| ¼ÒôÅï |
| ÐòºÅ | Îï×ÊÃû³Æ | ²úÆ·ÐͺŠ| £¨¼¼Êõ²ÎÊý£© | µ¥Î» | ÊýÁ¿ |
| 1 | ÒôƵ¹¤×÷Õ¾ | WaveDNA NH650S | ´¦ÀíÆ÷ Ó¢ÌØ¶û£¨Intel£©CPU i7 9700£¬É¢ÈÈÆ÷¿áÀäÖÁ×ð¾²Òô£¬Ö÷°å Intel B365-PLUS£¬ÄÚ´æDDR4 26668G*2£¬1TB¹Ì̬M.2 nvmeÐÒ飬 2TB 7200RÓ²ÅÌ£¬ 500wµçÔ´£¬ÏÔ¿¨Nvdia RTX 2080£¬¼üÊóÌ××°£¬protools Õýʽ°æ£¬ 27´çÏÔʾÆ÷Á½Ì¨¡£ | Ì× | 1 |
| 2 | ÒôƵ½Ó¿Ú | UA Apollo x8p | ¶¯Ì¬·¶Î§121dBA£¬Êä³öµçƽ +20dBu£¬»°·ÅͨµÀ 8·£¬Ä£Äâ½Ó¿Ú 8x14£¬Êý×Ö½Ó¿Ú 10x10£¬À×µç½Ó¿Ú 2¸ö£¬¶ú»ú½Ó¿Ú 2×飬×ÖʱÖÓ I/0£¬Èí¼þ¿ØÖÆ Windows/MacOS£¬¶ú·ÅÍÆÁ¦160mW¡£ | ̨ | 1 |
| 3 | »ìÒǫ̂ | Mackie MCU Pro | ͨÐÅÐÒéÎÞ·ì¶Ô½ÓÒôÆµÖÆ×÷Èí¼þ£¬100mm´¥Ãþ¸ÐÓ¦ÍÆ×Ó£¬´øÓлú¶¯×°Öã¬V-potÓÃÒÔ¿ØÖÆÈí¼þ¡¢²å¼þЧ¹ûºÍÐéÄâÀÖÆ÷£¬50¸öרÓð´Å¥ÓÃÀ´Ï¸ÄåµÄ¿ØÖÆÈí¼þÖеIJÎÊý£»´Å´øÊ½×ß´ø¿ØÖÆÆ÷£»È«ÒDZíÏÔʾ´øÓйìµÀÃû³ÆºÍ²ÎÊý£»¿ìËÙ¹â±êʽ°´¼ü¿ØÖÆÉÏ¡¢Ï¡¢×ó¡¢ÓÒÒÔ¼°Ëõ·Å£»USB MIDI½Ó¿ÚÖ±½ÓÓëMac»òPC½øÐÐÁ¬½Ó£¬×î¶à¿É½Ó3¸ö¶îÍâµÄMIDIÉ豸£»¿Éͨ¹ýMackie Control Extender Pro
ºÍC4 ProÄ£¿é½øÐÐÀ©Õ¹ À©Õ¹µ½16ͨµÀ¡£ | Ì× | 1 |
| 4 | ÈËÉùÂó¿Ë·ç | HV-Audio SP-5000 | ³¬µÍÔëÒô£»¶¯Ì¬·¶Î§¿í¹ã£»AÀàµç×ӹܵç·£»ÊÖ¹¤É¸Ñ¡µÄ·Ö¼¶µç×ӹܣ»×¨ÓõçÔ´£»3ÖÖÖ¸ÏòÐÔ£ºÈ«Ö¸Ïò£¬ÐÄÐÎÖ¸Ïò£¬8×ÖÖ¸Ïò£»¸ßÇ¿¶Èº¸½Ó²¢¾¹ýÈÈ´¦ÀíµÄ¸ÖË¿ÍøÕÖ»°Í²Í·£»¾¾ÃÄÍÓõĶÍÃæ¶ÆÄø±íÃæ£»ÄÚ²¿¼«Í··ÀÕðÉè¼Æ£»Ç¿Á¦¿¹RFÉ䯵¸ÉÈų¬µÍÔëÒôƵÂÊÏìÓ¦£º20 Hz£20 