Krotos Audio Concept v1.0.2 Mac ºÏ³ÉÆ÷²å¼þ
ÒÔÖÆ×÷ÉùÒôÉè¼Æ²å¼þÖøÃûµÄ Krotos Audio Ê״νøÈëºÏ³ÉÆ÷ÁìÓò£¬ËûÃÇ¿ª·¢µÄ Concept ÊÇÒ»¸öÖ±¹Û¶ø¸»Óд´ÒâµÄÈí¼þºÏ³ÉÆ÷£¬ËüµÄÄ¿±êÊÇÈÃÄã´´½¨ÒôÉ«µÄ¹ý³Ì¿ìËÙ¶øÓÐÆô·¢ÐÔ¡£Concept µÄÁé»îºÏ³ÉÒýÇæ¿ÉÒÔÈÃÄã´´½¨´Ó´«Í³ºÏ³ÉÒôÉ«µ½¸´ÔÓ½¥±ä±³¾°ÒÔ¼°¶¨ÖÆÉùÒôÉè¼ÆÔªËØÔÚÄÚµÄËùÓж«Î÷¡£
еĵ÷ÖÆ·½Ê½¿ÉÒÔÈÃÈÎÒâ²ÎÊýÓ³Éäµ½ Concept Óû§½çÃæÖÐÐĵÄËĸö¸ß¶È¿É±à¼µÄ¶àģʽµ÷ÖÆÆ÷ÉÏ¡£¿É´Ó¸÷ÖÖÁé»îµÄµ÷ÖÆÑ¡Ïî±ÈÈç°üÂç/Òô¸ß¸úËæ¡¢X/Y ²¶×½°åºÍ¶ÀÌØµÄ Tweak It ¶¨ÖÆÏµÍ³ÖÐÑ¡Ôñ¡£
Concept »¹´øÓÐÒ»¸öרÓÃµÄ¸ßÆ·ÖÊЧ¹ûÆ÷²¿·Ö£¬ÓÐ 3 ¸öͬʱ²å²Û¡£Ð§¹ûÆ÷Ì×¼þµÄÁÁµãÊÇÒ»¸öΪ»ìÒô×¼±¸µÄ¾í»ý»ìÏ죬ËüÔÊÐíÓû§Ê¹Óà IR ÎļþÀ´´´½¨·Çͬ³£¹æµÄЧ¹û¡£
Concept ¸ÅÀÀ£º
µ÷ÖÆÏµÍ³ ¡ª¡ª ̽Ë÷еÄÍϷŵ÷ÖÆ·½·¨¡£Í¨¹ýÇå³þµÄÑÕÉ«±àÂëºÍÄ¿±êÊÓ¾õ·´À¡¼´Ê±Á˽âÓ³Éä¡£
Tweak It ¡ª¡ª ʹÓÃÎÒÃǵĿɿØÖƺͿɷÖÅä¶¨ÖÆÏµÍ³¿ìËÙ»ñµÃÁé¸Ð¡£Í¨¹ýµ¥»÷¼´¿É´´½¨ÄãÒôÉ«µÄ±äÌ壬¿É»ñµÃ´ÓÒôÀÖÐÔµ½¸´ÔÓÐԵĽá¹û¡£
X/Y ²¶×½ ¡ª¡ª ͨ¹ý X/Y Çø±ð»æÖÆÄãµÄµ÷ÖÆÔ˶¯¡£²¶×½ÈÎÒâ²ÎÊýµÄ×éºÏÐÎʽ£¬²¢Í¬²½½á¹ûµ½ÄãµÄÏîÄ¿ËÙ¶È¡£Ë²¼ä´´½¨¶ÀÌØµÄÒôÉ«ºÍÐýÂÉ¡£
Ч¹û»ú¼Ü ¡ª¡ª ×éºÏһϵÁÐ¸ßÆ·ÖÊЧ¹ûÆ÷£¬ÍÏ·ÅÈÎÒâ²ÎÊýµ½µ÷ÖÆÏµÍ³¡£´´Ðµľí»ý»ìÏ죬¿ÉÒÔÈÃÄãʹÓö¨ÖƵÄÂö³åÏìÓ¦Îļþ¡£
ÒôƵÊäÈë ¡ª¡ª ͨ¹ýµ÷ÖÆÈÎÒâÊäÈë»òÀÖÆ÷¼¤·¢ÐµĹ¹Ë¼¡£Ê¹ÓÃÀ´×ÔÄã»ìÒôµÄÔªËØ´´½¨¶¯Ì¬µÄ½Ú×àÒôÉ«£¬»òʹÓÃÒô¸ß¸úËæÍ¨¹ýÏÖÓÐÐýÂÉ´´½¨ÁîÈËÐ˷ܵĻ¥¶¯¡£
