ºî¾ôѹËõ»ú ¨C Voxengo Marquis Compressor 2.5 Win
aidabuli
2020-7-9 12:15:59
File size: 8.0 MB
ºî¾ôѹËõ»úÊÇÒ»¸ö¡°Í¨Óá±Ñ¹Ëõ»úAAX, AudioUnitºÍVST²å¼þרҵÉùÒôºÍÒôÀÖÉú²úÓ¦Óá£Äã»á·¢ÏÖÒ»¸ö·Ç³£Æ½»¬µÄѹËõÐÔÄÜÔÚÕâ¸öѹËõ»ú£¬¼ÓÉÏÒ»¸öг²¨·á¸»µÄÉùÒô£¬¼ÈÊʺϻìÒôºÍÕÆÎÕ¡£×÷Ϊ¡°Í¨Óá±ÕâѹËõ»ú¿ÉÒÔÓÃÓڹ㷺µÄÉùÒô²ÄÁÏ:µ¥¸ö¹ìµÀ£¬¸ÉºÍ»ìÒô£¬²úÉú¡°Çå½à¡±»ò¡°²ÊÉ«¡±µÄÉùÒô¡£
ºî¾ôѹËõ»ú²å¼þÊǽ¨Á¢ÔÚ¹ÜÈý¼«¹ÜÄ£ÐÍ·Å´óÆ÷¼¶Áª¡£ÔÚµÍÇý¶¯Æ÷ÉèÖã¬Õâ¼¶Áª²úÉúÒ»¸öκ͵Äг²¨×ÅÉ«£¬¶øÔڽϸߵÄÇý¶¯Æ÷ÉèÖã¬Äã¿ÉÒԵõ½Ò»¸ö²Ð¿áµÄ¹Ü±¥ºÍ£¬Õ⹤×÷ΰ´óµÄ¹Ä£¬µÍÒôºÍÈËÉù¡£ÔÚÊʶȵÄÇý¶¯ÉèÖÃÏ£¬ÕâÖÖ²ãµþ¿ÉÒÔΪ»ìºÏÌí¼ÓÒ»ÖÖÁîÈËÓäÔõĴÖɰ¡£
ºî¾ôѹËõ»úµÄÌØµãÊǶÀÌØµÄ¡°Ô²ÐΡ±ÐÅºÅµçÆ½¼ì²âËã·¨£¬Ëü´´ÔìÁËÒ»¸ö·Ç³£¿ª·Å£¬ÓÐÁ¦£¬Ñ¹ËõÉùÒôÓëÒ»¸öÁîÈËÓ¡ÏóÉî¿ÌµÄ˲̬ÏìÓ¦¡£³ý´ËÖ®Í⣬ºî¾ôѹËõ»úÌṩÁËÒ»¸ö¾­µäµÄ·´À¡(opto)ѹËõģʽÇл»µ½Ò»¸ö¸ü³£¼ûµÄǰÀ¡Ñ¹Ëõ¡£
ºî¾ôѹËõ»úЯ´ø3ÖÖ¶ÀÌØµÄѹËõËã·¨£¬ÆäÖÐÒ»¸ö(T3)ÊÇ·ÂÕÕ¾­µäÄ£ÄâѹËõ»ú½¨Ä£µÄ¡£ÃÅËã·¨Ò²¿ÉÓã¬ÕâÊÇ·½±ãµÄ¼õÉÙ¹ÄÅÅÆøÔڹĹìµÀ¡£
ÌØµã:
3ѹËõ»úģʽ
4·Å´óÆ÷ģʽ
·´À¡Ñ¹Ëõģʽ
Æû³µ½á¹¹»ñµÃ
ÃÅ/ÏòÏÂÀ©Õ¹Æ÷ģʽ
Íⲿ²àÁ´
¹Ø¼üÐźÅÂ˲¨
Á¢ÌåºÍ¶àͨµÀ´¦Àí
ÄÚ²¿Í¨µÀ·ÓÉ
ÐŵÀ·Ö×é
´ïµ½8x¹ý²ÉÑù
64λ¸¡µã´¦Àí
Ô¤ÖùÜÀíÆ÷
³·Ïú/ÖØ×öÀúÊ·
A / B±È½Ï
ÉÏÏÂÎÄÌáʾÏûÏ¢
ËùÓÐÑù±¾ÂÊÖ§³Ö
Áã´¦ÀíÑÓ³Ù
Óû§½çÃæÅäÉ«·½°¸
¿Éµ÷Õû´óСµÄÓû§½çÃæ
ÊÓÍøÄ¤ºÍHighDPIÖ§³Ö
¼æÈÝÐÔ:
Õâ¸öÒôƵ²å¼þ¿ÉÒÔ¼ÓÔØµ½ÈκÎÒôƵÖ÷»úÓ¦ÓóÌÐò£¬·ûºÏAudioUnit»òVST²å¼þ¹æ·¶¡£AAX°æ±¾µÄ²å¼þ¿ÉÒÔÔÚProTools 12+ÖмÓÔØ¡£
´Ë²å¼þ¼æÈÝWindows(32λºÍ64λWindows XP, Vista, 7,8,10ºÍ¸ü¸ß°æ±¾)¼ÆËã»ú(2.5 GHzË«ºË»ò¸ü¿ìµÄ´¦ÀíÆ÷£¬ÖÁÉÙ4 GBµÄϵͳÄڴ棬SSE4.2Ö¸ÁîÖ§³Ö£¬ÀýÈçÈκÎIntel Core i-£¬ AMDÍÆÍÁ»ú-»òzenbase´¦ÀíÆ÷)¡£Ò»¸öµ¥¶ÀµÄ¶þ½øÖÆ·Ö²¼ÎļþÊÇ¿ÉÓÃÓÚÿ¸öÄ¿±ê¼ÆËã»úƽ̨ºÍÒôƵ²å¼þ¹æ·¶¡£
¼æÈÝWindows²å¼þÈí¼þ:Cubase, Logic Pro, ProTools, Ableton Live, Reaper, Presonus Studio One, FL Studio, Cakewalk, Nuendo£¬Ð¡²¨£¬GarageBand, Vegas, SoundForge, Audition, Samplitude, Digital Performer, Mixcraft, Bitwig Studio, Edius, others¡£
ʲôÐÂ:
ÐÞÕýÁËÒ»¸öÉÙ¼ûµÄÏîÄ¿¼ÓÔØ±ÀÀ£¡£
*ÔÚÔ¤Éè¹ÜÀíÆ÷ÖÐÔö¼ÓÁËÔ¤ÉèÁбíÅÅÐò¹¦ÄÜ¡£
ÖØÐÂÉè¼ÆÁËÐýÅ¥µÄÐÎÏó¡£
*ʹÓÃÑÕÉ«ÐÞ¸ÄÆ÷À©Õ¹ÁË¡°ÑÕÉ«±à¼­Æ÷¡±¡£
*Ôö¼ÓÁË¡°»ÒÀ¶É«¡±ºÍ¡°º£¾üÀ¶¡±µÄÅäÉ«·½°¸¡£
*¸ÄÉÆÑ¹Ëõ×ÖÌåµÄ¿É¶ÁÐÔ¡£
Marquis Compressor is a ¡°universal¡± compressor AAX, AudioUnit and VST plugin for professional sound and music production applications. You¡¯ll find a very smooth compression performance in this compressor, coupled with a harmonically-rich sound, both suitable for mixing and mastering. Being ¡°universal¡± this compressor can be used on a wide range of sound material: individual tracks, stems and mixes, producing ¡°clean¡± or ¡°colored¡± sound.