kHz¡¤Êä³ö×迹£º200¦¸£»ÁéÃô¶È£º-36 dB re 1Volt/Pascal (16 mV @ 94dB SPL) +/- 2 dB£»µÈÖµÔëÉù£º10 dBA¡¤¶¯Ì¬·¶Î§£º150 dB£»¹©µçÒªÇó£ºÍⲿ¹©µç110£120V/220£240V, 50/60Hz£»·ÀÕð¼Ü¡¢µçÔ´ºÐ¡¢»°Í²Á¬½ÓÏß¡£³§¼ÒÌṩÈýÄêÊÛºó¼¼ÊõÖ§³Ö¡£ | Ì× | 4 |
| 5 | Á¢ÌåÉù»°Í² | sE Electronics sE8 | µçÈݲÖ:ÊÖ¹¤ÖÆ×÷µÄСÕñĤµçÈÝ»°Í²£»Ö¸ÏòÐÔ:ÐÄÐΣ»ÆµÏ췶Χ: 20- 20,000 Hz£»ÁéÃô¶È: 25 mV/Pa (-32 dBV)£»´óÉùѹ¼¶: (0.5% THD): 139/ 149 / 159 dBSPL (0/10/20 dB Attenuation pad)
µÈЧÔëÉùˮƽ: 13 dB(A)£»¶¯Ì¬·¶Î§: 126/ 136 / 146 dB (0/10/20 dB Attenuation pad)£»ÐÅÔë±È: 81 dB£»µÍÇÐÂ˲¨Æ÷: 80/ 160 Hz, 6 dB/Oct,¿ÉÇл»£»Ë¥¼õ¹¦ÄÜ: 10/ 20 dB,¿ÉÇл»£»µçÔ´: 48 Volts according to IEC 61938£»×迹: 110 Ohms£»ÍƼö¸ºÔØ: >1k Ohms
µçÁ÷ËðºÄ: 2.7 mA£»½ÓÏßÖù: 3-pin male XLR connector£»³ß´ç:Ö±¾¶: 23 mm£¬³¤¶È 120 mm¡£ | Ö§ | 1 |
| 6 | ÀÖÆ÷»°Í²Ì××° | LEWITT DTP 340 | ÊÖ³Ö»°Í²¡£¹¤×÷ÔÀí£º¶¯È¦Ê½£»Ö¸ÏòÐÔ£º³¬ÐÄÐΣ»ÆµÂÊ·¶Î§£º40-16,000Hz£¬ÁéÃô¶È£º1.4mV/Pa(-57dBV)£»¸ºÔØ×迹£º<500¦¸£»²åÍ·£º3ÕëXLR¶Æ½ð²åÍ·£»³ß´ç£º41Ö±¾¶¡Á94mm£»1.6Ö±¾¶¡Á3.7Ó¢´ç¡£
ÀÖÆ÷»°Í²¡£¹¤×÷ÔÀí£º¶¯È¦Ê½£»Ö¸ÏòÐÔ£ºÐÄÐΣ»ÆµÂÊ·¶Î§£º20-16,000Hz£»ÁéÃô¶È£º2.5mV/Pa(-52dBV)£¬¶î¶¨×迹£º<500¦¸£»²åÍ·£º3ÕëXLR¶Æ½ð²åÍ·£»³ß´ç£º71Ö±¾¶¡Á158mm£»2.8Ö±¾¶¡Á6.2Ó¢´ç¡£ | Ì× | 1 |
