µçƽÏÔʾ²å¼þ LVC Audio LVC Meter Ãâ·ÑÏÂÔØ
mangil320
2020-12-27 14:58:00
[Ãâ·ÑµçƽÏÔʾ²å¼þ]LVC Audio LVC Meter 1.0.9 [WiN, MacOSX]£¨20Mb£©
LVC-Audio·¢²¼ÁËÃâ·ÑµçƽÏÔʾ²å¼þLVC-Meter¡£Ðí¶àLVC-Audio²å¼þÖж¼²ÉÓÃÁËÕâ¸öµçƽÏÔʾµÄÄ£¿é¡£
LVC-Meter°üº¬ÆµÆ×·ÖÎöÒÇ¡¢Á¢ÌåÉùʸÁ¿Ê¾²¨Æ÷ºÍ²¨ÐÎÀúÊ·¼Ç¼ÊÓͼ¡£ËùÓÐÒÇ±í¶¼²ÉÓÃÕæÊµ·åֵ̽²âÈ·¶¨Ñù±¾¼ä·åÖµµçƽ£¨Òç³ö£©¡£´ËÍ⣬LVC-MeterÓÐEBUģʽ¡¢K-System¼ÆÁ¿ºÍ±ê×¼dBFSģʽ¡£
LVC-MeterÓÐÈý¸ö¼òµ¥µ«ÖØÒªµÄ¿Ø¼þ£ºGAIN£¬BALANCEºÍWIDTH¡£ÓÒ¼üµ¥»÷ÐýÅ¥¿Éϸµ÷GAINºÍBALANCE¿Ø¼þ¡£
LVC-MeterÌØÐÔ£º
¿Éµ÷µÄÕæÊµ·åÖµµçƽ£¬ÀûÓÚ¿ÉÊÓ»¯³ÊÏÖ¡£
¿Éµ÷Õû½çÃæ´óС¡£
¿ÉÅäÖýçÃæÑÕÉ«¡£
¿ÉÉèÖÃÆµÆ×·ÖÎöÒÇ£¨´°¿ÚÀàÐÍ¡¢ftf´óС¡¢½»µþ£©¡£
FloatDither£ºAirwindowsµÄ32λ¶¶¶¯Ä£¿é¡£
»ùÓÚXMLµÄÔ¤Éèϵͳ£¬¿É±£´æ¡¢µ¼ÈëºÍµ¼³öÓû§Ô¤Éè¡£
ϵͳ֧³Ö£º
Windows£ºVST£¬VST3ºÍAAX²å¼þ¸ñʽ
Mac OS X£ºAU£¬VST£¬VST3ºÍAAX²å¼þ¸ñʽ¡£
LVC-MeterÃâ·ÑÏÂÔØ£¨Ò²¿ÉÒÔÖ±½ÓÏÂÔØÎÒÃÇÌṩµÄ°Ù¶ÈÍøÅÌÁ´½Ó£©£ºhttps://lvcaudio.com/plugins/lvc-meter/
LVC-Meter 1.0.8
-updated September 29, 2020-
Meter: LVC style
LVC-Meter is a free plugin that builds on all of the metering features of Toned-MAX, Limited-Z, and Clipped-MAX. This may be nothing new, but there might be times when you need the LVC style meters but not all of the other plugin features.
Beyond Basic
LVC-Meter includes a spectrum analyzer, stereo vectorscope, and a waveform history view. All of the meters utilize true-peak monitoring for determining intersample peak levels (i.e., ¡°overs¡±). In addition, LVC-Meter functions in EBU mode, K-System metering, and standard dBFS mode.
Just Because
Why have a meter plugin that monitors stereo and true-peak levels without having the ability to adjust things Good question, and LVC-Audio agrees. LVC-Meter includes three simple but valuable controls: GAIN, BALANCE, and WIDTH. Both the GAIN and BALANCE controls have extra fine settings accessible by right-clicking on the knobs. These extra settings allow for precise gain and balance adjustment. Perfect for a final gain stage.
LVC-Meter
Adjustable true-peak level for visualizing overs
Resizable interface
User configurable colors
Configurable spectrum analyzer settings (e.g., window type, fft size, overlap)
FloatDither: 32-bit dithering based on Chris¡¯s work at Airwindows (https://www.airwindows.com/ditherfloat/)
XML-based preset system for saving, importing, and exporting user presets
System Requirements and Specifications
Windows: VST, VST3, and AAX plugin formats. LVC-Meter requires Windows Vista, Windows 7, or Windows 8 machines with a processor that supports SSE2 (AMD or Intel processor from around 2004 or later). An iLok device is required to use the AAX format.
OS X: AU, VST, VST3, and AAX plugin formats. LVC-Meter requires OS X 10.8 or later, and an Intel Core2Duo processor (or better). An iLok device is required to use the AAX format.
Download LVC-Meter and user manual (still in development)
¨C Version 1.0.8
Fix AAX issue with resizing
Save GUI size for each preset
Improved oversampling with AVX2 CPUs (Haswell and newer) on Windows ¨C impacts ISP detection and metering
¨C Version 1.0.7
Fix compatibility with Acustica plugins
Improve speed of resizing
Improve preset controls on OS X
¨C Version 1.0.6
Significant improvement with image resampling by replacing bilinear with AVIR (https://github.com/avaneev/avir) from Aleksey Vaneev from Voxengo
Adding hover-over indicators for most controls
Fix resizing with certain hosts and VST format, as well as improving display on smaller screens
CPU usage improvements
¨C Version 1.0.5
Add magnitude display in spectrum analyzer (configurable via XML config file)
¨C Version 1.0.4
Minor fixes and tweaks
Frequency display in spectrum analyzer (left click)
Fixed moveable controls being dragged off screen
¨C Version 1.0.3
LMeter-.zip (20.07 MB, ÏÂÔØ´ÎÊý: 0)
ÆÀÂÛÁÐ±í£¨1£©
ºÃ¶«Î÷£¬±ØÐëÖ§³Ö
2020-12-27 16:35:58 »Ø¸´
