Steinberg Cubase 11 PRO v11.0.10 Full version
5708005
2021-3-21 15:33:31
ÎÊÌâ
Category:Software / Windows / Audio Tools / DAW
Do you want to start creating your own music, bring your production up to a professional level, or streamline your workflow for short deadlines? Whatever you need, Cubase helps you to reach your full creative potential. From Hollywood blockbuster composers and Billboard Hot 100 producers right through to keen beginners, the world of music production trusts the comprehensive feature set, straightforward tools and unrivaled sound of our acclaimed music production software.
The reference standard for music production software
Produce tracks from start to finish
Suitable for all genres, levels and budgets
Fast, flexible and intuitive workflows
Cubase 11 comes with a vast range of workflow and performance improvements, as well as exciting new ways to find inspiration and improve your productions. No matter what your musical goals are, Cubase 11 will help you to reach them.
Simpler Stems
In most DAWs, printing stems is a repetitive and time-consuming task. Cubase Pro 11 makes this job much faster, less prone to errors and way more convenient. Sync your export selection to the selection in your project. Create and restore file format presets. Export the full signal path, including master bus effects, to truly replicate the mix. Cubase Pro 11 even lets you collect your export jobs and export the whole queue in one go while you grab a coffee.
Sample. Slice. Move. Glide.
The Sampler Track in Cubase 11 has a number of great new features to discover. The new slicing mode chops up your loops so they¡¯re ready to play with just a click. There are now two global LFOs available to add motion and a catch to your sounds. You can go for a vintage feel or the highest fidelity with the sample engine¡¯s new quality modes. Then there¡¯s the new mono legato glide, perfect for riding 808 basslines¡­ and more!
Your Personal Scale Assistant
The Scale Assistant is a superb addition to your songwriting toolkit. You can set your song¡¯s scale in the Key Editor and follow its lead, quantize a solo to the scale or play live in perfect tune. You can change the view to only see the notes of the set scale. You can even let the Scale Assistant analyze your MIDI recording and suggest the right scale. Now there are no more excuses for wrong notes!
Perfect Bends
Cubase 11 brings a huge improvement to the Key Editor¡¯s functionality. You can now create ramps and curves in the CC and Pitch Bend lanes, just like you are used to with automation. Set your pitch bend steps to semitones and you will always be perfectly in tune. All of your CC edits can also be conveniently copied to another MIDI track, while MIDI notes can now be deleted with a simple, fast double-click.
Amazingly Precise Dynamic EQ
There are many reasons why you should use dynamic equalization to get a better mix and, with Frequency 2, there are now no reasons why you shouldn¡¯t. Each of its eight bands can be individually set to dynamic mode, making the filter node dependent on the input signal for amazingly precise dynamic mixing. And, even better, Cubase 11 allows you to set a different side-chain for each band by making use of the multiple side-chain architecture of VST 3.
Enhanced Synchronization
Staying in sync with tempo changes or markers is crucial when composing any kind of music. Cubase 11 makes your life easier with Global Tracks now able to be displayed in the Key Editor. With no need to leave the Key Editor anymore, this great visual reference will keep your compositions moving along quickly and creatively.
Enhance EDM with Squasher
Electronic dance music productions need Squasher! This dynamic tool combines up and down compression for up to three bands, making it super flexible in many situations. Use it to help your lead sounds cut through the mix, tame aggressive bass lines or enhance subtle, spacey reverberation. Squasher is amazingly easy to use and it sounds fantastic.
New Score Editor Features and Fonts
The Score Editor was enhanced with lots of great additions and improvements. The new Properties tab lets you instantly access the matching options and settings of your notation and, with the Note Editing Overlay, you can edit notes as conveniently as in the Key Editor. There are more workflow improvements, and the Score Editor now also supports the SMuFL font format, which will bring Dorico¡¯s beautiful Bravura and Petaluma fonts to Cubase.
Imager
The multiband Imager is another great tool that will help you to get a better, cleaner mix. You can place audio tracks in the stereo field independently in up to four bands, allowing you to expand or reduce the stereo width of your sound. The individual scope and correlation displays help you to get your panning absolutely perfect.
Visual Editing with SpectraLayers One
SpectraLayers One is a compact version of the acclaimed visual audio editing tool. SpectraLayers One allows you to visualize and clean up your audio with stunning results. But there is even more. Thanks to the state-of-the-art source separation engine, you can separate the vocal part from any kinds of audio tracks. Whether you want to remix your favorite song or create mash-ups, SpectraLayers One helps you to get started.