| 7 | »°Í²·Å´óÆ÷ | bblaudio 2042 | »°·ÅͨµÀÊý£º2£»»°·ÅÆðʼÔöÒæ£º²»µÍÓÚ20dB£»GAINÐýÅ¥¿ØÖÆ·¶Î§£º55dB£»»°·Å×î¸ßÔöÒæ£º²»µÍÓÚ75dB£»OUTÐýÅ¥¿ØÖÆ·¶Î§£º -¡Þ to 0dB£»µç·ÀàÐÍ£ºAÀࣻ»°·ÅÇ°Ãæ°åÅ䱸ÐźŹýÔØLED¾¯¸æÖ¸Ê¾µÆ¡£ÔËËã·Å´óÆ÷ÀàÐÍ£º²ÉÓ÷ÖÁ¢ÔªÆ÷¼þÔËËã·Å´óÆ÷£»¶ÀÁ¢Ô˷ʤÒÕ£º½ðÊô·â×°100%Ƶ±Õ£»ÊäÈë½Ó¿Ú£ºMICÊäÈë¡¢LINEÊäÈëºÍDIÊäÈ룻ƵÂÊÏìÓ¦£¨È¡Öµ¡À0.5dB£©: 20Hz to 22kHz£»ÊäÈë×迹: Mic @2k Ohms,Line in @22k Ohms,DI @2M Ohms £»Êä³ö×迹: 600 Ohms£»ÊäÈëñîºÏÀàÐÍ£º×¨ÒµÒôƵÊäÈë±äѹÆ÷£»ÊäÈë±äѹÆ÷¼¼Êõ: ÆÂĪºÏ½ð´Åо£¬²¢100%½ðÊô·â×°ÆÁ±Î£»×î´óÊä³öµçƽ: ²»Ð¡ÓÚ+27dBu£»²åÈëDIʱÊäÈëÔ´×Ô¶¯Çл»ÎªDIÊäÈ룻´øÓз´Ï࿪/¹Ø£»»ÃÏóµçÔ´: +48V£»ÍâÐγߴ磺±ê×¼1U»ú¼Üʽ¡£ | ̨ | 2 |
| 8 | 8·»°Í²·Å´óÆ÷ | Focusrite Scarlett OctoPre 8 | ÔöÒæºÍµçƽ¡£Âó¿Ë·çÔöÒæ£º+10dBÖÁ+55dB£»Ïß·1-8ͨµÀÔöÒæ£º-10dBÖÁ+55dB£»ÀÖÆ÷µç·ÔöÒæ£º+10dBÖÁ+55dB£»»ÃÏ󹩵çÒÔ4¸öÂó¿Ë·çͨµÀΪһ×éÇл»£¬1-4ºÍ5-8£»Âó¿Ë·çºÍÀÖÆ÷×î´óÊäÈëµçƽ+16dBu£»Ïß·ÊäÈë×î´óµçƽ+26dBu¡£
ѹËõÆ÷¡£ãÐÖµ·¶Î§£º-44dBFS£¨×î´óÉèÖã©ÖÁ-4dBFS£¨×îСÉèÖã©£»Ñ¹Ëõ±ÈÂÊ£ºÕý³£×´Ì¬2£º1£¬¸ü¸ßѹËõ£º4£º1£»×Ô¶¯ÔöÒæ²¹³¥£º4dB£¨×îСÉèÖã©£¬18dB£¨×î´óÉèÖã©£»Æðʼʱ¼ä£º1.2ms£¬ÊÍ·Åʱ¼ä£º28ms£¨-3.5dB·½·¨£©£»Ñ¹ËõÇúÏߣº¾µäFocusrite Soft Knee£¨ÈíÏ¥£©£»THD+N£¨ÔÚÈκÎѹËõÆ÷ãÐֵϵÄ×î´óÖµ£¬ÊäÈë<+16dBu£¬×îСÔöÒæ£©£º<0.18%¡£Ê±ÖÓÔ´¡£ÄÚÖÃʱÖÓÔ´£»×ÖʱÖÓÊäÈë½Ó¿Úͬ²½£»ADATÊäÈë½Ó¿Úͬ²½£¨½öÊÊÓÃÓÚADAT 