Leapwing Audio AlSchmitt 1.0.0 ÖÇÄÜ´¦Àí²å¼þ
ÎÒÃǷdz£×ÔºÀµØÐû²¼£¬ÎÒÃǵĵÚÒ»¸öÇ©Ãû²å¼þÊÇÓÉ´«ÆæµÄÉú²ú¹¤³ÌʦAl Schmitt¿ª·¢µÄ¡£ÎÒÃǵÄÍŶӷÖÎöÁËAl¹ýÈ¥¼¸Ê®ÄêµÄ¹¤×÷Á÷³Ì£¬³ÝÂֺ͹ý³Ì£¬´Ó΢ÃîµÄг²¨ÌØÕ÷µ½»ØÉù£¬Ñ¹ËõºÍEQ¡£
È»ºó£¬Õâµ¼ÖÂÎÒÃÇ´´Ôì³ö¶ÀÌØµÄÌØÕ÷À´¶¨ÒåËûµÄÉùÒô¡£ Al SchmittÇ©Ãû²å¼þ¾ßÓÐ6¸ö²»Í¬µÄÅäÖÃÎļþ£ºÈËÉù£¬¸ÖÇÙ£¬±´Ë¹£¬Í¹ÜÀÖÆ÷£¬ÇÙÏҺͻìÒô£¨×ÜÏߣ©¡£¸ù¾ÝAlµÄ¹¤×÷Á÷³ÌºÍ¶ÔÿÖÖÀÖÆ÷µÄÁ˽⣬ÿ¸öÈ˶¼Óв»Í¬µÄÉùÒôÌØÕ÷ºÍ²ÎÊý¡£¾«Á¶³É×îÉٵĿؼþ£¬²¢Ö¼ÔÚÈÃÄúÁ¢¼´»ñµÃÉùÒô
Ç©ÃûÉùÒô
ÔÚ·ÖÎöÁËÎÞÊýµÄ³ªÆ¬ÒÔ¼°AlµÄ¹¤×÷Á÷³ÌºÍ×°±¸Ö®ºó£¬ÎÒÃǽøÐÐÁ˾«ÐĵŤ×÷£¬ÒÔÔÙÏÖËûµÄÇ©ÃûÉùÒô¡£
6¸ö¶ÀÌØµÄ¸öÈË×ÊÁÏ
ÉùÀÖ£¬¸ÖÇÙ£¬±´Ë¹£¬Í¹ÜÀÖÆ÷£¬ÇÙÏҺͻìºÏ£¨×ÜÏߣ©ÅäÖÃÎļþ£¬Ã¿¸öÎļþ¾ùʹÓø÷×ԵIJÎÊý½øÐе¥¶Àµ÷Õû¡£
г²¨²úÉú
×Ðϸµ÷Õûг²¨Ê§Õ棬ÿ¸öÅäÖÃÎļþ¸÷²»Ïàͬ£¬ÒÔʹÆä¼¸ºõûÓжàÓàµÄ¡°Ä§Á¦¡±¡£
¾ßÓÐ×î¼Ñ¹¤×÷Á÷³ÌµÄÃÀÀöÉè¼Æ
¾«ÃÀµÄRetinaÉè¼Æ£¬ËùÓпؼþ¶¼ÔÚÒ»¸öÆÁÄ»ÉÏ¡£ÎÒÃÇÏ£ÍûÎÒÃǵÄÓû§ÔÚ¼¸ÃëÖÓÄÚ»ñµÃ½á¹û£¬¶ø²»»áʹUI»ìÂÒ¡£
ƽ̨£ºWiN64-VST / VST3 / AAX£¨ÒÑÐ޸ģ©
We are really proud to announce our first signature plugin, developed with none other than legendary producer-engineer Al Schmitt. Our team analyzed Al¡¯s workflow, gear and processes of the last decades, from subtle harmonic characteristics to echos, compression and EQ.
This then led us to create distinctive features that define his sound. The Al Schmitt signature plugin has 6 distinct profiles: vocal, piano, bass, brass, strings, and mix (bus). Each one has different sonic characteristics and parameters based on Al¡¯s workflow and perception of each instrument. Distilled to minimal controls, and conceived to allow you to get your sound instantly
SIGNATURE SOUND
Having analysed countless of records, as well as Al¡¯s workflow and gear, we worked meticulously to recreate his signature sound.
6 UNIQUE PROFILES
Vocal, piano, bass, brass, strings, and mix (bus) profile, each individually tuned with their own parameters.
HARMONIC GENERATION
Carefully tuned harmonic distortion, different per profile, to give it that little extra ¡®magic¡¯.
BEAUTIFUL DESIGN WITH OPTIMAL WORKFLOW
Beautiful Retina design with all controls on one screen. We want our users to get results within seconds without cluttering the UI.
PLATFORM: WiN64 ¨C VST/VST3/AAX(MODiFiED)
