רҵ½ÌѧÉ豸¡¢Â¼ÒôÅïDAW¼ÒôÈí¼þ
¼ÒôÅï
Æ×¼ÜÑÕÉ«£ºÄ¥É°¿¾ÆáºÚ
Áé»î¶È£ºÖ÷¸Ë¿ÉÉìËõ£¬Æ×°å¿É·­×ªºÍÐýת
¸ß¶È£º105-160cm
Æ×̨³ß´ç£º³¤51cm,¿í33cm£¬µ×±ß¾¶Éî5.5cm
½Å³¤£º25cm
12Ö»
»°Í²¼Ü¸ß¶È£º65-110 cm (2.1'-3.6')б¸Ë³¤¶È£º45-80cm(1.47'-2.62')
ÖØÁ¿£º3.15 kg (6.94 lbs)
²ÄÖÊ£ºÌú
µ××ù£ºËÜÁÏ
12Ö§
·ÀÅçÕÖ¼Òô·ÀÅçÍø
°ü×°ÄÚº¬Ë«Íø£º½ðÊôÍø¼°ÄáÁúÍø
ºÚÉ«
8¸±
ÒôÏä¼Ü¿ÉÉý½µ£»
ÊʺÏ5~8´çÒôÏ䣻
4Ö»
·À³±ÏäÈÝÁ¿£º32L£»
¿ØÖÆ·½Ê½£ºµµÎ»µ÷½Ú
³ýʪ·¶Î§£º30%~70% RH
2̨
ÊÓÆµ¼ô¼­Èí¼þÖ§³ÖµÄÊÓÆµ¸ñʽ£º
SD¡ªPA25i, NTSC 30i£»
HD¡ª720p (50, 59.94, 60*), 1080i (50, 59.94, 60), 1080p (23.98, 24, 25, 29.97, 30, 50, 59.94, 60)
Ultra HD¡ª23.98p, 24p, 25p, 29.97p, 30p, 50p, 59.94p, 60p
4K¡ª23.98p, 24p, 25p, 29.97p, 30p, 50p, 59.94p, 60p
Ö§³ÖµÄÉ«²Ê¿Õ¼äΪYUV 4:2:2, RGB 444, Rec 709, BT 2021; 8-bitºÍ10-bitÉ«²Ê¾«¶È
ÒôƵ²ÉÑùÂÊΪ16 bitºÍ24 bit£¬32 kHz£¬44.1 kHzºÍ48 kHz£¨µçÊÓ±ê×¼£©
Ö§³ÖÊÓÆµºóÆÚµÄ²É¼¯¡¢¹ÜÀí¡¢±à¼­ºÍ½»¸¶£¬Ã½ÌåÄÚÈÝ·Ö±æÂÊ¿ÉÖ§³Ö2K£¬4K£¬UltraHDµ½8K
Ö§³ÖÈκηֱæÂÊýÌåÖ±½Ó»ìºÏ¹¤×÷£¬´ÓSDµ½8K³¬¸ßÇåýÌåÎļþ
¶ÔÓڸ߷ֱæÂÊýÌåËØ²Ä£¬Èí¼þÐë¾ß±¸DNxHR ±àÂëÆ÷ÒÔÊÊÓ¦¸÷ÖÖ²»Í¬µÄ·Ö±æÂÊ
Ö§³Ö±à¼­8KºÍ¸ü¸ß·Ö±æÂÊýÌå
Ö§³Ö2K/4KËØ²ÄýÌåÔ­Éú·Ö±æÂÊʵʱ¼àÊÓÔ¤ÀÀ
ʱ¼äÏßÒôƵ±à¼­ÖÁÉÙÖ§³Ö64¹ì£¬Ã¿¹ìÒôƵ¾ßÓÐÔöÒæ×Ô¶¯µ÷½Ú