1ÊäÈ룩£»Ç°Ãæ°åָʾ£»Ä£ÄâÊäÈëµçƽ±í£¨1-8ͨµÀ£©£¬5¶Î£¨-42£¬-18£¬-6£¬-3ºÍ0dBFS£©£»4²ÉÑùÂÊLEDָʾµÆ£¨44.1k£¬48k£¬88.2kºÍ96k£©£»3¸öͬ²½Ô´LEDָʾµÆ£¨ÄÚ²¿Í¬²½£¬×ÖʱÖÓºÍADAT£©£»¡°Ëø¶¨¡±×´Ì¬LEDָʾµÆ£»Ä£ÄâÊä³ö¿ÚÐźÅÔ´ADDAÇл»¿ª¹Ø£¨A/D¶Ë»òADATÊäÈ룩¡£ÍâÐγߴ磺¿í484mm£¬¸ß45mm£¬Éî265mm¡£ | ̨ | 1 |
| 9 | Á¢ÌåÉùѹËõ | bblaudio VCA | ͨµÀÊý£ºÁ¢ÌåÉù£»Ñ¹ËõÆ÷ÀàÐÍ£ºVCA£»Á¢ÌåÉùѹËõ²àÁ´¼¼Êõ£ºMaxWin™¼¼Êõ£»´øÓÐSide Chain Filter¹¦ÄÜ£»·Å´óÀàÐÍ£º·ÖÁ¢Ê½AÀà·Å´ó£»ÆµÂÊÏìÓ¦: 20Hz to 20kHz(¡À0.5dB), @1kHz£»±¾µ×Ôë: <-90dBu @0dB Êä³öÔöÒæ£»ÊäÈë½Ó²å¿ÚÀàÐÍ£º XLRĸͷ, ƽºâʽ¡£ÊäÈë×迹: 10K Ohms £»Êä³ö½Ó²å¿ÚÀàÐÍ£º XLR¿¨Å©¹«Í·Æ½ºâÊä³ö£»Êä³ö×迹: 600 Ohms£»Êä³öñîºÏÀàÐÍ£º±äѹÆ÷£¨¶¨ÖÆ£©£»×î´óÊä³öµçƽ: +27 dBu£»ÄÚ²¿²àÁ´Â˲¨ÆµÂÊ·¶Î§£º 55Hz to 340 Hz@18dB/oct£»ÊäÈëµçƽ¿ØÖÆ£º -¡Þ to 0dB£»Ñ¹ËõÆ÷¹Õµã£º Hard Knee/Soft Knee Ç°Ãæ°å¿ª¹ØÑ¡Ôñ£»ÃÅÏÞ·¶Î§: +20dBV to -40dBV£»Ñ¹Ëõ±È: 1:1 to ¡Þ£»Æô¶¯Ê±¼ä: £¨fast£©0.1ms to 165ms£¨Slow£©£»ÊÍ·Åʱ¼ä: £¨fast£©2ms to 2s£¨Slow£©£»Êä³öÔöÒæ: ¡À20dB£»ÅÔͨ£º¶ÏµçֱͨʽÉè¼Æ£¬0Ⱦɫ,¿ª»úǰ°´ÏÂÅÔͨ¿ª¹Ø¿ÉÍêÈ«±ÜÃâµçÁ÷³å»÷ÊäÈëºÍÊä³öÐźţ» LED GR ָʾµÆ¡£¹¦ºÄ: £¼10Watt£¬
ÍâÐγߴ磺±ê×¼1U»ú¼Üʽ£¨¿í: 483mm£¬¸ß: 44mm£©¡£ | ̨ | 1 |
