BeepStreet Sunrizer v1.2.4 Win/V1.20 MACœp·¨ºÏ³ÉÆ÷
Ò»¸ö¾µäµÄŤÇú
SunrizerÊǽ¨Á¢ÔÚÒ»¸öÊìϤµÄ¼õ·¨ºÏ³ÉÉè¼Æ-µ«¾ßÓÐÏÊÃ÷µÄ¸öÐÔºÍÐí¶à¶ÀÌØµÄÌØµã¡£Ëü¿ªÊ¼ÓÐÁ½¸öÕñµ´Æ÷ºÍÁ½¸ö×ÓÕñµ´Æ÷£¬ÌṩËùÓеĻù±¾²¨ÐκÍÍêÃÀµÄ·ÂÕæJP-8000¡°supersaw¡±£¬Âö³å¿í¶È£¬ÆµÂʺͻ·Ðε÷ÖÆ¼ÓÉÏÒ»¸ö»ªÀöµÄºÍгģʽ¡£
´óʦµÄÓ°Ïì
SunrizerÓÐÒ»¸ö·Ç³£Áé»îµÄЧ¹û²¿·Ö£¬ËüÓµÓÐÒ»¸öÊäÈë½»²æ¹ýÂËÆ÷£¬ÈÃÄãÖ»Ó¦ÓÃËüÃÇÔÚÆµÆ×µÄÒ»¸öÌØ¶¨²¿·Ö¡£ÓÐÒ»¹²ÓÐËĸöЧ¹ûÄ£¿é-µÚÒ»¸ö°üÀ¨¹â»¬µÄºÏ³ª£¬ÏàλÆ÷ºÍת×ÓËã·¨ÓëÊ§Õæ£¬Æä´ÎÊÇÁ¢ÌåÉùÑÓ³Ù£¬Á½²¨¶Î¾ùºâÆ÷ºÍÒ»¸ö¿í³¨ºÍ¸ß¶È¿Éµ÷»ìÏ졣Ȼ¶ø£¬ÓÉÓÚ´óÁ¿µÄ´úÂëÓÅ»¯£¬SunrizerÈÔÈ»±£³ÖÁ˽ϵ͵Ĵ¦ÀíÆ÷¸ºÔØ¡£
ÓÐÁ¦µØÉú»î
ÔÚSunrizerµÄÉùÒôÒýÇæ½áÊøµÄµØ·½£¬ÀÖȤ²Å¸Õ¸Õ¿ªÊ¼¡£Ê×ÏÈ£¬Ã¿¸ö²¹¶¡¶¼ÓÐÁ½×é²ÎÊý£¬¶øsynth¿ÉÒÔÈÃÄãÔÚËüÃÇÖ®¼äËæÒâ±äÐΡª¡ªÁ÷³©»ò¿ñÒ°¡£Sunrizer»¹Ô˶¯ÁËÒ»¸öÅÃÒô£¬ÒÑÍêÈ«¿É±à³ÌÐòÁкÍÖ§³Öÿ¸öÒô·ûµÄת»»ºÍËæ»ú»¯-Ò»ÆðÓëºÍÏÒ¼ÇÒ䣬ËüÔÊÐíÄã´´Ô쾫ϸ¶ø¾«Ï¸µÄ¿É¿ØÖƵĵ¥ÊÖÖ¸»ò¶àÊÖָͨµÀ¡£
µÄ¼òµ¥
¾¡¹ÜÓÐÕâô¶àµÄ¹¦ÄÜ£¬µ«SunrizerµÄµ¥ÆÁÄ»Éè¼ÆÓ뾫ÐÄÖÆ×÷µÄͼÐΣ¬ÔÚÊÓÍøÄ¤ÆÁÄ»ÉÏ¿´ÆðÀ´Ìرð»ªÀö¡£ËüµÄËùÓй¹¼þ¶¼ÊÇÂß¼°²Åŵģ¬Ò×ÓÚ·ÃÎÊ£¬Ã¿¸ö²ÎÊý¶¼¾¹ý×ÐϸУ׼¡£ÕâÈÃSunrizer¸øÄãÒ»¸öÍêÈ«µÄÀÖȤºÍ¾Þ´óµÄÉú²úÁ¦£¬ÕâÊÇȱ·¦ÔÚ´ó¶àÊý²»±ØÒªµÄ¹ýÓÚ¸´Ôӵĺϳɡ£
¹æ·¶
¶¨ÖƵÄsynthÒýÇæÓë24ÓïÒô¸´µ÷ºÍ·Ç³£µÍµÄ´¦ÀíÆ÷¸ºÔØ¡£
•¾ßÓжàÖÖ²¨ÐÎÀàÐ͵ÄÁ½¸öÕñµ´Æ÷£¬Ó²Í¬²½£¬Âö¿íµ÷ÖÆ¡£
´øÓл·Ðε÷ÖÆÆ÷ºÍ¶ÀÁ¢ÔëÉùÔ´µÄÕñµ´Æ÷»ìƵÆ÷¡£
ÿ¸öÕñµ´Æ÷µÄÒ»ÖÂÐÔ¹¦ÄÜÓë¿É±äµÄdetuneºÍÀ©Õ¹¡£
•Á½¸ö¶ÀÁ¢µÄ´®Ðлò²¢ÐвÙ×÷µÄÂ˲¨Æ÷µ¥ÔªºÍ16ÖÖ²»Í¬µÄËã·¨:µÍ¡¢¸ß¡¢´øÍ¨¡¢Ïݲ¨Æ÷¡¢Êá×´²¨¡¢¹²Õñ·åI/II¡¢È«Í¨¡¢¹¦Âʵ͡¢´øÍ¨¡¢²¨haper¡¢Ð³ÕñÆ÷¡¢ÔÙ²ÉÑùÆ÷¡¢µÍͨ+ÔÙ²ÉÑùÆ÷¡¢ÒÆÆµÆ÷¡¢Ä£ÄâµÍͨ¡£
Á½¸öADSRÐÅ·âÉú³ÉÆ÷¡£
Á½¸öLFO·¢µç»ú£¬ÕýÏÒ£¬Èý½ÇÐΣ¬¾â×Ó£¬Õý·½ÐΣ¬Ñù±¾ºÍ±£³ÖºÍËæ»ú
²¨ÐÎ;¿É±äÏà룬µÈëʱ¼äºÍ²»Í¬µÄ´¥·¢Ä£Ê½¡£•Master effects°üÀ¨ºÏ³ª£¬ÏàλÆ÷£¬×ª×Ó£¬EQ£¬ÑӳٺͻìÏì¡£
•¾ßÓÐÉî¶ÈÅÅÐò¹¦ÄܵÄÅÃÒôÆ÷¡£
•ºÍÏÒ¼ÇÒ书ÄÜ¡£
•A-B²ÎÊý±äÐÎÌØÕ÷:±¾ÖÊÉÏÊÇÁ½¸ösynth²¹¶¡ÔÚÒ»¸ö¡£
•ÓµÓг¬¹ý400¸öÔ¤Öò¹¶¡µÄ¹¤³§ÒôЧ¿â;ÓëiPad°æ±¾ÍêÈ«¼æÈݵIJ¹¶¡¡£
Sunrizer 1.2.4µÄ±ä»¯:
¸Ä½øµÄ»¬¿éÖµÓ³Éä¡£
ÐÞÕýÁËÕñµ´Æ÷2°ëÐýť״̬±£´æ(½öÔÚWindows)µÄÎÊÌâ¡£
A classic with a twist
Sunrizer is built upon a familiar subtractive synth design ¨C but with a distinct character and a host of unique features. It starts with two oscillators and two sub-oscillators that deliver all of the basic waveforms and a perfect emulation of JP-8000 ¡°supersaw¡±, with pulse width, frequency and ring modulation plus a lush unison mode.
Master of effects
