查看: 49731|回复: 0
[资讯] Klanghelm DC8C advanced compressor 压缩效果器插件
发表于 2021-6-15 12:25:42 | 显示全部楼层 |阅读模式
DC8C 是最灵活的压缩机之一。虽然使许多不同的压缩风格成为可能,但它的一般性质可以描述为:清晰、流畅、开放、独特。
设计 DC8C 时的主要目标是获得非常干净的压缩器动作,而不会出现不需要且通常几乎不可避免的伪影/失真。通过这种方式,当您想要避免着色时,您可以为要求最苛刻的母带制作会话实现几乎不可见的压缩。
如果您的目标是颜色,您可以在两种饱和度模型之间进行选择。
从光学式、峰值压缩、外部侧链、RMS 压缩、反馈、前馈压缩(以及介于两者之间的所有内容)到负比率、零延迟砖墙限制、从快速瞬态处理到平滑瞬态舍入 – 一切皆有可能.
DC8C、SDRR、VUMT 和 VUMT 豪华版的维护更新
2021 年 4 月 26 日,星期一,DC8C、SDRR、VUMT 和 VUMT 豪华版的
小错误修复和改进。
DC8C is one of the most flexible compressors around.
While making a lot of different compression styles possible, it’s general nature may be described as: clear, smooth, open, distinct.
The main goal while designing DC8C was to get a very clean compressor action without unwanted and often almost inevitable artifacts/distortion. This way you can achieve almost invisible compression for your most demanding mastering sessions, when you want to avoid coloration.
If you aim for color you can choose between two saturation models.
From opto-style, peak compression, external side-chaining, RMS compression, Feedback, Feedforward compression (and everything in-between) to negative ratios, zero latency brick-wall limiting, from snappy transient treatment to smooth transient rounding – everything is possible.
Maintenance updates for DC8C, SDRR, VUMT and VUMT deluxe
Monday, April 26, 2021
Minor bug fixes and improvements for DC8C, SDRR, VUMT and VUMT deluxe.
https://plugincrack.com/plugins/klanghelm-dc8c-3-win-mac/
https://www.4download.net/837-klanghelm-dc8c-full-version.html
GMT+8, 2025-7-16 14:03 , Processed in 0.026429 second(s), 9 queries , Redis On.
