DJÖÆ×÷»ìÒôÈí¼þ ¨C PCDJ DEX Pro 3.16.0.0 MacOS
7924230
2021-6-4 13:34:37
Èí¼þ
8 t* j. ]- {$ c  G: I
( b6 B, s! w$ r( H- H; Z ! E' S) J( D, z; M- U. P
Ò»¿îDJÖÆ×÷Èí¼þ£¬¿ÉÒÔÈÃÓû§ÇáËɵĻìºÏÒô¹ì£¬ÓкÜÈ«ÃæµÄÒôÀֿ⣬¿ÉÒÔ×Ô¼ºÖÆ×÷¸èÇú£¬ÓÐ90¶à¸ö¼æÈݵÄDJ¿ØÖÆÆ÷£¬ÄÚÖÃЧ¹ûºÍʾÀý²¥·ÅÆ÷£¬ÊÇÒ»¿î·Ç³£×¨ÒµµÄDJ»ìÒôÈí¼þ¡£1 G0 L/ O5 y; X6 I4 |
- C7 Q4 T* q7 f8 EFile size: 119.56 MB3 L; C- P4 @( D- R2 ?1 l0 N8 A) S
7 V8 F, M( K, t' x
DEX 3 is professional DJ Software for MAC and Windows that allows you to go far beyond simple DJing. The most versatile do-it-all DJ software available, DEX 3 enables you to intuitively mix music, music videos and host karaoke with precision. Why settle for a product that has only one function or use multiple products? DEX 3 is the only DJ software with all the features you require to make any every gig a total success.
" ^  ~3 |# P) b5 w: |7 }; s PCDJ-DEX-3.16.0.0-MacOS.png 4 R  \) W8 O/ G7 G, X
With our beat-grid based automatic beat mixing and key detection it¡¯s easy to blend tracks, allowing you to focus on the other aspects of your mix. Your audience will enjoy superior sound quality made possible by DEX 3¡¯s industry-leading custom sound engine whether your mixing live or using automix.- ?. |  u% h- U$ `1 y
( ]+ y, h% E3 h% Z5 M, ^Since DEX 3 offers no-latency playback and support for today¡¯s hottest DJ controllers; loops, hot cues, and all playback features are ultra-responsive. DEX 3 allows you to create mixes from your own music and music video library and/or iTunes using just a keyboard or mouse, or one of the 100+ supported DJ controllers.; e3 L/ b$ q, V: g
  ~2 \+ q8 b- j/ K8 Z5 Z8 h% ]Supported Operation System:5 I* a( E; I1 j6 H
• 64-bit processor* @. N( o. K6 p4 B- P0 @! Z
• macOS 10.14 or later