Sunrizer has a very flexible effects section which boasts an input crossover filter that lets you apply them only on a specific part of the spectrum. There is a total of four effect modules ¨C the first includes silky-smooth chorus, phaser and rotor algorithms alongside distortion, followed by stereo delay, two-band equalizer and a spacious and highly tuneable reverb. Yet with all this power Sunrizer still keeps the processor load low, thanks to heavy code optimizations.
Powerfully live
Where the Sunrizer¡¯s sound engine ends, the fun only starts. First off, each patch has two sets of parameters and the synth lets you morph between them ¨C as smoothly or as wildly as you wish. Sunrizer also sports an arpeggiator that has fully programmable sequences and supports per-note transposition and randomization ¨C together with chord memory it allows you to create elaborate yet finely controllable single- or multi-finger passages.
Polished simplicity
Despite such an extensive feature list, Sunrizer has a single-screen design with finely crafted graphics that especially look gorgeous on Retina screens. All of its building blocks are logically arranged and easily accessible, with each individual parameter carefully calibrated. This lets Sunrizer give you a mix of utter pleasure and great productivity that is lacking in most unnecessarily overcomplicated synths.
Specifications
•Bespoke synth engine with 24 voice polyphony and very low processor load.
•Two oscillators with multiple waveform types, hard-sync, pulse width modulation.
•Oscillator mixer with ring modulator and separate noise source.
•Per-oscillator unison function with variable detune and spread.
•Two separate filter units with serial or parallel operation and 16 different algorithms each: low-, high- and band-pass, notch, comb, formant I/II, all-pass, power low- and band-pass, waveshaper, resonator, resampler, low-pass + resampler, frequency shifter, analog low-pass.
•Two ADSR envelope generators.
•Two LFO generators with sine, triangle, saw, square, sample & hold and random
waveforms; variable phase, fade-in time and different trigger modes. •Master effects including chorus, phaser, rotor, EQ, delay and reverb.
•Arpeggiator with deep sequencing capabilities.
•Chord memory function.
•A-B parameter morph feature: essentially two synth patches in one.
•Factory sound bank with over 400 preset patches; full patch compatibility with the iPad version.
Changes in Sunrizer 1.2.4:
Improved sliders value mapping.
Fixed issue with Oscillator 2 semi knob state saving (Windows only).
v1.2.4 Win V1.20 MAC |
