Mojave Audio MA-201fet´óÕñĤµçÈÝ»°Í²
joyc
2020-6-1 10:03:15
ÒôƵϵÁÐ
MA - 201fet´ÓιþΤAudioÊÇÒ»¸ö´óÕñĤ¹Ì̬µçÈÝ»°Í²£¬ËüÌṩһ¸öÎÂů£¬³äÂúÁË¿ÚÆø¡£·Ç³£ÊÊÓÚ¸÷ÖÖÉùÀÖºÍÆ÷ÀÖµÄÓ¦Ó㬻°Í²ÓÐÒ»¸ö**¼¶FETºÍղɭÒôƵ±äѹÆ÷Ìṩ¸É¾»£¬ÇåÎúµÄÉùÒô£¬µÍÔëÉùºÍ¸ßÉùѹ¼¶´¦ÀíÄÜÁ¦¡£
Âó¿Ë·çÓÐÊÖÑ¡3΢Ã×1 ¡°½ºÄÒÓëÐÄÐÎʰÒôģʽµÄÁ˲»ÆðµÄÀëÖáÒÖÖÆÔëÉùµÄ»°Í²ÓÐÒ»¸ö±ê×¼µÄ3ÕëXLRÁ¬½ÓÆ÷ºÍ¹¤×÷ÔÚ48V»ÃÏóµçÔ´£¬Ò»¸ö·ÉÐÐÏäºÍµ¯ÐÔ·ÀÕð¼Ü¶¼°üÀ¨ÔÚÄÚ¡£
ÎÂů£¬±¥ÂúµÄÉùÒô
Ò»¸öղɭÒôƵ±äѹÆ÷ºÍ**¼¶³¡Ð§Ó¦¹ÜÌṩһ¸öÎÂů£¬³äÂúÁË¿ÚÆø
ÐÄÐÎʰÒôģʽ
ÊÖÑ¡µÄ3΢Ã×1 ¡°»Æ½ð½¦É佺ÄÒÓëÐÄÐÎʰÒôģʽÌṩÁËÀëÖáÉùÒôÓÅÁ¼µÄÒÖÖÆ
µÍÔëÉù
×Ô¶¨Òåµç×èµ¼ÖµÍÔëÒô¸É¾»µÄÐźÅ·¾¶
¸ßÉùѹ¼¶
Âó¿Ë·çµÄ¸ßÉùѹ¼¶ÄÜÁ¦£¬¿ÉÒÔÈÃÄúÂ¼ÖÆÏìÁÁÉùÔ´²»Ê§Õæ
Åä¼þ°üÀ¨
Ò»¸öÖØÐÍ·ÉÐÐÏäºÍµ¯ÐÔ¼õÕð¼Ü°üÀ¨
µçÈÝʽ´«¸ÐÆ÷
ʰÒôģʽÐÄÐÎ
ƵÂÊÏìÓ¦20Hz - 20kHzµÄ
ÁéÃô¶È-39·Ö±´
×î´óÉùѹ¼¶£¨ SPL £© 125·Ö±´
Êä³ö×迹550Å·Ä·
Êä³öÁ¬½ÓÆ÷3ÕëXLR¹«
ÍâÐγߴ磨 LxDiameter £© 7.6 ¡Á2¡° £¨ 193 x 51ºÁÃ×£©
ÖØÁ¿1°õ£¨ 453¿Ë£©
ιþΤÒôƵMA- 201fet´óÕñĤ¹Ì̬µçÈÝ»°Í²
º½¿ÕÏä
¼õÕð¼Ü
Mojave Audio MA-201fet Features:
Hand-selected 3-micron 1" capsule
Jensen audio transformer
Military-grade FET
Custom designed low-noise resistors
Ultra clean signal path
Transducer Type: Externally polarized pressure gradient capacitor
Diaphragm: 1-inch diameter, gold sputtered
Diaphragm Thickness: 3-micron
Polar Pattern: Cardioid
Frequency Response: 20Hz-20kHz, + 3dB
Sensitivity: -39dB re. 1V/pa
Maximum SPL: 125dB
Distortion: <1% @120dB SPL, <3% @134dB SPL
Self Noise: 14dB nominal, not to exceed 16dB (A weighted)
Impedance: 550 ohms, transformer balanced (Jensen)
Powering: 48VDC phantom power; current .68mA.
Carrying case with microphone, shock mount: 10" x 9" x 4.5", 4 lbs.
Microphone: 7-5/8" x 2", 1 lb.
Microphone Type
Condenser
Polar Pattern
Cardioid
Diaphragm Size
1" (25.4mm)
Frequency Response
20Hz-20kHz
Max SPL
125dB SPL
Output Impedance
550 ohms
Signal to Noise Ratio
80dB (A weighted)
Self Noise
14dB
Black
Connector
XLR
Weight
1 lbs.
Included Accessories
Shock mount, Carry case
