ÃÀ¹úDWFearn VT-2»°Í²·Å´óÆ÷
coboy
2006-3-10 18:58:00
»°Í²
" I: y$ h5 w  J( i- u! W5 G; p; U6 R- t$ d1 D9 a
5_113_1714944_1000_391.jpg 7 c( K4 `7 W& I5 X# S9 Q9 d
ÔÚÉè¼ÆVTǰÖ÷ŴóÆ÷ʱ£¬²»ÔÊÐíÔÚÉùÒôÖÊÁ¿£¬¿É¿¿ÐÔ»ò¼á¹ÌÐÔ·½Ãæ×ö³öÈκÎÍ×Э¡£Óë20ÊÀ¼Í50Äê´úºÍ60Äê´úµÄµç×Ó¹ÜÉ豸һÑù£¬VTǰÖ÷ŴóÆ÷²ÉÓÃÖØÐÍÂÁÖÆ»úÏ䣬²ÉÓõã¶Ôµã²¼Ïß¡£Ñ¡Ôñÿ¸öÕæ¿Õ¹ÜÒÔ»ñµÃ***СµÄÔëÒôºÍ΢Òô£¬ÒÔ¼°µÄÉùÒôÇåÎú¶È¡£Ç°Ãæ°å¿ª¹Ø¿ØÖÆÃÜ·âµÄ½ð´¥µã¾«Ã̵ܼçÆ÷£¬ÓÃÓÚËùÓÐÒôƵÇл»£¬Ïû³ýÁËÔà½Ó´¥½µµÍÉùÒôºÍ***С»¯ÄÚ²¿ÒôƵ·¾¶µÄ¿ÉÄÜÐÔ¡£Ã¿¸öͨµÀÖеÄËĸöAÀàÈý¼«¹Ü·Å´óÆ÷²¿·Ö£¨ÔÚÁ½¸ö¹ÜÖУ©°üÀ¨Õû¸öÓÐÔ´µç·¡£Õâ¸öÁîÈ˾ªÑȵļòµ¥µç·£¬ÒÔ¼°¸ßÆ·ÖʵÄÔª¼þºÍ¾«ÐĵÄÉè¼ÆÓÅ»¯£¬´øÀ´ÁËVTǰÖ÷ŴóÆ÷µÄÉùÒôÓÅÊÆ¡£0 K! r, k( z2 Q5 P5 I: j' @( c
; P* z' `) B+ s4 Q" t& M
; w+ X. J% R& I  E
5_258_1651582_1000_625.jpg 2 T7 x  S$ W8 R) q: x! p% d* m
Features! l# k$ J8 {0 g
; B. \/ ?4 D- R9 h( k  ?; }" BAll vacuum-tube design* Y! ?0 Z- a8 ]  v# y2 U# d& D
: n1 m6 K) k( N
Lo-Z input position for superior performance with transformerless mics! V# G0 c  P1 D" E( K
4 G: x* ^5 ~& iPhase (polarity) reverse switch, ?  j1 _' K, X0 B
- {. B( O$ I3 j# @* w
+48 volt phantom power (completely disconnected when off)
' |  i8 I8 C6 ^# X( g% ~% I, W, Q& [# t) ^2 ]. e  O, x; G
Custom-design Jensen input and output transformers1 ?8 s6 @( q- |  e3 E
2 ?+ T! [6 k% Z9 @9 h9 V
20 dB input pad (switchable)0 T7 \& k, C. Z( g( Y, R1 w
# v7 {+ l% K9 CTrue VU meters (amplifier isolated)4 K0 x- a" H( m# f. {+ [
6 _! Q" k, k$ D. OAll point-to-point audio wiring
+ a* \' W( l4 X' K  S* t3 N/ j4 H6 L0 Q* |) B/ f
Gold input and output XLR connectors5 i6 t1 h/ z- R" _- g; x/ i
# B* e4 k# d0 H
Polypropylene and polystyrene coupling capacitors2 Z" y" k9 j9 n7 X1 q5 C2 M3 H. ^* z
: p+ Y! F$ k, p% U9 p- i
All audio switching through gold-contact, sealed precision relays
' w" Y/ d0 S& g' {4 s- Z  o; U, n* Z" ~
International operation on 100, 120, or 220 VAC, 50/60 Hz! O/ W  F8 D( T6 R  F
) o( Z3 k6 r, n% _CE certified, RoHS-compliant
: l, Q" t8 D& K& J* s' P
1 k. j% Q' |  ]( N, B% D. b: r+4 dBm output
4 @3 Z( Z4 ]0 S8 F! Q; X1 }# g' o; f
Conservatively rated precision components and rugged construction for stability and long life8 u& _3 y; h$ e
, I7 m6 h. h6 l8 K5 i# o" M, w* g8 O: LSpecifications
) ^' j1 ^& H: t9 @; w  Z$ w' U, N
: P* S6 y* J5 V! r, {! jInput 150 ohms" Q1 g8 E: N% n; n2 E
* E; h* v+ K# O' iInput Load Impedance 1.5k ohms
- O* v# l* w1 ]1 o
+ Q( |" y) |$ P. `) u  bMinimum Input Level -65 dBm nominal: \7 ?% X* Y' d8 R
- m2 N4 M) L; R3 o
Maximum Input Level @ 20 cps -30 dBm without pad, -5 dBm with 20 dB pad$ j3 @0 o2 w8 u
# [0 E% M* v& C* X* [Gain 53 dB8 b* e" M7 h* i
0 u8 s5 F3 b/ t2 w5 M5 ^
Frequency Response +/-0.25 dB 20 cps to 20 kc; -3 dB @ 0.5 cps and 55 kc
- H/ v+ s  {8 G7 T+ P# x8 c/ p$ Q3 M: U4 t9 {0 B$ Q
THD+Noise less than 0.25% 20 cps to 20 kc' w4 ]: z' ^9 i
7 A$ ~* n4 h& Q6 \" Q
Intermodulation Distortion SMPTE less than 0.02%! a9 P) O/ x. v9 b
( C. K/ P- Z1 K# j7 |, q' S
Signal to Noise Ratio 74 dB minimum2 I$ b4 @& c: \7 N
2 V& n; {& k0 g! J( ]- R0 C1 \
Equivalent Input Noise -124 dBm maximum
1 x4 i# }4 X6 P. y
$ k' y, |" J, X6 d0 f2 G4 ^Output low-Z, transformer-balanced. [% W! w. f$ J% V5 y
  Y! B7 S, V$ n# T. F% B9 XMaximum Output Level +22 dBm, 20k ohm load3 _" y% y, c0 ^4 r% v) ^/ r
  {3 Q7 q+ p. r0 `. i
Power Requirements 100, 120, or 220 VAC, 50/60 Hz
) D1 c1 A5 D, w  m9 e& q! K. H7 W* m) u5 l8 ^
Dimensions 19¡± (48.26cm) W, 5.25¡± (13.34cm) H, 14¡± (35.56cm) D
" v. r. U1 X% V4 `+ m1 |/ H0 ^
6 O) C2 J2 f4 ^; M8 Q) Q! O: D# ]& L6 F6 J+ ^
ÆÀÂÛÁÐ±í£¨2£©
Ö§³Ö!ÊÕ²ØÁË °¡
2006-3-10 22:27:00 »Ø¸´
coboy Â¥Ö÷
<P>лл֧³Ö£¡£¡£¡</P>
2006-3-11 01:14:00 »Ø¸´