| 10 | ¾ùºâÆ÷ | bblaudio BEX | ͨµÀÊý£ºÁ¢ÌåÉù£»¾ùºâÆ÷Ƶ¶Î£ºÈýƵ¶Î²ÎÁ¿Ê½£»ºËÐļ¼Êõ£ººã¶¨QÖµ¼¼Êõ£»·Å´óÀàÐÍ£º·ÖÁ¢Ê½AÀà·Å´ó£»ÆµÂÊÏìÓ¦: 20Hz to 20kHz(¡À0.5dB), @1kHz£»±¾µ×Ôë: <-90dBu @0dB Out Gain£»ÊäÈë½Ó²å¿ÚÀàÐÍ£º XLRĸͷ, ƽºâʽ£»ÊäÈë×迹: 10K Ohms£»Êä³ö½Ó²å¿ÚÀàÐÍ£º XLR¿¨Å©¹«Í·Æ½ºâÊä³ö£»Êä³ö×迹: 600 Ohms£»Êä³öñîºÏÀàÐÍ£º±äѹÆ÷£¨¶¨ÖÆ£©£»Êä³ö±äѹÆ÷¼¼Êõ: ÆÂĪºÏ½ð±äѹÆ÷(¶¨ÖÆ£©£»×î´óÊä³öµçƽ: +27 dBu£»µÍÇУº 50Hz @12dB/oct£»µÍƵ LF: ÔöÒæ·¶Î§ ¡À9dB; ɨƵ·¶Î§: 50Hz to 620Hz Q=0.707;¸é¼Üʽ£»ÖÐÆµ MF: ÔöÒæ·¶Î§ ¡À12dB, ɨƵ·¶Î§65Hz£» to1kHz/650Hz to 10kHz @x10±¶Æµ³Ì¿ª¹Ø;Q:10 to 0.5;²ÎÁ¿Ê½£»¸ßƵ MF: ÔöÒæ·¶Î§¡À9dB;ɨƵ·¶Î§: 1.3kHz to 20kHz; Q=0.707;¸é¼Üʽ£»Êä³öµçƽ¿ØÖÆ: -¡Þ to 0dB£»ÅÔͨ£º¶ÏµçֱͨʽÉè¼Æ£¬¹¦ºÄ: £¼10W£»ÍâÐγߴ磺±ê×¼1U»ú¼Üʽ¡£ | ̨ | 1 |
| 11 | Ч¹û¿¨ | UA UAD-2 | À×µçËĺËЧ¹û¿¨£»²ÉÓÃSHARC 21396ÔËËãоƬ£»ËÄоƬ¿¨quad£»
Ö§³ÖAU/VST²å¼þ¸ñʽ£»LiveTrack³¬µÍÑÓ³Ù¼àÌýģʽ£º²»¾¹ýËÞÖ÷»º´æ£¬Ö±½Óʵʱ´¦Àí£¬ÑÓ³Ù¸üµÍ£»×¨ÎªÏÖ³¡ÓÅ»¯µÄL.O.D.E£¨Live Optimizing DSP Engine£©DSPÒýÇæ£¬×Ô¶¯DSP¸ºÔØÆ½ºâ£»¿ÉÓëUAD-1»ì²å£¬×î¸ß¾«¶È24bit/192kHz£»Ö§³ÖWindows XP/VistaºÍMac OS Tiger/Leopard¡£ | ̨ | 1 |
| 12 | ¼àÌý¿ØÖÆÆ÷ | SM Pro Audio ACTIVE-1 | 3×éÄ£ÄâÊäÈ룻3×éÄ£ÄâÊä³ö(ÅäÓÐרÃÅ»ìÈë¶Ô½²µÄ¼ÒôÊÒ¼àÌýÊä³ö)USBÊäÈ룻2¸ö¶ú»ú·Å´ó¿Ṳ́°å¿ØÖƶԽ²ÄÚÖöԽ²»°Í²£»µ¥ÉùµÀ¼æÈݼӺͰ´Å¥£»DimË¥¼õ°´Å¥£»¼àÌýÑïÉùÆ÷Çл»£»¾«È·µÄÖ÷ÒôÁ¿ÐýÅ¥£»µçƽ±í¡£³§¼ÒÌṩÈýÄêÊÛºó¼¼ÊõÖ§³Ö¡£ | ̨ | 1 |
