Acon Digital Acoustica Premium ¸ß¼¶ÒôƵ´¦ÀíÈí¼þ
8058453
2020-5-23 22:10:33
Èí¼þ
Acon Digital Media Acoustica PremiumÊÇÒôƵ±à¼­ºÍĸ´ø´¦ÀíµÄÀíÏë½â¾ö·½°¸¡£¸Ã³ÌÐò°üº¬´´½¨¾«ÃÀµÄ¼ÒôºÍÒôƵCDËùÐèµÄÒ»ÇУ¬°üÀ¨ÓÃÓڼǼ£¬·ÖÎö£¬±à¼­ºÍCD¿Ì¼µÄרҵ¹¤¾ß¡£ AcousticaÓû§½çÃæÔÚÉè¼ÆÊ±¿¼ÂÇÁËËÙ¶È£¬×¼È·ÐÔºÍÒ×ÓÃÐÔ¡£Ö§³Ö¸ß´ï32λµÄÒôƵ·Ö±æÂʺ͸ߴï192 kHzµÄ²ÉÑùÂÊ£¬Ê¹ÄúÄܹ»ÒÔ¾ªÈ˵ÄÒôƵÖÊÁ¿½øÐÐÂ¼ÖÆºÍ±à¼­¡£
AcousticaÌṩÈýÖÖ°æ±¾-Ãâ·ÑµÄ»ù±¾°æ£¬±ê×¼°æºÍ¸ß¼¶°æ£¬Ö§³Ö5.1ºÍ7.1ÉùµÀ»·ÈÆ£¬²¢°üÀ¨À©Õ¹µÄ´¦Àí¹¤¾ßºÍÓëRestoration SuiteÖÐÏàͬµÄÒôƵ»Ö¸´Ëã·¨¡£
ÖÕ¼«ÒôÖÊ
AcousticaÖ§³Ö×î¸ß32λµÄ×îÐÂÒôƵ·Ö±æÂʺÍ×î¸ß384 kHzµÄ²ÉÑùÂÊ£¬´Ó¶øÈ·±£ÄúµÄËùÓй¤×÷¶¼´ïµ½×î¸ßÖÊÁ¿¡£ Acoustica Premium EditionÉõÖÁÖ§³Ö¶àÉùµÀÒôÆµÂ¼ÖÆºÍ±à¼­£¬ÀýÈç5.1ºÍ7.1»·ÈÆÉù¡£
ÒôƵ»¹Ô­
¼¯³ÉµÄÒôƵ»Ö¸´¹¤¾ß¿É°ïÖúÄú³ä·ÖÀûÓÃÓÉÓÚ±³¾°ÔëÒô£¬ßÇàªÉù£¬crackžÉù£¬¼ô¼­»òȱÉÙ¸ßÆµÄÚÈݶøÊÜËðµÄ¼Òô¡£¸ß¼¶°æ°üº¬ÓëÎÒÃǵĻָ´Ì×¼þÏàͬµÄרҵ¹¤¾ß¼¯¡£
¶à¹ì±à¼­
AcousticaµÄй¦ÄÜÊÇ¿ÉÒԱ༭¶à¹ìÒôƵ¡£±ê×¼°æºÍ¸ß¼¶°æ¶¼ÔÊÐíÄúʵʱ»ìºÏÀ´×Ô²»Í¬Òô¹ìµÄÒôƵ£¬ÎªÒô¹ìÌí¼ÓÒôƵЧ¹û»òÇáËÉ´´½¨½»²æ½¥±ä¡£ÄúÉõÖÁ¿ÉÒÔÖ±½Ó´Ó¶à¹ìʱ¼äÏßÑ­»·»òÀ­ÉìÆ¬¶Î¡£
¼Ó¹¤¹¤¾ß
¼¯³ÉÁ˸ßÖÊÁ¿µÄÒôƵ¹¤¾ßºÍЧ¹û£¬ÀýÈ綯̬´¦Àí£¬ÏÞÖÆÆ÷£¬¾ùºâ£¬»ìÏ죬¾í»ý»ìÏ죬ºÏ³ªºÍÏâ±ß¡£Äú»¹¿ÉÒÔʹÓÃÓÅÖʵÄʱ¼äÀ­ÉìºÍÒÆµ÷¹¤¾ßÀ´¶ÀÁ¢ÐÞ¸ÄÂ¼ÖÆµÄËٶȺͼü¡£
Ч¹ûÁ´ºÍ²å¼þÖ§³Ö
Äú¿ÉÒÔ´´½¨ÍêÕûµÄ´¦Àí¹¤¾ßÁ´£¬°üÀ¨Íⲿ²å¼þ£¬²¢½«ËüÃÇÓëËùÓвÎÊýÉèÖÃÒ»Æð±£´æÒÔ±¸ºóÓᣠVSTºÍDirectX²å¼þÖ§³ÖʹÄú¿ÉÒÔÖ±½Ó´ÓAcoustica·ÃÎÊ´óÁ¿Ãâ·ÑºÍÉÌÒµµÚÈý·½ÒôƵ´¦Àí²å¼þ¡£
·ÖÎö¹¤¾ß
Ç¿´óµÄÀëÏß·ÖÎö¹¤¾ß¿ÉÓ㬰üÀ¨ÆµÆ×£¬ÆµÆ×ͼºÍС²¨·ÖÎö¡£ÊµÊ±·ÖÎöÒÇ£¬ÀýÈçK-Systemµçƽ±í£¬ÏàλÏà¹ØÒÇºÍÆµÆ×·ÖÎöÒÇ£¬Ê¹Äú¿ÉÒÔÔڻطŹý³ÌÖÐʵʱ¿ÉÊӵؼàÊÓÒôƵÊä³ö¡£
Ö÷Ò³
https://acondigital.com/
Acon Digital Media Acoustica Premium is an ideal solution for audio editing and mastering. The program contains everything you need to create great sounding recordings and audio CDs, including professional tools for recording, analysis, editing and CD burning. The Acoustica user interface was designed with speed, accuracy and ease of use in mind. The support for audio resolutions up to 32 bit and sampling rates up to 192 kHz allows you to record and edit in an amazing audio quality.