30Ì×
ÒôƵ¼ô¼­Èí¼þ¹¤Òµ±ê×¼µÄÊý×ÖÒôƵ¹¤×÷Õ¾Èí¼þ
ͬ²½·¢Òô/¹ìµÀ (48 kHz/96 kHz/192 kHz) ²»Ð¡ÓÚ128/64/32
×î¶àÊäÈëÊý²»Ð¡ÓÚ32
Ö§³Ö²»ÉÙÓÚ128¸¨ÖúÊäÈë
Ö§³Ö²»ÉÙÓÚ512ÀÖÆ÷Òô¹ì¡¢1024 MIDIÒô¹ì
Ö§³ÖµÄ×î´ó²ÉÑùÂÊΪ32 룬192 kHz
Ö§³Ö×Ô¶¯²å¼þÑÓ³Ù²¹³¥¡¢·ÇÆÆ»µÐԱ༭¡¢×·ËÝʽ MIDI ¼Òô¡¢Sibelius ÀÖÆ×±à¼­Æ÷¡¢Ñ­»·Â¼Òô¹ìµÀºÏ²¢µÈ¹¦ÄÜ
¿É×Ô¶¯µ÷ÕûÒôÁ¿¡¢ÉùÏñ¡¢·¢Ëͼþ¡¢¶À×à¡¢¾²Òô¡¢²å¼þ²ÎÊýµÈµÈ
Ö§³ÖµÄÊÓÆµ¹ìµÀΪ1ͨµÀ
30Ì×
רҵÒôƵ½Ó¿Ú ×ÀÃæÊ½USB3.0½Ó¿Ú
 ¾ß±¸²»ÉÙÓÚ2¸öÂó¿Ë·ç/Ïß·ǰÖ÷ŴóÆ÷
 ¾ß±¸²»ÉÙÓÚ2¸ö¶ÀÁ¢µÄ¶ú»úÊä³ö
30Ì×
8´ç¼àÌýÒôÏä ×î´óÉùѹ¼¶²»Ð¡ÓÚ110dB
 ƵÂÊÏìÓ¦·¶Î§²»Ð¡ÓÚ32 Hz ¨C 25 kHz (-6 dB
 ƵÂÊÏìÓ¦¾«×¼¶È²»Ð¡ÓÚ¡À 1.5 dB(38 Hz ¨C 20 kHz)
 µ¥Ôª³ß´ç²»Ð¡ÓÚµÍÆµ 8 ´ç£¬¸ßƵ 1 ´ç
 ¹¦·Å¹¦Âʲ»Ð¡ÓÚµÍÆµ 150 W£¬¸ßƵ 120 W
 ÒôƵ½Ó¿ÚÀàÐÍΪ1 x XLR Ä£ÄâÊäÈë
2Ì×
¸ßÖ¡Âʹ̼þ¼¤»îÂëÖ§³ÖÅÄÉãÖ¡ÂÊÌáÉýµ½×î¸ß4K 2.39:1ģʽϵÄ120fps, 6K 3:2ģʽÏ嵀 60fps£¬ 4K 17:9ģʽÏÂΪ110fps£¬4K 4:3±ä¿íģʽÏÂΪ75fps¡£ÊÊÓÃÓÚ4KºÍ6KµÄÅÄÉã¼°ÖÆ×÷£¬6KµÄ50/60pÖÆ×÷ºÍ60pµÄ6K 3:2´óÊÓ½ÇVRÖÆ×÷¡£¸ßÖ¡ÂʾùÖ§³ÖX-OCN¸ñʽ£¬°üÀ¨ÔÚV3.0¹Ì¼þÖÐмӵÄX-OCN XT¸ñʽ¡£1Ì×
Ë«²å²Û SxS¶Á¿¨Æ÷SxS PRO+ ºÍ SxS-1 ´æ´¢¿¨¶ÁдÆ÷ÔÚ»ùÓÚ Windows µÄ PC ºÍ Macintosh ¼ÆËã»úÉϾù¿ÉÔËÐС£¸Ã×°ÖÃÌṩUSB 3.0 ½Ó¿Ú£¬Ö§³Ö¸ßËÙ´«ÊäÒôƵ/ÊÓÆµ²ÄÁÏ¡£2Ì×
