iZotope RX 8 Audio Editor Advanced v8.1.0 MacOS-MORiA ÒôƵºóÆÚÈí¼þ
iZotope RX 8ÊÇÒ»¿îרҵµÄÒôƵÖÕ¼«´¦ÀíÈí¼þ£¬Õâ¿îÈí¼þ¿ÉÒÔÂú×ã¸÷ÖÖÁìÓòËùÐèÒªµÄÒôƵÐÞ¸´ºÍ´òÄ¥Ì×¼þ¹¦ÄÜÐèÇó¡£ÔÚRX 8ÖУ¬ÎÒÃÇ´´ÔìÁËÐµĹ¤¾ß²¢¸Ä½øÁËÉîÊÜϲ°®µÄÄ£¿é£¬°ïÖúÄãÔÚ¸ü¶ÌµÄʱ¼äÄÚÍê³É¸ü¶àµÄ¹¤×÷¡£
Ö÷Òª¹¦ÄÜ£º
¼ªËûÈ¥Ôë
ʹÓà Guitar De-noise Õü¾ÈÄãµÄ×°±¸£ºÇ¿´óµÄ¹¤¾ßÀ´¿ØÖÆÒô¸ñÖ¨Ö¨Éù¡¢·Å´óÆ÷˻˻ÉùºÍàÐÔÓµÄʰÒô¡£
ƵÆ×»Ö¸´
ʹÓà Spectral Recovery ½«ÊµÊ±Á÷ýÌå¡¢Ô¶³ÌÒôƵͨ»°ÖеĿÅÁ£×´ÒôƵ»¹ÔΪˮ¾§°ãÇåÎú¡£
ÒôÀÖÔÙÆ½ºâ
ͨ¹ý¸Ä½øµÄÒôÔ´·ÖÀëËã·¨ºÍ´ÓÁ¢ÌåÉù¼ÒôÖÐÉú³ÉStemsµÄÄÜÁ¦£¬Äú¿ÉÒÔÇáËɵØÖØÐ´´½¨Ò»¸ö»ìÒô£¬É¾³ý»ò¸ôÀëÈËÉù½øÐлìÒô£¬ÉõÖÁ´´½¨ºÍµ¼³öеÄStems½øÐнøÒ»²½´¦ÀíºÍ»ìÒô¡£
Èí¼þÌØÉ«£º
1¡¢»Ö¸´Ô¤ÆÚµÄÐÔÄÜʹÓÃÐ嵀 Dialogue ContouÄ£¿é£¬Äú¿ÉÒÔÖØËܶԻ°µÄÓïµ÷£¬ÒÔÍì¾È»òÌá¸ßºóÆÚÖÆ×÷µÄ±íÏÖ¡£ Dialogue Contour¾ßÓÐÕë¶ÔÓïÒô¶¨ÖƵÄÒôµ÷УÕý´¦Àí£¬Ö¼ÔÚµ÷Õû¶Ô»°¶ÌÓïÄڵĵ¥´Ê±äÐΣ¬ÕâЩµ¥´Ê¿ÉÄÜÓë¼ô¼ÖÐµÄÆäÓà¶Ô»°²»Æ¥Åä»òÎÞ·¨ÕýÈ·Á÷¶¯¡£
ÇáËÉÆ´½Ó×ÔÈ»µÄ¾ä×Ó»ò½«³ÂÊö±ä³ÉÎÊÌ⣡
2¡¢Ð²å¼þ£¬Ð¹¤×÷Á÷³Ìʱ¼ä¾ÍÊÇÒ»ÇУ¬ÎÒÃÇΪRX7 AdvancedÌí¼ÓÁ˸ü¶àµÄ Audiosuite²å¼þ£¬ÒÔ°ïÖúÄú»ñµÃ¸ü¶à¡£Óû§ÊղؼРDialog IsolateºÍDe- rustleÏÖÔÚÒ²¿ÉÔÚ Pro Tools audiosuiteÖÐʹÓã¬ÎªÄúµÄÒôƵÐÞ¸´¹¤×÷Á÷³ÌÌṩ¸ü´óµÄÁé»îÐÔ¡£´ËÍ⣬RX7
AdvancedÏÖÔÚ¿ÉÈÃÄúÐÞ¸´¶à´ï712 Dolby atmosµÄ¶àÉùµÀÒôƵ¡£
3.ÒÆ³ýɳɳÉù
Á¢¼´´Ó¶Ô»°ÖÐÒÆ³ýÁîÈË·ÖÐĵÄÁì¼ÐʽÂó¿Ë·çÔëÒôºÍÆäËûÐÎʽµÄɳɳÉù¡£
¼õÉÙ¼äЪÐԵĵͶ˷çÉù
4¡¢¶Ô»°ÂÖÀªÖØËܶԻ°µÄÓïµ÷£¬ÒÔÕü¾È»ò¸ÄÉÆ±íÏÖ¡£
5¡¢¶Ô»°¸ôÀëÇáËɽ«¶Ô»°ÓëàÐÔӵı³¾°¸ôÀ뿪À´£¬ÈÃËü³ÉΪ½¹µã¡£
6¡¢ Dialogue De- ReverbʹÓûúÆ÷ѧϰÀ´¼õÉÙ»òɾ³ý¶Ô»°¼ô¼Öв»ÐèÒªµÄ»ìÏì
RX has long been the go-to audio repair and polishing suite for film, television, music, podcasts, video games, sample libraries, and more. With RX 8, we¡¯ve created new tools and improved beloved modules to help you accomplish more in less time than ever. Rescue your rig with Guitar De-noise: powerful tools to control fret squeaks, amp hiss and noisy pick sounds.
What¡¯s New in RX 8
Music Rebalance ARA
Guitar De-noise
RX 8 De-hum overhaul
Is that an AC unit you hear switching on in the back of your recording? Or maybe you¡¯re frustrated that your drummer lives in an apartment where no matter what room they¡¯re in, you can always hear their fridge humming along? Never fear! De-hum in RX 8 Elements is here.
