÍ·
Ö»5
12¶ú»ú·ÖÅäÆ÷Cavatina/AHD61.Á¢ÌåÉùÊäÈë¿É·ÖÅ䵽ÿ×é¶ú»ú
2.ËùÓнӿھù²ÉÓÃ¸ßÆ·Öʶƽð²ÄÖÊ
3.ÉùÒôÇåÎúÎÞËð
4.º¬ÕýÃæ°åֱͨÊäÈë×ÜÒôÁ¿¿ØÖÆÐýÅ¥,ÕýÃæ°åÊäÈëÐźÅÓÅÓÚ±³Ãæ°å5.ÿ×éͨµÀ´øÓÐÊäÈë½Ó¿Ú
6.ÿ·ͨµÀ¾ù´øÓжÀÁ¢µÄ¶ú»úÊä³öͨµÀ
7.ÿ¸öͨµÀÉ϶¼ÓÐmono/stereo¿ØÖÆ
8.ÿ¸öͨµÀÉ϶¼ÓÐÒôÁ¿Êä³öµçƽ¿ØÖƼ°L/R Mute¿ØÖÆ
¡ï9.ÿ·ͨµÀ¾ù´øÓÐ-24ÖÁ12dbµÄLEDÐźÅָʾµÆ
¡ï10.Ö÷ÊäÈë´øÓÐ-24ÖÁ18dbLEDµçƽÐźÅָʾµÆ11.´øÓÐÁ¢ÌåÉùֱͨÊä³ö12.ÊäÈë/Êä³ö½Ó¿Ú£ºÆ½ºâʽµÄXLR¼°6.5mm½Ó¿Ú13.ÊäÈë×迹:55ǧŷƽºâʽ/30ǧŷ·Çƽºâʽ14.ÊäÈëµçƽ:©�12dBÖÁ©€6dB
¡ï15.×î´óÊäÈëµçƽ£º©€24dBu16.¶¯Ì¬ÏÞÖÆ:>60dB(1KHz)17.auxÊäÈë½Ó¿Ú£º6.5mm18.auxÊäÈëÀàÐÍ£º·Çƽºâʽ19.Êä³ö×迹£ºËæÊäÈë×迹ֵ¿É±ä20.×î´óÊä³öµçƽ£º©€24dBu
¡ï21.ƵÏ췶Χ£º20Hz-22KHz£¬¡À3dBu22.ÔëÉù£º>©�90dBu at 22Hz-22KHz
¡ï23.×Üг²¨Ê§Õ棺0.005%£¬1KHz£¬©€4dBu24.×î´óÊä³ö×迹£º110¦¸25×î´óÔöÒæ£º©€24dB26.µçÔ´¹©Ó¦£º220V-240V AC27.¹¦ºÄ£º40W28.1U»ú¼ÜÉè¼Æ,6×é¶ÀÁ¢¸ßÆ·Öʶú»ú·Å´óÆ÷
̨1
13¼àÌýÒôÏä1Valseana/CR8¡ï4¡°´¿ÂÁÖÆÒôȦ£»Ë«Í¨µÀ¸ßË®×¼100/200W ¶î¶¨¹¦·ÅƵÂÊÏìÓ¦£º42Hz¡ª50kHz£¨¡À3dB£©µÍƵÏì¶ÈË¥¼õ£º-3dB@60Hz¸ßƵÏì¶ÈË¥¼õ£º-3dB@22KHz
¡ïÉùѹ¼¶£º100dB SPL@1m£¨@1 meter,+5dBu into Balanced Input)×î´óÉùѹ¼¶£º131dB SPL@1m£¨Per Pair£©µÍÒôµ¥Ôª£º1¸ö/£¨10in£©203mm¸ßÒôµ¥Ôª£º1¸ö/£¨1in£©25mmµÍÒôµ¥Ôª¹¦ÂÊ£º150watts 4ohm (·åÖµ200watts£©¸ßÒôµ¥Ôª¹¦ÂÊ£º50watts 4ohm£¨·åÖµ100watts£©