Acoustica is available in three editions ¨C the free Basic Edition, the Standard Edition and the Premium Edition which supports 5.1 and 7.1 channel surround and includes extended processing tools and the same audio restoration algorithms as found in our Restoration Suite.
Ultimate Audio Quality
Acoustica offers support for state-of-the-art audio resolutions up to 32 bit and sampling rates up to 384 kHz, ensuring that all of your work comes across at the highest quality. Acoustica Premium Edition even supports multichannel audio recording and editing such as 5.1 and 7.1 surround sound.
Audio Restoration
Integrated audio restoration tools help you get the most out of recordings impaired by background noise, clicks, crackle, clipping or missing high frequency content. The Premium Edition contains the same set of professional tools as our Restoration Suite.
Multitrack Editing
New in Acoustica is the ability to edit multitrack audio. Both the Standard and the Premium Edition allows you to mix audio from different tracks in real-time, add audio effects to tracks or easily create cross-fades. You can even loop or time stretch clips directly from the multitrack timeline.
Processing Tools
High quality audio tools and effects are integrated such as dynamic processing, limiter, equalizing, reverb, convolution reverb, chorus and flanger. You can also modify tempo and key of your recordings independently using the superb quality time stretching and transpose tools.
Effect Chains and Plug-In Support
You can create complete chains of processing tools, including external plug-ins, and save them along with all the parameter settings for later use. VST and DirectX plug-in support allows you to access a vast number of both free and commercial third party audio processing plug-ins directly from Acoustica.
Analysis Tools
Powerful offline analysis tools are available, including spectrum, spectrogram and wavelet analysis. Real-time analyzers such as K-System level meters, phase correlation meters and spectrum analyzers allow you to monitor your audio output visually in real time during playback.
Homepage
File size: 55 MB
