Soundlib G-Player GIGA²ÉÑùÆ÷
3529892
2021-4-11 18:30:14
ÎÞÐèת»»¡£ G-PlayerÊDZ¾»úGigastudioÎļþ²¥·ÅÆ÷£¬Ö¼ÔÚ²¥·ÅÐèÒª´ÅÅÌÁ÷´«ÊäµÄ´óÐÍ´æ´¢¿â¡£ G-PlayerÔÊÐíÄú¿ìËÙÐÞ¸ÄijЩ³ÌÐò²ÎÊý£¨ADSR£¬VCA£¬VCF ¡­£©£¬¶øÎÞÐè±à¼­ºÍ±£´ægigaÎļþ¡£
ÎÞÐèת»»
²»ÓÃËæ»ú½á¹û¾Í¿ÉÒÔ½øÐÐת»»ºÍµ¼Èë¡£½Úʡʱ¼äºÍ´ÅÅ̿ռ䡣 G-PlayerÎÞÐèÈκÎת»»¼´¿É²¥·ÅËùÓÐGigastudio™ÉùÒô¿â¡£ G-PlayerÖ¼ÔÚ²¥·Å´óÐ͹ÜÏÒÀÖ¶ÓµÄÉùÒô¿â£¬²¢Ö§³Ö´ÅÅÌÁ÷£¬³ß´ç£¬¼ü¿ª¹ØºÍ·Ö²ãÀÖÆ÷¡£
ÃÔʧÔÚ·­ÒëÖÐ
ÔÚGigastudio™ÎļþÖУ¬Ã¿¸öÑù±¾ÇøÓò¶¼ÓÐÆä×Ô¼ºµÄ°üÂçºÍ²ÎÊý£¬µ±Îļþת»»ÎªÁíÒ»ÖÖÐèÒª¶Ô¾ßÓÐÏàËÆ²ÎÊýµÄÇøÓò½øÐзÖ×éµÄ²ÉÑùÆ÷¸ñʽʱ£¬Í¨³£»á¶ªÊ§ÕâЩÐÅ·âºÍ²ÎÊý¡£²»ÊÊÓÃÓÚG-Player¡£ G-PlayerÒÔ×î¼Ñϸ½Ú²¥·ÅËùÓÐÑù±¾¡£
×î¼ÑGigastudio™²¥·ÅÆ÷
´´½¨G-PlayerÊÇΪÁ˾¡¿ÉÄÜÄ£ÄâGigastudio™ÉùÒô¡£µ±ÆäËû²ÉÑùÆ÷Ö»ÄܸÄÉÆÆäGigastudio™Îļþµ¼Èëʱ£¬ÎÒÃǽ«Ö±½ÓÔÚÒôƵÒýÇæÉϹ¤×÷£¬Ö±µ½»ñµÃÀíÏëµÄ½á¹û¡£ÀýÈ磬G-PlayerÊÇΨһģÄâGigastudio™3ÌõËÙ¶ÈÇúÏߣ¨ÏßÐÔ£¬·ÇÏßÐÔºÍÌØÊ⣩µÄ²ÉÑùÆ÷¡£
±íÏÖ
G-PlayerÕë¶ÔGigastudio™¸ñʽ½øÐÐÁËÓÅ»¯£¬ÔÚÄÚ´æºÍCPUʹÓ÷½Ãæ·Ç³£¸ßЧ¡£ G-Player¿ÉÒÔ²¥·ÅºÍÁ÷¾­Ñ¹ËõºÍ¼ÓËÙµÄÑù±¾£¬ÓëÆäËûÈκλùÓÚת»»µÄ½â¾ö·½°¸Ïà±È£¬ÆäÓ²Å̻¸üÉÙ¡£
ÇáËɱ༭
×î³£ÓõÄÑù±¾²ÎÊý¿ÉÔÚÖ÷´°¿ÚÖÐÖ±½Ó·ÃÎÊ¡£ÀýÈ磬Äú¿ÉÒÔÖ»ÓÃÒ»¸öÐýÅ¥¾Í¿ÉÒÔ¼õÉÙ»òÔö¼ÓËùÓÐÑùÆ·µÄÊÍ·Åʱ¼ä¡£
¶à²ã½»²æµ­Èëµ­³ö
G-Player¿ÉÒÔÑÝ×à¶à´ï8²ã½»²æµ­Èëµ­³öµÄ·Ö²ãÀÖÆ÷¡£Ã¿¸öͼ²ãµÄ½»²æµ­Èëµ­³öÓÉ4¸öµã¶¨Ò壬ÕâЩµã¾«È·È·¶¨µ­ÈëºÍµ­³ö¶Î¡£×ʢÃûµÄGigastudio™ÉùÒô¿âʹÓÃÁ˴˹¦ÄÜ£¬G-Player±¾ÉíÖ§³Ö´Ë¹¦ÄÜ¡£
Soundlib G-Player v2.0.1£¨Win / Mac OS X£©
¸ÅÊö
•ÎÞÐèת»»
•²»ÐèÒªGSIFÉù¿¨
•ÔÚMac OSX 10.4ºÍ¸ü¸ß°æ±¾ÉÏÔËÐÐ
•ÔÚWindows XP£¬VistaºÍ7£¨32λºÍ64룩ÉÏÔËÐÐ
•µ¥»ú°æ
•Mac OS XÉϵIJå¼þ°æ±¾£ºVST£¬AudioUnitºÍRTAS
•WindowsÉϵIJå¼þ°æ±¾£ºVST
•ÄÚ´æºÍCPUЧÂʸß
•¼òµ¥µÄ²ÎÊý±à¼­
•ÔÚGigastudio™Îļþä¯ÀÀÆ÷Öй¹½¨
•×îϲ»¶µÄ²Ëµ¥´´½¨£¬¿ÉÒÔ¸ü¿ìµØ·ÃÎÊÎļþ
•¶Ñ·Åģʽ
•°üÀ¨G-Solo²å¼þ
No conversion required. G-Player is a native Gigastudio file player designed to play the large banks that require disk streaming. G-Player allows you to quickly modify some program parameters (ADSR, VCA, VCF¡­) without having to edit and save the giga file.
Forget converting and importing with random results. Save time and disk space. G-Player plays all your Gigastudio™ sound libraries without any conversion. G-Player was designed to play the large orchestral sound libraries and supports disk streaming, dimensions, keyswitches and layered instruments.
