Cinematique Instruments K101 Keyboard KONTAKTÀÏʽµÄ¿¨Î÷Å·ºÏ³ÉÆ÷
k101ÊÇÒ»¸öÐÒÔ˰ü¡£ËüµÄÖ÷ÒªÒôÔ´ÊÇÀÏʽµÄ¿¨Î÷Å·(Casio) z ¨C 101¼üÅÌ£¬¸¨ÒÔ´Ó¿¨Î÷Å·PT-10Éϲ¶×½µ½µÄһЩÉùÒô¡£ËùÓеÄÉùÒô¶¼ÊǷdz£ÎÂůºÍÃÔÈ˵ġ£Äã¿ÉÒÔÃÔʧ×Ô¼º£¬Ö»ÊÇÑØ×ÅÄ£ÄâµÄÉùÒô£¬±»Æä¶ÀÌØµÄÌØµã£¬¼´ÎÂůºÍÔʼµÄÁé¸Ð¡£
µÄÄÚÈÝ
K 101µÄÒÇÆ÷Éè¼ÆÊÇ»ùÓÚ2¸öͬʱµÄÉùÒô²Û£¬Ã¿¸ö²Û¿ÉÒÔÓë47¸öÉùÔ´Ö®Ò»£¬²¢ÓÐÒ»¸öµ¥¶ÀµÄÒôÁ¿ºÍ¹øÐýÅ¥¡£³ý´ËÖ®Í⣬µÚÒ»¸ö²å²ÛÌṩÁËÒ»¸ö¶îÍâµÄ-12µ½12°ëÒôÒô¸ßÐýÅ¥¡£
ÎÒÃDz¶×½ÁËÔʼ¼üÅ̵Ä47ÖÖ¸öÐÔ»¯Éè¼ÆµÄÉùÒô¡£ÎÒÃÇÂ¼ÖÆÁËÕû¸öСÈý¶ÈÒôÓò£¬Ñ»·²¥·ÅÉùÒô£¬±ØÒªÊ±½øÐд¦Àí£¬²¢½«ÒôÓòÀ©Õ¹µ½C0-C6¡£ÎªÁËËÜÔì×îÖÕµÄÉùÒô£¬K 101ÌṩÁË´óÁ¿µÄÉùÒôÑ¡Ïî:
EQ±»³ÆÎª¡°¹ýÂËÆ÷¡±¡£½¯´ºêѶÔÓÚ·ÑÂí´ó¶¨Àí¡±ºÍ„ÒôÏ족
Ðýת£¬±ÇÒôºÍŤÇú-fx
»ìÏìºÍÑÓ³Ù
Á½¸ö²»Í¬µÄ¾íÐŷ⣬·Ö±ð½Ð×ö¡± PAD ¡°ºÍ¡± SQR ¡±
K 101ÌṩÁË55¸öÔ¤Ö㬺¸ÇÁËһϵÁеĸÖÇÙ¡¢µÍÒô¡¢µæÒô¡¢¹Ü·çÇÙºÍ¸ßÆµÒô¡£Òª±£´æ×Ô¼ºµÄÔ¤Öã¬Ö»ÐèÔÚÓ²ÅÌÉÏÒÔ²»Í¬µÄÃû³Æ±£´æ²¹¶¡¡£
Ò»¸ö·Ç³£ÌØÊâµÄÑ¡ÏîÊÇ¡°RNDM¡±¹¦ÄÜ£¬Ëü¿ÉÒÔËæ»úÉèÖÃfx²ÎÊý¡¢ÉùÒôÑ¡Ôñ¡¢ÒôÁ¿ºÍÆ½ÒÆ¡£ÕâÊÇ´¿´âµÄÀÖȤºÍ¾ªÈ˵Ŀ´µ½Ê²Ã´×îºó³öÀ´
Ò»¸ö¸´ÔÓµÄKontakt²¹¶¡ÓÐ47¸öµ¥Ò»µÄÉùÒô¿ÉÓÃÁ½´Î(2¸öÉùÒô²å²Û)ºÍ55¸öÔ¤Éè¡£
Kontakt 4.22ÍêÕû°æ±¾ÊDZØÐèµÄ
The K 101 is a lucky bag. Its main sound source are the vintage Casio CZ¨C101 keyboard, supplemented by a few sounds captured from a Casio PT-10. All the sounds are incredibly warm and charming. You can lose yourself just playing along the analog sounds, being inspired by its distinct character which is both warm and raw.
The Content
K 101¡äs instrument design is based on 2 simultaneous sound slots, each can be feeded with one of 47 sound sources and has a separate volume and pan knob. Beside that, the first slot provides an additional -12 to 12 semitones pitch knob.
We captured 47 individualy designed sounds of the original keyboards. We recorded the whole keyrange in minor thirds, looped the sounds, processed them if needed and extended the key range to C0-C6. In order to shape the final sound, K 101 provides plenty of sound options:
3 EQ¡äs called „FILTER¡±, „A.FLT¡± and „HIFI¡±
rotary- , twang- and distortion-fx
reverb and delay
2 different volume envelopes, called „PAD¡± and „SQR¡±
K 101 provides 55 presets which are covering a range of pianos, basses, pads, organs and fx-sounds. To preserve your own presets simply save the patch under a different name on your harddrive.
A very special option is the „RNDM¡± function, which sets fx parameters, sound selections, volumes and panning by random. This is pure fun and amazing to see what comes out in the end
One complex Kontakt patch with 47 single sounds available twice (2 sound slots) and 55 presets.
Kontakt 4.22 full version is required |