×÷ΪÆð²½£¬Concept ´øÓÐ 200 ¶à¸ö²»Í¬Ô¤É裬ÓɱÈÈç Roni Size (Reprazent, Universal), Richard Devine (Google, Warp Records), Kayla Painter (Brownswood Recordings), Dom Ruckspin (Ninja Tune) ºÍ Heiroglyphic Being (Mathematics Records) µÈ Mercury ½±ÒôÀÖÖÆ×÷ÈËÉè¼Æ¡£
ConceptÊÇÒ»ÖÖÖ±¹ÛÇÒ¸»Óд´ÔìÐÔµÄÈí¼¯³É£¬Ëüʹ´´½¨×Ô¼ºµÄ²¹¶¡µÄ¹ý³Ì¿ìËÙÇÒ¹ÄÎèÈËÐÄ¡£ConceptµÄÁé»îµÄsynthÒýÇæ½«Ê¹ÄúÄܹ»´´½¨Ò»ÇдӴ«Í³µÄsynthÉùÒôµ½¸ü¸´ÔÓµÄÑݱäÎÆÀíºÍ×Ô¶¨ÒåµÄÉùÒôÉè¼ÆÔªËØ¡£Ò»¸öÐµķ½·¨£¬µ÷ÖÆÔÊÐíÈκβÎÊýÓ³Éäµ½Ëĸö¸ß¶È¿É±à¼µÄ¶àģʽµ÷ÖÆÆ÷Ö®Ò»£¬ÔÚ¸ÅÄîµÄUIÖÐÐÄ¡£´Ó¸÷ÖÖÁé»îµÄµ÷ÖÆÑ¡ÏÈçÐÅ·â/Òô¸ß×·ËæÕߣ¬X/Y²¶»ñµæºÍ¶ÀÌØµÄ¡°µ÷ÕûËü¡±¶¨ÖÆÏµÍ³¡£
XY²¶»ñ
XY CaptureÊÇÒ»ÖÖ¶ÀÌØµÄµ÷ÖÆÐ§¹û£¬½«XY padÓëÒ»ÖÖ·½Ê½½áºÏÔÚÒ»ÆðÀ´¡°²¶×½¡±XY padÖ´Ðе͝×÷£¬²¢Ê¹ÓÃÕâ¸ö¶¯×÷À´¿ØÖƲå¼þÖеÄÈκβÎÊý¡£XY²¶×½ÔÊÐíÄ㳬ԽLFOs£¬ÐÅ·â»òÅÃÒôºÍÖ±¹ÛµØÐÎ×´µÄÈκÎÊýÁ¿µÄ²ÎÊýµÄ·´Ó¦£¬²¢¼Ç¼·Ç³£¸´ÔÓ£¬¸öÈ˺ͿÉÖ´Ðе͝×÷¡£Ò»µ©Ò»¸öÔ˶¯±»²¶»ñ£¬Äã¿ÉÒÔ±à¼Ëü£¬Í¬²½ËüµÄ½Ú×࣬µ÷ÕûËÙ¶È»ò·½ÏòºÍ¸ü¶à¡£ÄãÒ²¿ÉÒÔÔÚÔ¤ÉèÖÐʹÓÃ×î¶à4¸öXY²¶»ñ¡£¼ì²éһЩÎÒÃǵŤ³§Ô¤É裬¿´¿´ÈçºÎ¿ÉÒÔÔÚÄú×Ô¼ºµÄÏîÄ¿ÖÐʹÓá£
ÒôƵÊäÈë
ÒôƵÊäÈëÊǸÅÄîµÄ¿ìËٺͼòµ¥µÄÒô¸ßºÍ·ù¶È¸úËæ¡£ÕâÔÊÐíÄú½«¶à¸öÒôƵÐźÅÊäÈë²å¼þ(È¡¾öÓÚÄúµÄDAW)£¬²¢½«ËüÃÇÓÃ×÷µ÷ÖÆÔ´¡£Äã¿ÉÒÔÑ¡ÔñÕñ·ù»òÒô¸ß·ÖÎö£¬²¢·ÖÅäÕâµ½ÈκβÎÊýµ÷ÖÆËü¡£Á¢¼´Ò¡¶¯ÄãµÄµÍÒô²¹¶¡»òµæÎ¹ÑøÔÚÌߣ¬Ã±×Ó»òÐýÂɵ½Ëü£¬ÒÔ½ºÄãµÄ¹ìµÀÔÚÒ»¸öȫеķ½Ê½!
