查看: 26267|回复: 0
打印 上一主题 下一主题
[软件] 音频处理工具 – CyberLink AudioDirector Ultra
跳转到指定楼层
1#
发表于 2020-11-20 07:09:58 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
音频处理工具 – CyberLink AudioDirector Ultra 11.0.2304.0 WIN
AudioDirector 极致版 – 创造声音无限可能、视频声动精彩! 立即试用,感受强大声音编辑魅力:
动态强化视频的声音质量,自打造精准的5.1或7.1声道动态环场音效
与威力导演完美整合,拥有极为顺畅、无接缝的音效/视频工作流程
利用直觉式录音及混音工具,创作独一无二听觉特效
使用专业级视觉修复工具,移除多余声音,将声音还原至最纯净状态。
从DirectorZone云端资源网站免费下载各式音效风格文件套用至剪辑项目
使用iPhone app – AudioClipper随时录制各种声音并汇入使用。
语言: 英文, 繁体中文, 日文, 西班牙文, 韩文, 简体中文, 德文, 法文, 意大利文
Windows x64 | Languages: Multilingual | File Size: 365.82 MB
Precision Audio Editing for Videos. Proper audio is critical for setting the right mood for any video or movie. AudioDirector contains high-end tools to edit and fix audio tracks for professional results. Seamless integration with PowerDirector’s video editing workflow makes AudioDirector a must-have application for professional video makers.
AI Wind Remove
Recording outdoors will never be the same again! With just one click you can use the power of AI to remove wind gusts from audio clips, bringing clarity to dialogue and ambient sounds.
Punch & Roll Recording
Quickly record lengthy voiceovers or podcasts, and seamlessly make corrections to your dialogue tracks.
Restoration Adjustment Tools
– Dialogue Contour NEW – Change dialogue’s inflections
– Plosive Removal – Remove distracting breathy sounds in speech
– Noise Reduction – Clear unwanted static and background noise
– Declip – Remove distortion caused by clipping
– Declick – Clear track of clicks, pops and crackles
– Hiss Removal – Eliminate hissing sounds from audio tracks
– Hum Removal – Get rid of low frequency audio artifacts
Visual Spatial Audio Editing
Edit audio tracks for 360˚ videos in a visual preview window to precisely tune audio direction and elevation.
360º Video Support
Preview 360˚ video, import & edit multi-channel audio clips and export in 360˚ formats for a smoother workflow.
Vocal Transformer
Alter existing vocals through a number of natural-sounding filters. Choose from five existing presets including phone, gender, robot, and more, or create your own.
Multi-Channel Device Recording
Record from multiple audio channels at the same time directly into AudioDirector. You don’t need to spend time syncing channels, so you can start editing right away.
Track Alternatives in Mixer Room
Sample different effects and recordings on a single track with Track Alternatives. Add multiple tracks to the same timeline and preview different styles without having to individually mute and unmute them.
Ambience Creator
Maintain a constant ambience through your audio tracks by choosing a background sound sample and using it consistently in the entire clip.
Surround Sound Panner
Create sophisticated surround sound projects using dynamic panning technology.
Auto-Fit Background Music
Automatically adjust background music tracks to fit the length of your video. AudioDirector analyzes the music and seamlessly remixes it to fit the length of your video clip.
Batch Processing
Apply your favorite effects to multiple audio files simultaneously, saving hours of tedious editing time and repetition.
音频处理工具 – CyberLink AudioDirector Ultra.txt (147 Bytes, 下载次数: 0)
Codec Preview
Preview the final result and identify any artifacts from lossy encoding before you produce, so you can make smart processing decisions and create better sounding audio tracks.
Release Notes
System Requirements:
– Microsoft Windows 10, 8/8.1, 7 (64-bit OS only)
– Multi-core Intel processor with 64-bit support
– 128 MB VGA VRAM or higher
– 4 GB memory required (8 GB or above recommended)
– 1 GB hard disk space GB required
– Windows compatible sound card is required
Language Support:
– English
– French
– German
– Italian
– Spanish (European)
– Chinese Simplified
– Chinese Traditional
– Japanese
– Korean
Homepage
https://www.cyberlink.com