Super SuperVision
SuperVision is a fully customizable, multimeter audio analyzer for professional productions. You can choose out of several different modules for level, spectral, phase and waveform analysis, creating your own custom layout with up to nine module slots to give you a supremely accurate visual picture of your sound.
Inspiring New Sample Sets
Be inspired and instantly start producing with six new, exclusive sound and loop sets in Cubase 11. Grammy-winner Beat Butcha contributes a sizzling pack of hip hop heat. Go-to Hollywood sound designer Robert Dudzic brings the Noir pack for cinematic trailers, where every sound tells a story. And Black Octopus Sound ¡ª well known for their samples in many current productions ¡ª contributes four exclusive sets: Lo-fi hip hop, Dancefloor Tech House, Vocal lines and ¡¯80s Synth Wave.
Óοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë»Ø¸´
ÆÀÂÛÁÐ±í£¨38£©
6666666666666666666666666666666666666666666666666666666
2021-6-8 13:16:11 »Ø¸´
ÆÚ´ýÁËÐí¾Ã£¬ÖÕÓÚ¿´µ½È«ÐµÄ11°æ±¾ÁË¡£
2021-4-1 21:58:32 »Ø¸´
´ó¸ç£¬ÄúÕâÊÇÍâ¹úµØÖ·£¬Ï²»Á˰¡
2021-3-23 14:56:20 »Ø¸´
ѰÕÒÁ˺ܾã¬Ï£Íû»áÏÂÔØµ½°É
2021-3-23 14:53:43 »Ø¸´
·Ç³£¸Ðл1232
2021-3-25 12:32:27 »Ø¸´
лл·ÖÏí¡£Ñ§Ï°Ñ§Ï°¡£
2021-3-26 11:42:27 »Ø¸´
ÕâÊÇ·ÖÏíµÄÕý°æ×ÊÔ´Á´½ÓÂð£¿
2021-4-2 15:59:49 »Ø¸´
xiehuicure
cubase11.0.10ÊÇÈ«ÐÂÆÆ½âÂð
2021-4-3 07:49:34 »Ø¸´
2021-4-6 11:48:15 »Ø¸´
ºÃ¶«¶«£¬¿Éϧ²»ÊÇ MAC
2021-4-8 19:47:38 »Ø¸´
¸Ðл·ÖÏí£¬ÐÁ¿àÁË£¡
2021-4-10 10:35:58 »Ø¸´
²»ÖªÊÇʲô°æ±¾£¬ÏÈллÁË£¡
2021-4-11 22:07:29 »Ø¸´
Ï£Íû»áÏÂÔØµ½°É
2021-4-15 06:30:51 »Ø¸´
Ï£Íû»áÏÂÔØµ½°É
2021-6-8 14:55:16 »Ø¸´
lzdily2021
Õâ¸öÔõôÑù£¿
2021-6-8 19:30:31 »Ø¸´
лл·ÖÏí¡£Ñ§Ï°Ñ§Ï°¡£
2021-7-7 00:24:24 »Ø¸´
Ï£Íû»áÏÂÔØµ½°É
2021-7-25 08:57:45 »Ø¸´
Õâ¸öÓÐÎȶ¨PJ°æÂð£¿
2021-8-16 16:51:34 »Ø¸´
ÖÕÓÚÕÒµ½ÁË£¡Ï£ÍûÄÜÓã¡
2021-8-22 01:25:58 »Ø¸´
¸Ðл´óÀзÖÏí£¡£¡£¡
2021-8-22 22:54:06 »Ø¸´
66666Õæ°ôŶ
2021-10-3 13:32:49 »Ø¸´
¸Ðл¥Ö÷Ìṩ
2021-10-14 14:28:56 »Ø¸´
ÔٴθÐл·ÖÏí£¡
2021-10-21 16:29:03 »Ø¸´
лллл£¬ÏÈÊÔÊÔ¿´à¶
2021-10-25 14:55:19 »Ø¸´
Ö»ÄÜÕý°æKEYÓðɣ¿
2021-11-1 10:00:24 »Ø¸´
Â¥Ö÷ºÃÈË£¬¶àл·ÖÏí¡­¡­
2021-11-4 16:12:26 »Ø¸´
¸Ðл¥Ö÷µÄ·ÖÏí
2022-2-26 16:30:03 »Ø¸´
12ÏÂÒ»Ò³