µ÷ÕûËü
TweakÊÇConcept¹«Ë¾¶ÀÌØµÄ¶¨ÖÆÏµÍ³¡£ËüÔÊÐíÄã¿ìËÙ´´½¨¸÷ÖÖ²»Í¬µÄ¹¤³§Ô¤É裬»òÄã×Ô¼ºµÄÉè¼Æ£¬¶ø²»Ê§È¥Ô¤ÉèµÄ³õÊ¼ÌØÕ÷¡£Í¨¹ýÏò΢µ÷itϵͳÌí¼Ó²ÎÊý£¬Äú¿ÉÒÔÔÚÿ´Î´¥·¢Î¢µ÷ʱÔÚÒ»¶¨·¶Î§ÄÚ¸üиòÎÊý¡£Äú¿ÉÒÔÌí¼ÓÈÎÒâÊýÁ¿µÄ²ÎÊý£¬Òò´ËÄú¿ÉÒÔÔÚÒ»´Îµ÷ÕûÖе÷Õû²å¼þÄÚ²¿µÄÒ»¸ö»òÊý°Ù¸ö²ÎÊý¡£Äã¿ÉÒÔÔÚ²å¼þÖе÷Õû¼¸ºõËùÓеĶ«Î÷£¬°üÀ¨Õñµ´Æ÷£¬¹ýÂËÆ÷£¬FX£¬µ÷ÖÆÆ÷µÈËùÓÐʹÓÃÍÏ·Å¡£
Ö÷Ò³:
https://www.krotosaudio.com/concept/
Concept is an intuitive and creative soft-synth, that makes the process of creating your own patches fast and inspiring. Concept¡¯s flexible synth engine will enable you to create everything from traditional synth sounds to more complex evolving textures and custom sound design elements. A fresh approach to modulation allows any parameter to be mapped to one of four highly editable multi-mode modulators in the centre of Concept¡¯s UI. Choose from a variety of flexible modulation options such as an Envelope/Pitch Follower, an X/Y Capture pad and the unique ¡®Tweak It¡¯ customisation system.
XY CAPTURE
XY Capture is a unique modulation effect combining an XY pad with a way to ¡®capture¡¯ movements performed with this XY pad, and use this movement to control any parameter in the plugin. XY Capture allows you to go beyond LFOs, Envelopes or Arpeggiators and intuitively shape the response of any number of parameters, and record very complex, personal and performable movements. Once a movement is captured, you can edit it, sync it to tempo, adjust the speed or direction and much more. You can also use up to four XY captures in your presets. Check out some of our factory presets to see how this can be used in your own projects.
AUDIO INPUT
Audio Input is Concept¡¯s quick and easy pitch and amplitude follower. This allows you to feed multiple audio signals into the plugin (depending on your DAW), and use these as modulation sources. You can choose between amplitude or pitch analysis, and assign this to any parameter to modulate it.Instantly shake up your bass patches or pads by feeding in a kick, hat or melody into it, to gel your tracks in a whole host of new ways!
TWEAK IT
Tweak it is Concept¡¯s unique customisation system. It allows you to quickly create variations of factory presets, or your own designs, without losing the initial character of the preset. By adding a parameter to the Tweak it system, you allow the parameter to be updated within a certain range every time a Tweak is triggered. You can add any number of parameters, so you could tweak one, or hundreds of parameters inside the plugin on a single Tweak. You can tweak almost everything in the plugin, including oscillators, filters, FX, Modulators etc all using the drag and drop.
home page:
CODESHiNE | 03 June 2020 | 200 MB
ÏÂÔØ£ºhttps://www.torrentmac.net/krotos-audio-concept-v1-0-2/ |