New 32-tab limit for Audio Tabs
Time is precious when editing audio in post. To help you tackle more work faster, RX 8 doubles the previous 16-tab limit, now allowing you to view and edit up to 32 files within RX Audio Editor. Cover more ground in less time with greater efficiency and in-app real estate.
RX 8 Wow & Flutter module
Physical audio recordings¡ªsuch as tape and vinyl¡ªinevitably fall prey to the elements as time goes by. This often results in pitch fluctuations in those physical recordings. Wow & Flutter is designed to correct this symptom regardless of the intensity of the modulating pitch. Use Wow to fix longer, sustained pitch drift, and Flutter to correct pitch variances that occur at faster rates. Wow & Flutter is the key to performing pitch-perfect music restoration in record time.
RX 8 Loudness Control
Prepare your recordings for final delivery with the detailed level readings and loudness-management power of the all-new Loudness Control module. Load preset loudness standard targets to ensure your audio conforms to broadcast requirements, and monitor your levels using the built-in numeric and histogram readouts for integrated, short-term, and momentary loudness. Plus, resize the module to fit your display perfectly and suit your unique workflow.
Spectral Recovery
Restore grainy audio from live-streamed, remote audio calls to crystal clarity with Spectral Recovery.
Music Rebalance
With improved source separation algorithms and the ability to generate stems from a stereo recording, you can easily re-animate a mix, remove or isolate vocals for a remix, or even create and export new stems for further processing and mixing.
INSTALLATION:
¨C Install IZotope RX8.dmg
¨C Install IZotope RX8.pkg
REQ: Restart!
Done.
Whats new in this version:
Official site does not provide any info about changes in this version.
System Requirements
Mac OS 10.13.6 High Sierra ¨C MacOS 11 Big Sur
Plugin Formats: Standalone, AU, VST, VST3
MORiA | September, 30 2020 | STANDALONE, AU, VST, VST3 | 1.6 GB |