¡ïѹ°ÚÂÊ£º£¾15V/¦Ìsг²¨Ê§Õ棨THD,SMPTEIMD,DIM100):£¼0.035£¥¸ßƵÀàÐÍ£ºMonlithic IC,Class AB with DMOS power stageµÍƵÀàÐÍ£ºDiscrete bipolar Class AB
¡ïÀàÐÍ£º24dB/±¶Æµ³Ì
¡ï·ÖƵµã£º3kHzÁéÃô¶È£º+4dBU at 300Hz for full outputÊäÈë×迹£º20k¦¸£¨Æ½ºâ£©/10k¦¸£¨·Çƽºâ£©
¡ï¸ßƵ²¿·ÖEQ:+2dB/+4dB@100Hz£¬shelvingµÍƵ²¿·ÖEQ:+2dB@5kHz£¬shelving·ÖƵƵÂÊ£º1800 Hz·ÖƵбÂÊ£º30 dBÿ°Ë¶È
¡ï¸ßÒôÑïÉùÆ÷£ºEsotec 28 mm Èíñ·ÐÎ
¡ïµÍÒôÑïÉùÆ÷£º240 mm, Ò»Ìå³ÉÐ;۱ûϩ׶Ìå, 100 mm´¿ÂÁÒôȦ
¶Ô1
14¼àÌýÒôÏä2Valseana/CR101.ÒôÏäÀàÐÍ£ºÈý·ÖƵÓÐÔ´ÒôÏä2.Íâ¿Ç²Ä£º25/18mm MDF°å3.ƵÂÊÏìÓ¦£º35Hz-25KHz£¨¡À3dB£©4.µÍÒôµ¥Ôª£º10´çÏ𽺱߳¤³å³Ìµ¥Ôª5.ÖÐÒôµ¥Ôª£º4´çÏ𽺱߲£Á§ÏËάÒôÅè
¡ï6.¸ßÒôµ¥Ôª£º1.25´çо²Ï˿ĤÇò¶¥´ÅÒºÀäÈ´¸ßÒô
¡ï7.·ÖƵ£ºµÍÒôÓëÖÐÒôµÄÏνÓΪ·ÖƵµã200Hz£»ÖиßÒôÄÚÖÃÎÞÔ´·ÖƵ·ÖƵµã2500Hz.8.×î´óÉùѹ£º©ƒ120dB9.ÁéÃô¶È£º95 dB@1m
¡ï10.µÍÒôͨµÀ¹¦·Å×î´óÊä³ö£º1000W/4¦¸11.ÖиßÒôͨµÀ¹¦·Å×î´óÊä³ö£º400W/4¦¸
¡ï12.×Üг²¨Ê§Õ棺©‚0.04%13.¶¯Ì¬·¶Î§£º©ƒ110dB14.ÒôƵÊäÈ룺ƽºâÓë·ÇƽºâÄ£Äâ¶Ë¿Ú
¶Ô1
