Electronica Performance Synthesizer Kontakt µç×ÓºÏ³ÉÆ÷
Êý×ÖÉùÒô¹¤³§³ÊÏÖKontaktµç×ÓÊÕ²ØÕÆÎÕΪDSFÐÔÄÜºÏ³ÉÆ÷¡£ÓÃÕâÌ×µç×Ó¹¤¾ßÈôó¼ÒÕ¾ÆðÀ´¡£Ó²ºË±´Ë¹ºÍԭʼºÏ³ÉºÍʵʱ¿ØÖƸøÄã¼ÝÔ¦ÉùÒôµÄÁ¦Á¿¡£´´½¨ÐµÄÁîÈËÐ˷ܵÄÎÆÀíºÍÔÚ·ÉÐкͷ¢ËÍÄãµÄÒôÀÖµ½µç²¨¡£ºÏ³ÉЧ¹û£¬¿áŤµÄÏÖ´úºÏ³ÉÆ÷²¨ÐΣ¬ÒÔ¼°´óÁ¿µÄÎèÇú¶¼ÊÇÕâ¿î¸ßÄܵç×ÓÒôÏìµÄÒ»²¿·Ö¡£
Êý×ÖÉùÒô¹¤³§µç×ÓÐÔÄÜºÏ³ÉÆ÷KONTAKT screenshotSequencerÊÓͼÌṩ¶à´ïÁù-Ê®Áù²½Ä£Ê½¡£Ã¿¸öģʽ°üº¬ËÙ¶È¡¢Òô·û³ÖÐøÊ±¼äºÍÒôµ÷¡£Ä£Ê½¿ÉÒÔ¿ìËٵشÓÒ»¸öµØ·½¸´ÖƵ½ÁíÒ»¸öµØ·½¡£ËÙÂÊ¿ØÖƽÚ×࣬³ÖÐøÊ±¼ä¿ØÖÆÒô·û³¤¶È£¬Ò¡°Ú½«Íƶ¯»òÀ­½Ú×࣬¶ø°Ë¶ÈÑ¡Ôñ°Ë¶È·¶Î§¡£È«¾ÖÑ¡Ôñ¹Ø±Õ¡¢´ò¿ªºÍ±£³Öģʽ¡£
Êý×ÖÉùÒô¹¤³§µç×ÓÐÔÄÜºÏ³ÉÆ÷KONTAKTÆÁÄ»½ØÍ¼ÅÃÒôÊÓͼ°üº¬Ò»¸ö32²½µÄÅÃÒô£¬²¢Ìṩ16Ô¤ÖÃÒô·û˳Ðò¡£Ã¿¸öͼ°¸°üº¬ËÙ¶È¿ØÖƵÄ×¢ÒâÊÂÏî¡£ËÙÂÊ¿ØÖƽÚ×࣬³ÖÐøÊ±¼ä¿ØÖÆÒô·û³¤¶È£¬Ò¡°Ú½«Íƶ¯»òÀ­½Ú×࣬°Ë¶ÈÑ¡Ôñ°Ë¶È·¶Î§£¬¶ø´ò»÷¿ØÖÆÒ»¸öÒô·ûÖØ¸´µÄ´ÎÊý¡£È«¾ÖÑ¡ÔñOff, On, HoldºÍHold + -ģʽ¡£
Digital Sound Factory presents Kontakt Electronica collection mastered for the DSF Performance Synthesizer. Keep the crowd on their feet with this set of electronica tools. Hard core basses and raw synths and real-time control give you the power to harness the sound. Create new exciting textures and grooves on the fly and send your music into the airwaves. Synth effects, cool twisted modern synthesizer waveforms, and a large palate of dance hits are part of this high energy electronic sound set.
Digital Sound Factory Electronica Performance Synthesizer KONTAKT screenshotSequencer view provides up to six ¨C sixteen step patterns. Each pattern contains velocity, note duration, and pitch. Patterns can be quickly soloed and copied from one location to another. Rate controls tempo, Duration controls note length, Swing will push or pull the tempo, and Octave selects the octave range. Global selects Off, On, and Hold modes.
Digital Sound Factory Electronica Performance Synthesizer KONTAKT screenshotThe Arpeggiator view contains a 32 step arpeggiator and provides 16 presets for Note Order. Each pattern contains note on velocity control. Rate controls tempo, Duration controls note length, Swing will push or pull the tempo, Octave selects the octave range, and Strike controls the number of times a note is repeated. Global selects Off, On, Hold, and Hold + ¨C modes.