Lost in translation
In a Gigastudio™ file, every sample zone has its own envelopes and parameters, this is usually lost when the file is converted to another sampler format that needs to group zones with similar parameters. Not with G-Player. G-Player plays all the samples with the finest level of detail.
Best Gigastudio™ player
G-Player was created to emulate the Gigastudio™ sound as close as possible. When other samplers can only improve their Gigastudio™ file import, we work directly on the audio engine until we get a perfect result. For example, G-Player is the only sampler that emulates the 3 velocity curves of Gigastudio™ (linear, non-linear and special).
Performance
G-Player is optimized for the Gigastudio™ format and is very efficient in memory and CPU usage. G-Player can play and stream the compressed and accelerated samples which results in less hard disk activity than any another conversion based solution.
Easy editing
The most commonly used sample parameters are directly accessible on the main window. For example, you can decrease or increase the release time of all the samples with just one knob.
Multi-Layer crossfade
G-Player can play layered instruments with up to 8 layers of crossfade. Each layer¡¯s crossfade is defined by 4 points which precisely determine the fade in and fade out segments. This feature is used by the most prestigious Gigastudio™ sound libraries and is natively supported by G-Player.
Overview
• No conversion required
• Does not require a GSIF audio card
• Runs on Mac OSX 10.4 and later
• Runs on Windows XP, Vista and 7 (32 and 64 bits)
• Stand-alone version
• Plug-in version on Mac OS X : VST, AudioUnit and RTAS
• Plug-in version on Windows : VST
• Memory and CPU efficient
• Easy parameter editing
• Buit in Gigastudio™ file browser
• Favorite menu creation for faster file access
• Stacking mode
• Includes the G-Solo plug-in
https://open.keijuhiwansupp.tk/