| 13 | ¼àÌýÒôÏä | GARR AUDIO M60A | ÀàÐÍ£º2·ÖƵ£»µÍƵµ¥Ôª£º6´çKevlar×¶ÇúÄÍÈÈÒôƵµ¥Ôª¡¢¸ôÀë±£»¤£»¸ßƵµ¥Ôª£º1.25´ç´Å¸ôÀëµ¥Ôª£»¸ßƵ¼¼Êõ£ºM-AIR¸ßƵµ¥Ôª¼¼Êõ£»ÄÚÖù¦·Å¼¼Êõ£ºDSQ tech£»¿ØÖÆÑÓʱʱ¼ä£º0-4ms£»ÆµÏ췶Χ£º40 Hz ¨C 30kHz£»·ÖƵµã£º2.5 kHz£»µÍƵ¹¦ÂÊ£º70W£»¸ßƵ¹¦ÂÊ£º60W£»ÐÅÔë±È£º>100dB A¼ÓȨ£»ÊäÈë½Ó¿Ú£º1¿¨Å©¡¢1Èýо£»ÊäÈë×迹£º20 K¦¸ ƽºâ, 10 K¦¸ ·Çƽºâ£»ÊäÈëÁéÃô¶È£º85mV£¨90dBA 1 meter£©£»±£»¤£ºRF¸ÉÈÅ£¬Êä³öÏÞÖÆ£¬¹ýÔØ±£»¤£¬¿ª¹ØË²Ì¬µçÔ´±£»¤£¬Íⲿ±£ÏÕ£¬ÑÇÒôËÙÂ˲¨£»Ö¸Ê¾µÆ£º¿ª¹ØÖ¸Ê¾£»µçÔ´¹©¸ø£º15 V ~50/60 Hz, 230 V ~50/60 Hz, or 100 V ~50/60 Hz£»³ß´ç£º318 mm x 213 mm x 249 mm¡£³§¼ÒÌṩÈýÄêÊÛºó¼¼ÊõÖ§³Ö¡£ | Ö» | 2 |
| 14 | ¶ú»ú·Å´óÆ÷ | SM Pro Audio HP12E | 6¸öA¼¶¶ú»ú·Å´óÆ÷£»12¸ö´óÈýоTRS¶ú»úÊä³ö£»Æ½ºâXLRÊäÈë
ƽºâTRS´óÈýоÊäÈ룻ÿ¸öÊä³ö¶¼¿Éµ¥¶À¿ØÖÆÒôÁ¿£»Ã¿¸öÊä³ö¿É×öA/BÉùÔ´Çл»£»ÄÚÖñäѹÆ÷¡£³§¼ÒÌṩÈýÄêÊÛºó¼¼ÊõÖ§³Ö¡£ | ̨ | 1 |
| 15 | ¼àÌý¶ú»ú | AKG K271 MKII | ²åÍ·Ö±¾¶:3.5mm£»¶ú»úÊä³öÒôÔ´:ËæÉíÊÓÌý£»ÌײÍÀàÐÍ:ÌײͶþ£»ÀÂÏß³¤¶È:3Ã×£»¼àÌý¶ú»ú£¬²»´øÂó£¬Í·´÷»¤¶úʽ£¬ÓÐÏßÖ±²åÐÍ£»
ÊÇ·ñÏß¿Ø:·ñ£»×迹: 55¦¸£»ÆµÏ췶Χ: 16-28000Hz¡£ | ¸ö | 2 |
| 16 | ¼àÌý¶ú»ú | AKG k72 | ²åÍ·Ö±¾¶: 3.5mm/6.3mm£»¶ú»úÊä³öÒôÔ´: HiFi£»ÌײÍÀàÐÍ:¹Ù·½±êÅ䣻ÀÂÏß³¤¶È:3m£»¶ú»úÀà±ð: HIFI¶ú»ú£¬¼àÌý¶ú»ú£»:²»´øÂó£»Í·´÷»¤¶úʽ£»¶ú»úÀàÐÍ:ÓÐÏߣ»¶ú»ú²åÍ·ÀàÐÍ:Ö±²åÐÍ£»ÊÇ·ñÏß¿Ø:·ñ£»ÊÊÓÃÒôÀÖÀàÐÍ:ÇåÐÂÆ÷ÀÖС±àÖÆÀàÐÍ£»×迹:32¦¸£»ÁéÃô¶È:112dB/mW£»ÆµÏ췶Χ:16-20000 Hz¡£ | ¸ö | 4 |
