¡°½³ÐĶÀ¾ß¡±Robert Koda Takumi K-160µ¥ÉùµÀºó¼¶
É豸
µ¥´ÓÃæ°åÉÏ¡¸½³ÐÄ¡¹¶þ×ÖÄú¿ÉÄÜÒѾ­²Âµ½ÁË£¬ÕâÊÇÀ´×ÔÈÕ±¾µÄÒôÏìÆ·ÅÆ£­Robert Koda£¬²»¹ý´´Á¢ÕßRobert KochÈ´ÊÇһ볤Äê¾ÓסÔÚÈÕ±¾ÄÏ·ÇÈË£¬ÔçÄêÔø¾­ÈÎÖ°ÓÚÓ¢¹úAudio NoteÓëÈÕ±¾Kondo£¬ºóÀ´²Å´´Á¢ÁËÊôÓÚ×Ô¼ºµÄÒôÏìÆ·ÅÆ¡£È»¶øÕâ´ÎÒª½éÉܵÄÊǼÌK-70Ö®ºó¸ü¸ß½×µÄK-160£¬Ô­³§Óá¸The most ultimate power amplifier¡¹À´ÐÎÈÝÕâ¿îµ¥ÉùµÀºó¼¶·Å´óÆ÷¡£
ÓбðÓÚ×Ô¼ÒK-70µÄÕæ¿Õ¹ÜÉè¼Æ£¬K-160¸Ä²ÉÓÃÈ«¾§ÌåÖÆ×÷£¬ÔÚ8Å·Ä·¸ºÔØÊ±£¬¿ÉÌṩÿÉùµÀ150ÍßÊä³ö¹¦ÂÊ¡£·Å´ó¼¶²ÉÓöþ¼¶·Å´óÉè¼Æ£¬Ê×ÏÈ£¬µÚÒ»¼¶½øÐеçѹÔöÒæ26dB£¬µÚ¶þ¼¶½øÐеçÁ÷ÔöÒæ£¬Á½Õ߸÷×Ô¶ÀÁ¢ÔË×÷¡£µÚÒ»½×¶Î²ÉÓøߵçѹ£¨160V£©£¬Ä¿µÄÊÇÒª¼ò»¯Ïß·²¢ÇÒ×ÔÈ»µØ¼õÉÙÊ§ÕæÓëÔëѶ¡£ÄÚ²¿²ÉÓÃÁ㸺·´À¡Éè¼Æ£¬Ê§Õæ±»ÏÞÖÆÔÚ¿ÉÌý¼ûµÄ·¶Î§Ö®Ï£¬²»ÐèÒªÈκδíÎóУÕý¡£
´ËÍ⣬ԭ³§Ìáµ½£¬K-160ʹÓõÄÊǵ翹µçÔ´£¨Reactor power supply£©£¬Ïà½Ï֮ϱäѹÆ÷µÄ·¢ÈÈÁ¿½ÏÉÙ£¬Òò´Ë¿ÉÌáÉýʹÓÃЧÂÊ£¬Ò²±ÜÃâ´óÐͱäѹÆ÷¿ÉÄܲúÉúÔëѶ¸ÉÈŵÄÎÊÌâ¡£ÔÙÕߣ¬¿ÉÒÔ½µµÍÖ±Á÷Êä³öʱµÄÁ°²¨£¨ripple£©ÏÖÏ󣬯½¾ù¿ÉÒÔ½µµÍ12dB£¬Èç¹ûÊÇÔÚ½Ï¸ßµÄÆµÂÊʱ¿É½øÒ»²½½µµÍ10dB¡£Ò²ÒòΪÈç´Ë£¬Á÷¾­ÕûÁ÷Æ÷ºÍÂ˲¨µçÈݵÄÁ°²¨½µµÍÁË´óÔ¼Áù±¶£¬±ÜÃâÒòµçÁ÷²úÉú¸ßÎÂÓ°ÏìµçÈÝÊÙÃüÎÊÌ⣬µÈͬÓÚÑÓ³¤Â˲¨µçÈݵÄʹÓÃÊÙÃü¡£
ÔÚ×é×°·½Ã棬ԭ³§Ç¿µ÷ÿһ̨K-160¶¼ÊÇÓÉÉè¼ÆÊ¦´ÓÍ·µ½Î²Ç×Á¦Ç×Ϊ£¬°üÀ¨Ã¿Ò»¸öµç·°å¡¢ÊÖ¹¤½ÓÏß¡¢Ã¿Ò»¸öº¸µãÇå½à£¬¶øÇÒ¾­¹ýÒ»´ÎÓÖÒ»´ÎµÄ¼ì²é£¬ËùʹÓõÄÔª¼þÒ²¾­¹ýÔ¤ÏÈÌôÑ¡ÓëÆ¥Åä¡£
Æ÷²Ä²ÎÊý
ÐÍʽ£ºµ¥ÉùµÀºó¼¶·Å´óÆ÷
Êä³ö¹¦ÂÊ£º
150W / 8 ohm @ less than 1% THD (any mode)
230W / 8 ohm @ less than 1% THD (high power mode)
120W / 8 ohm @ less than 1% THD (high power mode)
ѶÔë±È£º
105.5dB (A weight) @ 1W into 8 ohms
125.5dB at 100W into 8 ohms
Ê§Õæ£º
0.0009% at 5 watts into 8 ohm, 1KHz
0.005% at 50 watts into 8 ohm, 1KHz
ÏûºÄ¹¦ÂÊ£º
550W at all times (high power mode)
400W at all times (normal mode)
Êä³ö×迹£º0.05 ohms at 1KHz (damping factor is 160)
ÊäÈë×迹£º´óÓÚ10K ohms (SE, balanced or floating)
µçѹÔöÒæ£º26dB
ÖØÁ¿£º45kg£¨unpacked per unit£©
ÆÀÂÛÁÐ±í£¨1£©
·ÖÏí£¬Ð»Ð»·¢²¼
2021-5-5 21:21:27 »Ø¸´
