Overloud BREVERB 2 v2.1.10 WiN/v2.1.11 MacOSX 混响效果器
有了BREVERB 2,你的指尖就能听到50多种新的环境空间的声音。所有的氛围设置都是由吵闹的工程师精心制作的,他们参考了首选的房间和顶级音效设计师的氛围选择。
它们涵盖了从混音到后期制作的广泛应用,其中许多都是针对特定的乐器进行优化的,从鼓到人声到吉他等等。不要浪费时间浏览几十个不同的混响插件,寻找正确的房间声音。与BREVERB 2,你可以找到它在一个点击,没有妥协的声音质量。
新空间算法
空间算法的设计,以满足极高的要求,音频专业人士喜欢你;今天,还有明天。为完成BREVERB调色板而创建的space算法可以根据任何现代录音的混合需求进行定制。您可以自由控制多达38个参数来创建您自己独特的房间声音。或者,如果你在一个紧迫的期限,你可以使用我们的综合库的预设,由一流的声音工程师设计。
新的预设管理
预置管理器已经完全重新设计。它在插件界面上有一个专用区域,与旋钮空间分开,让你的声音库总是方便。您可以轻松创建类别来组织您的预置,无论您选择什么。导入,导出和分享您的预设只需单击。通过多级撤销/重做功能,您可以跟踪您对设置所做更改的历史。
新的算法
BREVERB 2的特点是一个新的源混响算法。只需在图形界面上单击一下,就可以设置声源的3D位置,并在混音中创建逼真的全景。源算法是后期制作的理想工具。你可以单独设计早期反射和混响场,完全控制任何参数。通过自动化,您可以实时控制声源的位置,并创建声源的明显运动。
With BREVERB 2 you have the sound of more than 50 new ambient spaces at your fingertips. All ambience settings have been carefully crafted by Overloud engineers who referenced the preferred room and ambience choices of top sound designers.
They cover a wide range of applications from mixing to post-production, and many of them are optimized for a particular instrument, from drums to vocals to guitars etc. Don’t waste time flipping through dozens of different reverb plug-ins, looking for the right room sound. With BREVERB 2 you can find it in one click, with no compromises in sound quality.
New spaces algorithms
SPACES algorithms are designed to meet the extremely high demands of audio professionals like you; today, as well as tomorrow. Created to complete the BREVERB palette, the SPACES algorithms are tailored to the mixing needs of any modern recordings. You are free to control up to 38 parameters to create your own unique room sound. Or, if you are on a tight deadline, you can use our comprehensive library of presets, designed by top-notch sound engineers.
New preset management
The preset manager has been completely redesigned. It has a dedicated area on the plugin interface, separate from the knob space, to have your sound library always handy. You can easily create categories to organize your presets however you choose. Import, export and share your presets with just one click. With the multilevel undo/redo feature, you can keep track of the history of the changes you make to your settings.
New source algorithm
BREVERB 2 features a new SOURCE reverb algorithm. With a simple click on the graphic interface you can set the 3D position of your sound sources and create life-like panoramas in your mix. The SOURCE algorithm is the ideal tool for post-production. You can separately design the early reflections and reverberant field, with full control over any parameter. Through automation you can have real-time control of the position of the sound source and create apparent movement of the sound sources.
Overloud BREVERB 2 v2.1.10 WiN | 7 Mb MacOSX | 32 Mb |