| 17 | ¼ÓÖØ»°Í²¼Ü | Decksaver HM-402 | ÊÖÎÕÊÔÉý½µ£¬·À»¬½ºµæ£¬½ðÊôÂÁƬ£¬³åѹ¸Ö°å£¬Õ¹¿ª¸ß206cm£¬ÕÛµþ¸ß107cm¡£ | ¸ö | 4 |
| 18 | ¼ÓÖØÒôÏä¼Ü | Decksaver HM-800 | ÊÊÅä¸÷¿î¼àÌýÒôÏ䣬֨20¹«½ï£¬³ÆÖØ100¹«½ï£¬¸ß96cm£¬´¿½ðÊô²ÄÖÊ£¬·½±ã×é×°¡£ | ¸ö | 2 |
| 19 | ¶ú·ÖÖ§¼Ü | Decksaver M305 | Ö§¼ÜÖ§³Å¸ËÖ±¾¶40mm£¬ÉìËõ¸ËÆß¿×µ÷½Ú£¬ÕûÌå¸ß¶È1060mm£¬×îµÍµ÷½Ú790mm£¬±ê×¼1U£¬µ×²¿ÓÐÂÖ×Ó·½±ãÒÆ¶¯¡£ | ¸ö | 1 |
| 20 | ¹¤×÷̨ | Decksaver CN1800 | ÒôƵ¹¤×÷ÊÒרÓ㬱íÃæ·À¾²µç£¬¿¹¸¯Ê´£¬ÅçËÜ£¬Á½²àľ°å×°ÊΣ¬ºóÃæÔö¼ÓÉ¢Èȿգ¬Á½²à±ê×¼19Ó¢³ß»ú¼Ü£¬¸ß75cm£¬Éî100cm£¬¿í2400cm£¬È«²¿²É×÷ÓÅÖÊÀäÔþ¸Ö°å£¬×°Êβ¿·Ö²ÄÁÏΪÓÅÖʽø¿Ú¸ßÃܶȰ塣 | ̨ | 1 |
| 21 | Æ×¼Ü | Decksaver EX-1 | ×èÄáÉèÖã¬×ÔËøÉý½µ£¬¸ß¶È·¶Î§1050mm-1600mm£¬Æ×̾̾»ý510mm-320mm£¬ºÚÉ«¡£ | ¸ö | 2 |
| 22 | Ïß²Ä | | ÓÅÖÊÈýоÍÏߣ¬×¨ÒµÒôƵÉ豸Á¬½ÓÏß | Åú | 1 |
| 23 | ɳ·¢²è¼¸ | | ³ß´ç£º1100*880*880£¬²ÄÖÊ£ºÆ¤ÖÊ£¬ÄÚ²¿£º¸ß»Øµ¯º£Ã࣬ËÉľµ××ù£¬Ìúɼľ¿ò¼Ü¡£ ¿¿±³£ºÌùºÏ±³²¿ÇúÏߣ¬ÄÚ²¿¸ß»Øµ¯º£Ã࣬¿¿¸ÐÊæÊÊ¡£·öÊÖ£º¼Ó¿í·öÊÖÉè¼Æ£¬ÊæÊÊÃÀ¹Û¡£É³·¢½Å£ºËÉľ´òÔìɳ·¢½Å£¬²»Ò×±äÐΣ¬·À³±£¬ÎȹÌÄÍÓá£Ï¸½Ú:¾ùÔȹ¤Õû³µ·ì×ßÏߣ¬Ë«Õë×ßÏߣ¬ÔúʵÄÍÓᣠ| Ì× | 1 |
| 24 | °²×°µ÷ÊÔ | | ËùÓÐÉ豸µÄ°²×°¡¢µ÷ÊÔ£¬²¢¶ÔʹÓÃÈËÔ±½øÐÐרҵ¡¢ÏµÍ³Åàѵ¡£ | Ïî | 1 |