15¼àÌý¿ØÖÆÆ÷Running man/bigknob Studio+¿ÉÔÚ 4 ·ÊäÈëÔ´ºÍ 3 ·¼àÌýÒôÔ´Ö®¼äÇл»¾­µäµÄ Big Knob ´óÐýÅ¥ÒôÁ¿¿ØÖƶÀÁ¢¿ª¹ØÃ¿Â·ÒôÔ´£¬°üÂçÊäÈëÔ´ºÍ¼àÌýÔ´µ¥ÉùµÀ¡¢¾²ÒôºÍË¥¼õ¹¦ÄÜ2 ·´ø»ÃÏëµçÔ´µÄ¸ßÖÊÁ¿ Onyx Âó¿Ë·çǰ¼¶¹¦·Å192kHz/24-bit ¸ßÖÊÁ¿Â¼ÒôºÍ²¥·ÅCue Mix ¿ÉÒÔ¿ØÖƸ÷·ÐźŵĿª¹Ø£¬Í¬Ê±¶ÔÆäËûÐźŽøÐÐÎÞÑÓ³Ù¼Òô¿É×ÔÐÐÑ¡ÔñºÍÇл»Â¼Òô¹ìµÀ£¬ÓÈÆäÊʺϹ㲥µç̨ÄÚÖà 3.5mm ÊäÈë½Ó¿Ú£¬ÊʺÏʹÓÃÊÖ»úÊäÈëË«¶ú»úÊä³ö£¬´ø¶ÀÁ¢µÄÒôÁ¿¿ØÖÆ£¬¿ÉÇл» Aux ¼àÌý»òÕß USB ÊäÈëÐźÅÄÚÖöԽ²¹¦ÄÜ£¬¿É½ÓÈë̤°å½øÐпØÖÆÄÚÖù¦·ÅµÄÊä³öÐźÅ16 µµ¸ßÇåÊäÈëÐÅºÅµçÆ½²ÎÊýÏÔʾ̨1
16ÈËÉùµçÈÝ»°Í²1Cavatina/T535¡ï1.2Ó¢´çTϵÁи߾«¶È¼«Í·Âó¿Ë·çÀàÐÍ£¨4Ö»Ò»Ì××°£©: µç×ӹܵçÈÝÂó¿Ë·çµç×Ó¹ÜÀàÐÍ£ºVD-6072
¡ïµçÔ´: VD-535µçÔ´Ö¸ÏòÐÔ£º Ô²ÐÍ¡¢ÐÄÐÍ¡¢8×ÖÐ͵ȾÅÖÖÖ¸ÏòÐÔ
¡ïƵÂÊ·¶Î§£º17-24Khz
¡ïÁéÃô¶È£º28mV/Pa
¡ïµÈЧÔëÒô¼¶£º11dB( A¼ÆÈ¨IEC651) ÐźÅÔëÉù±È£º86dB
¡ï×î´óÉùѹ¼¶£¨0.5% THD @ 1000Hz£©£º148dB½ÓÍ·:XLR3F
Ö»1
17Á¢ÌåÉù»°Í²Valseana/TM1-S1.Ö¸ÏòÐÔ£ºÐÄÐÍ2.ÉùÒô²Ù×÷Ô­Àí£ºÑ¹Á¦Ìݶȴ«¸ÐÆ÷
¡ï3.ƵÂÊÏìÓ¦£º20Hz-20kHz4.ÁéÃô¶È£º13mV/Pa5.×迹£ºLow (Less than 200 Ohms)¡ï6.µÈЧÔëÉù¼¶£º+14dB (A-weighted)Á½Ö»Ò»Ì××°
¡ï7.×î´óÉùѹ¼¶£¨THDµÈÓÚ0.5%£©£º140dBµçÔ´£º48V»ÃÏ󹩵ç8.Á¬½ÓÆ÷£º3Õ뿨ũ
Ö»1
18ÈËÉùµçÈÝ»°Í²2Cavatina/S86 MKIIÐÄÐÎÖ¸ÏòÐÔÉè¼ÆÆµÏìÏìÓ¦:20Hz-20KHzÊä³ö×迹:200ohms
¡ï¸ºÔØ×迹:1000ohms
¡ïµÈЧÔëÉù¼¶:17dB-A