Marquis Compressor plugin was built around a tube triode-modeled amplifier cascade. At low Drive settings this cascade produces a mild harmonic coloration while at higher Drive settings you can get a brutal tube saturation which works great for drums, bass and vocals. At moderate Drive settings this cascade can add a pleasant grit to the mix.
Marquis Compressor features a unique ¡°round¡± signal level detection algorithm, which creates a very open, punchy, compressed sound with an impressive transient response. Beside this, Marquis Compressor offers a classic feedback (opto) compression mode switchable to a more common feed-forward compression.
Marquis Compressor carries 3 distinctive compression algorithms, one of them (T3) being modeled after a classic analog compressor. The Gate algorithm is also available which is handy at reducing drum bleed in drum tracks.
Features:
3 compressor modes
4 amplifier modes
Feedback compression mode
Auto make-up gain
Gate/downward expander mode
External side-chaining
Key signal filtering
Stereo and multi-channel processing
Internal channel routing
Channel grouping
Up to 8x oversampling
64-bit floating point processing
Preset manager
Undo/redo history
A/B comparisons
Contextual hint messages
All sample rates support
Zero processing latency
User interface color schemes
Resizable user interface
Retina and HighDPI support
Compatibility:
This audio plugin can be loaded into any audio host application that conforms to the AudioUnit or VST plugin specification. Plugins with AAX version available can be loaded in ProTools 12+.
This plugin is compatible with Windows (32- and 64-bit Windows XP, Vista, 7, 8, 10 and later versions) computers (2.5 GHz dual-core or faster processor with at least 4 GB of system RAM, SSE4.2 instructions support required, e.g. any Intel Core i-, AMD Bulldozer- or Zen-based processor). A separate binary distribution file is available for each target computer platform and audio plugin specification.
Compatible Windows plugin software: Cubase, Logic Pro, ProTools, Ableton Live, Reaper, Presonus Studio One, FL Studio, Cakewalk, Nuendo, WaveLab, GarageBand, Vegas, SoundForge, Audition, Samplitude, Digital Performer, Mixcraft, Bitwig Studio, Edius, others.
Whats New:
* Fixed a rare crash on project load.
* Added the preset list sorting function to the preset manager.
* Redesigned the knob image.
* Extended the ¡°Color Editor¡± with color modifiers.
* Added the ¡°Gray Blue¡± and ¡°Navy¡± color schemes.
* Improved readability of the condensed font.
