Ashampoo Music Studio ÊÇ´¦ÀíÒôÀÖºÍÒôƵÎļþµÄÍêÕû½â¾ö·½°¸¡£¿ÉÒÔÂ¼ÖÆ¡¢×¥È¡¡¢¿Ì¼¡¢¼ô¼¡¢×ª»»ÒÔ¼°»ìÏý¸èÇú¡£¹ÜÀíÄúµÄÒôƵÊղأ¬´´½¨²¥·ÅÁÐ±í£¬Éè¼Æ²¢´òÓ¡·âÃæ ¨C Ò»ÇÐÖ»ÐèµãµãÊó±ê¾ÍÄÜ¿ì½ÝÍê³É£¡ÎÞÂÛÊǵçÄÔ¡¢ÊÖ»ú¡¢MP3 »òÊÇÆû³µÖУ¬ÏëÌý¾ÍÌý£¬ÈÃÄúÔÚÈÎÒâÉ豸Öж¼ÄÜÏíÊÜÄú×î°®µÄ¸èÇú£¡
: x- S# {, H6 r6 y7 a7 }" K4 _
$ ^6 Y/ W6 L$ q) W# ~9 v9 J" dFile Size: 58.7 MB
$ Q4 @* ~" F5 }# G7 n @# a& o" N8 g& M# g1 Z
Ashampoo Music Studio 2020 is a proven music software to edit, rip, organize and burn music and sounds in general. You can even design fitting covers for your projects, create device-compatible playlists or turn your songs into the perfect mix tape for your next party!0 z' l1 W' f: G5 Y0 I
" `3 y0 v! y1 b5 S3 K! VPerfect mix tapes for every event S* D6 S- l! Q) f& K3 T5 j, U
Create mix tapes for your next party in just a few clicks! Set the mood with fitting transitions and fades, pick a file format and sound quality and you¡¯re good to go. Casual party, wedding or other formal occasion ¨C create the right ambience with Ashampoo Music Studio 2020!
* D) k; A, {. H8 j. L: Z3 L( _6 p
Create playlists' L! B M' e7 W5 {2 J9 c/ P
Playlists allow you to play your songs in any order on almost any device. With its support for multiple audio formats (M3U, PLS, WPL, XSPF, etc.), playlists created with Ashampoo Music Studio 2020 are compatible with nearly every device.
" S1 M1 }3 X! u& z4 O2 X+ u% `3 ]; A' F. f4 Q
Rip CDs quickly and easily% b1 H3 _1 M5 c1 E+ g
Turning music and audio books into a more space-saving form is a breeze with this music program. Thanks to a gigantic database, your tracks will be auto-named and fitted with the right cover art before they¡¯re saved to a format of your choosing.* @: d0 @. O/ m; l5 t/ r$ J
: D* [! Q" V& p; }
Fast song renaming3 g1 |( l# a$ I4 G
Incomplete or inconsistent file names can ruin your song collection. Ashampoo Music Studio 2020 includes smart auto-naming based on customizable file naming schemes. Bring order to individual tracks or entire folders at the click of a button and save time and effort with this nifty feature!
/ ?, F2 \: M2 x3 e) ^5 x2 O: j. I) f! B' L, q& e
Extract audio from videos
3 \( i( L! b6 A# D+ G; ~Ashampoo Music Studio 2020 quickly extracts audio tracks from videos. Whether you want to enjoy that epic soundtrack from your favorite movie standalone or turn sounds and quotes into ring tones ¨C this music program will get the job done, and fast!, I0 g. o* H+ i9 h; ~* z
; h5 b/ S, V& {! I% E5 D! Z* a- q* ?
Useful tools for your sounds
$ _; V. U, D$ O* S* hAshampoo Music Studio 2020 comes with multiple useful tools, e.g. to edit metadata, normalize songs or analyze your audio files. It¡¯s everything you need in one handy music program. Go check it out. You¡¯ll be amazed how quickly you can achieve great results!
# h- B* W$ W/ P& v; j4 p3 @
; R$ X, ^+ { \9 fEdit audio files
) J. t: `8 m gNot all recordings come out perfectly out of the box. That¡¯s where audio editing comes into play. The built-in editor not only crops or cuts files into individual segments, but also supports volume adjustments, including muting entire sections. Edit your tracks and produce the songs you¡¯ve always wanted!6 }7 r7 C2 p2 J# C" {: o; d( q: E
1 h' ^, N, @& Y& G9 mRecord audio files+ y* c2 E( ?6 f8 h. X& z& s" P
Ashampoo Music Studio 2020 also supports recording your own audio files on your home PC. Simply pick the audio source and click ¡°Record¡±. Afterwards, use the built-in tools to edit your audio.
3 }# p2 h6 Y1 ~7 j" S
0 Q) v3 t7 y, s- m# EWhat¡¯s new:
: X1 Z- Y) ^ m) c3 Zofficial site does not provide any info about changes in this version: Z {1 l% f* q5 o8 M/ I& |
3 ^; S* g! ^0 `2 l3 j5 ?. [
Homepage
3 O3 w4 K+ x& Zhttps://www.ashampoo.com/7 K3 N0 t+ G0 z
% Y3 C+ I9 G, _, ~+ T3 _8 n% \
Â¼ÖÆ¡¢×¥È¡¡¢¿Ì¼¡¢¼ô¼¡¢×ª»»ÒÔ¼°»ìÏý¸èÇú¹¤¾ß ¨C Ashampoo Music Studi+ @; n7 J% D. @( V
Â¼ÖÆ¡¢×¥È¡¡¢¿Ì¼¡¢¼ô¼¡¢×ª»»ÒÔ¼°»ìÏý¸èÇú¹¤¾ß ¨C Ashampoo Music Studi.txt
(144 Bytes, ÏÂÔØ´ÎÊý: 0)