¡ïÐÅÔë±È£º90db-A£¨ICE-651£©ËÄÖ»Ò»Ì××°
¡ïÁéÃô¶È:33mV/Pa at 1KHzS/N±È:88dB*×î´óÉùѹ¼¶£¨THDСÓÚ0.5%£©:140dB(ÐÄÐÍ)×î´óÉùѹ¼¶:145dB¶¯Ì¬·¶Î§ :135dB½ÓÍ·:3Õ뿨ٯ½Ó¿Ú
Ö»1
19·ÀÅçÕÖDesksaver/MS-11.½ðÊô²ÄÖÊ Ë¿ÍøÄ¤Éè¼Æ¸ö3
20½ø¿Ú½Ó²å×éºÏÉ豸¶¨ÖÆ¿¨Å©¹«¡¢DB25¡¢¿¨Å©ÄÁ¡¢´óÈýо¡¢¹âÏËÏß¡¢¶àоÀ¡¢48¿ÛÌøÏßÅÌ¡¢ÌøÏßÈô¸É¡¢¶à¹¦ÄܲåÏß°å¡¢Êý×Öͬ²½ÏßµÈÏî1
21µçÔ´¾»»¯Æ÷Â˲¨Æ÷JOECO/PRO D30001.¶î¶¨µçÁ÷£º15°²Åà2.¿ØÖƲå¿Ú£º103.µç´ÅÓëÉ䯵Â˲¨£ºÊÇ
¡ï4.À­³öʽ´óÑÛ¾¦LEDÕÕÃ÷µÆ
¡ï5.ʵʱ¼à²âµçѹÊý¾Ý6.ÏìӦʱ¼ä£º1ÄÉÃë7.¹¤×÷µçѹ£º180 - 260V AC
¡ï8.EMI¶à¶ÎÂ˲¨£ºÏû³ýµçÐźÅÖеIJ»Í¬³É·ÖÔÓ²¨9. ÊÖ¶¯¹ýÔØ±£»¤£º³¬¹ý¸ººÉ×Ô¶¯×è¶ÏµçÁ÷£¬±£»¤ºó¼¶É豸°²È«10.ÑÓʱÅä¼þ²å×ù£º8×Ü11.²å¿Ú¹¦ÄÜ£º2Êý×ÖÆ÷²Ä2Ä£ÄâÆ÷²Ä 4¸ß¹¦ÂʹýÂË12.µçѹÏÔʾ£ºÊÇ13.ÑÓ³Ùʱ¼äÔ¤Öãº1Ãë14.ÓµÓиߵ͵ƹâÁÁ¶Èµ÷½Ú£¬ÍêÃÀÓ¦Óõ½Îę̀ÒÔ¼°×¨Òµ¹¤×÷ÊÒ
¡ï15.¶à¹¦ÄÜרÓòå×ù£ºÌṩ²»Í¬Æ÷²ÄרÓýӿڱ£Ö¤ÍêÃÀµçÁ¦´«Êä
¡ï16.ʱÐò¿ª¹Ø£º×Ô¶¯²½½øÊ½¸øÃ¿¸ö½Ó¿Ú¹©µç£¬·½±ã¿ØÖƲ»Í¬Æ÷²Ä°´Ë³Ðò¿ª¹Ø17.EMI¶à¶ÎÂ˲¨£ºÏû³ýµçÐźÅÖеIJ»Í¬³É·ÖÔÓ²¨¡£
¡ï18.ÊÖ¶¯¹ýÔØ±£»¤£º³¬¹ý¸ººÉ×Ô¶¯×è¶ÏµçÁ÷£¬±£»¤ºó¼¶Æ÷²Ä°²È«19.ֱͨÊä³ö£ºÁ¬½ÓÆäËûÆ÷²Ä·ÀÀ×±£»¤¡£20.µçѹÏÔʾ£ºÊµÊ±¼à¿ØÏÔʾµ±Ç°Í¨Â·µçѹ¡£21.µçѹ±£»¤£ºµ±Óöµ½Òì³£µçѹʱ×Ô¶¯±£»¤ºó¼¶Æ÷²Ä22.ÓµÓÐרÀûAUTO CUT×Ô¶¯µçѹ±£»¤¼¼ÊõÒÔ¼°23.ÔÓ²¨Â˳ý¼¼Êõ24.·ÀÀ×±£»¤Éè¼ÆÎªÒ»ÌåµÄ¸ßÆ·ÖÊרҵµçÔ´ 25.ÌṩÁ˶à×é¶à¹¦Äܲå×ù¡¢¿ÉÒÔ¼æÈݲ»Í¬¹ú¼Ò±ê×¼µÄ²åÍ·26.Õë¶Ô²»Í¬Æ÷²ÄÂ˲¨ÌØÐÔÌṩÁËÄ£Ä⣬Êý×Ö£¬ÒÔ¼°¸ß¹¦ÂÊÊä³ö²å×ù
