查看: 25431|回复: 0
[软件] Hit n Mix Infinity 4.5.1 x64 Win
发表于 2020-5-21 19:20:26 | 显示全部楼层 |阅读模式
Hit’n’Mix Infinity不仅仅是另一个音频编辑器。 可能性是无止境! 解锁音频。 处理构成音频的实际音符,和声和打击乐声音。 在波形和频谱上没有困难的编辑。
您可以:
将完全流畅的音高变化应用于立体声混音中的音符,甚至将其从其他声音中克隆出来。
以手术精度清理单个谐波。
在人声和乐器上添加逼真的声音和声。
使用Audioshop®工具进行详细的编辑。
在音高,水平,平移等上运行自动化脚本。
而且,它适合大多数DAW的工作流程,例如Pro Tools,Logic Pro X,Ableton Live和FL Studio。
平台:WiN64-EXE / AAX
Hit’n’Mix Infinity isn’t just another audio editor. The possibilities are endless! Unlock audio. Work with the actual notes, harmonics and percussive sounds that audio is constructed from. No difficult edits on waveforms and frequency spectrums.
You can:
Apply completely fluid pitch changes to notes in stereo mixes, even clone them from other sounds.
Clean up individual harmonics with surgical precision.
Add realistic sounding harmonies to vocals and instruments.
Make detailed edits with Audioshop® tools.
Run automated scripts on pitch, levels, panning and more.
What’s more, it fits within the workflow of most DAWs such as Pro Tools, Logic Pro X, Ableton Live and FL Studio.
File size: 25 MB
Platform: WiN64 – EXE/AAX
https://filecr.com/windows/hit-n-mix-infinity/
GMT+8, 2025-9-18 11:57 , Processed in 0.028843 second(s), 9 queries , Redis On.