̨2
22»°Í²Ö§¼ÜDecksaver/HM1021.¸ß¶È¿É×ÔÓɵ÷½Ú2.Èý½ÇÂ䵨3.½ðÊô²ÄÖÊ4.¿ÉºáÕÛ90¶È¼°µ÷½Ú³¤¶Ì¸ö5
23¶ú·ÖÖ§¼ÜDecksaver/M3051.´ø¹öÂÖ¿ÉÒÆ¶¯2.Èý½ÇÂ䵨3.½ðÊô²ÄÖÊ4.¿É¹Ò¶ú»ú¸ö1
24¼àÌýÒôÏäÖ§¼ÜICON/SB2001.¿É½Ç¶Èµ÷½Ú2.Èý½ÇÂ䵨3.½ðÊô²ÄÖÊ4.ÓëÒôÏ䯥Åä¸ö4
25ÀÖÆ×Ö§¼ÜDecksaver/EX-11.¸ß¶È¿É×ÔÓɵ÷½Ú2.Èý½ÇÂ䵨3.½ðÊô²ÄÖÊ4.¿Éµ÷Õû½Ç¶È¸ö4
26¹¤×÷̨Decksaver/CN800 SL1.¸Öľ½á¹¹¡£2.¸ù¾Ýµ÷Òǫ̂ÍâÐÎÉè¼Æ×÷ǶÈë°²×°£¨º¬Ð±²å»ú¹ñ)¡£3.ÀιÌÄÍÓᣠ4.ÄÍËá¼î£¬¿¹¸¯Ê´£¬·À¾²µç¡£ 5.·ÀÐâÁ×»¯´¦Àí¡£ 6.ÍÑÖ¬¡¢ËáÏ´´¦Àí¡£ 7.ÉèÓÐͨ·çÉ¢ÈȰ塣8.»ú¼ÜÓë»ú¼ÜÄÚÉè×ßÏß¿×Óë¹ýÏß²Û£¬¸ù¾ÝÁ㲿¼þ×÷Óò»Í¬£¬ÁϺñ¹æ¸ñ·Ö±ðΪÏÖ³¡¼Ó¹¤´îÅ䣬¼Ó¹¤Ó²»¯£¬ÀιÌÄÍÓá£Ì×1
ÆÀÂÛÁÐ±í£¨1£©
m13370149101 Â¥Ö÷
»¶Ó­¹âÁÙ ÖйúȨÍþµÄ¼ÒôÅïϵͳ¼¯³ÉÉÌ¡ª¡ª±±¾©ÀÖ³ÇÊ˹ú¼Ê¿Æ¼¼ÓÐÏÞ¹«Ë¾
±¾¹«Ë¾ÎªÊµÌå¾­ÓªµÄºÏ·¨×¢²á¹«Ë¾£¬ËùÓвɹº¼°ºÏ×÷ÏîÄ¿¾ù¿ÉÇ©ÊðºÏ·¨ÕýʽºÏͬ£¡
±¾¹«Ë¾ÊÛǰ³Ðŵ£ºËù¹©É豸¾ùΪȫÐÂÔ­×°Ðлõ£¡¼ÙÒ»·£Ê®£¡±£Ö¤°´³§¼Ò¹æ¶¨Ãâ·Ñ±£ÐÞ£¡
±¾¹«Ë¾ÊÛºó³Ðŵ£º±¾¹«Ë¾Å䱸·Ç³£×¨ÒµµÄÒôƵ¼¼ÊõÍŶӣ¬ÎªÄúÌṩ¼¼ÊõÖ§³Ö·þÎñ£¡
ÀÖ³ÇÊËÏîÄ¿¾­Àí£ºÁõÑ󠠵绰/΢ÐÅ£º13370149101 QQ£º3490029085   ³Ð½ÓÈ«¹ú¼ÒôÅïÏîÄ¿
2021-7-7 10:56:37 »Ø¸´
