Õ𺳽»Ïì²ÉÑù ¨C Bunker 8 Digital Labs Symphonic Intense 5 MULTiFORMAT-DECiBEL
¡° Symphonic Intense 5¡±ÊÇÆù½ñΪֹ¡° Symphonic Intense¡±ÏµÁÐÖÐ×î´óµÄϵÁС£Ê®¸öÍêÕûµÄ¹¹½¨Ì×¼þ£¬³¬¹ý397¸öÎļþ£¬¶¥²¿ÓÐ3.27 GBµÄÐÂÏÊÉöÉÏÏÙËØÒýÆðµÄ½»ÏìÀÖ°²ÅÅ¡£
¡° Symphonic Intense 5¡±¾ßÓдóÌáÇÙ£¬µÍÒôÌáÇÙ£¬Ô²ºÅ£¬Ð¡ºÅ£¬¹ÏÒ²¿·Ö/ËÄÖØ×࣬µÍÒôÌáÇÙÉî³Á£¬²ü¶¯µÄµÍÒôÒôÉ«£¬ÄúÐèÒªµÄÒ»ÇÐÒÔ¼°ÔÚÑÝʾÒô¹ìÖÐÌýµ½µÄÒ»Çж¼ÔÚ´ËÊÕ²ØÖС£ÊµÊ±¹ìµÀÒÑÓë²ÉÑùÀÖÆ÷ÎÞ·ìµØÄöºÏ£¬²¢ÇÒÿ¸ö¹¹ÔìÌ×¼þÖеÄËùÓÐÁã¼þ¶¼°üº¬ÍêÕûµÄMIDIÎļþ¡£ÕâЩÌ×¼þ¿ÉËæÊ±ÓÃÓÚÄúµÄÍϳµ£¬¿ìËÙ¼üÌáʾ£¬±³¾°ÒDZíµÈ¡£Ëü¼ÈʵÓÃÓÖÔʼ¡£
ÿ¸öÌ×¼þ¶¼´øÓÐÑ»·£¬È«¾¥ºÍMIDIÎļþ¡£Äú½«Äܹ»ÔÚ¼¸·ÖÖÓÄڷֽ⣬°²ÅÅ£¬±à¼ºÍ¹¹½¨×Ô¼ºµÄ»ìÒôºÍ°²ÅÅ¡£
Ñ»·£ºÍ¨¹ý×Ô¶¨Òå±à¼£¬µ÷ƽºÍEQ·Ö½âµÄÿ¸öÒô¹ì£¬Ã¿¸öÖ÷¸ÉÔªËØ¶¼ÓÐ16ÌõÑ»·µÄ¸Ë×é¡£ÄúÐèÒª×öµÄ¾ÍÊǽ«ËüÃÇ·ÅÈëÄúϲ»¶µÄÒôƵ±à¼Æ÷£¬DAW»ò²ÉÑùÆ÷ÖС£ÕâЩѻ·¶¼ÊÇ¿çÆ½Ì¨¼æÈݵģ¬Òò´ËÎÞÂÛÄúÐèÒªWAVÎļþ»¹ÊÇAIFFÎļþ£¬Bunker 8¶¼¿ÉÒÔÂú×ãÄúµÄÒªÇó¡£
ÍêÕûµÄÀÖÆ÷×飺¼±ÓÚ´´½¨Ò»Ð©ÑÝʾ°²ÅÅÂ𣿽öÐèÒªÄúϲ»¶µÄÑ»·¼¯ÖеÄ×Ö·û´®£¿ÊÇ·ñÏëÔÚ¶à¸ö¹¹½¨Ì×¼þÖпìËÙ»ìºÏºÍÆ¥Åä¶øÎÞÐèÉèÖÃ×é²¢¼ÓÔØÒ»¶Ñ²»ÐèÒªµÄÑ»·£¿¶ÔÓÚBunker 8À´Ëµ£¬ËüÃÇÊǶÀÒ»ÎÞ¶þµÄ£¬¿ÉΪÀÖÍŵÄËùÓÐÖ÷Òª²¿·ÖÌṩÍêÕûµÄÖ÷Òô£¬°üÀ¨µ¥¶ÀµÄ´ò»÷ÀÖ£¬µÍÒôºÍ¹ÄÉù²¿·Ö¡£
MIDI£ºÃ¿¸ö¹¹½¨Ì×¼þ¶¼Å䱸ÁËÍêÕûµÄMIDI°²ÅÅ£¬Òò´ËÄú¿ÉÒÔÉîÈëÍÚ¾òÿ¸ö²¿·ÖµÄ¸´ÔÓÐÔ£¬²¢°´×Ô¼ºµÄϲºÃ¶ÔÆä½øÐÐ×Ô¶¨Òå¡£´ÓMIDI²¿¼þÖÆ×÷еÄÒô¹ì£¬Ìí¼ÓеıàÅÅ£¬ËæÒâ½øÐÐתÖ㬶ø²»»áÔì³É´Ì¶úµÄÉùÒô»òÆæ¹ÖµÄʱ¼äÀÉìαӰ¡£Õâ¸ö¼¯ºÏʹһÇгÉΪ¿ÉÄÜ¡£
²úÆ·ÏêÇ飺
-10¸ö¹¹½¨Ì×¼þ£¨±êÓÐKeyºÍBPMµÄ±êÇ©£©
-×ܹ²397¸öÎļþ
-10¸öMIDI¹¹ÔìÌ×¼þ°²ÅÅ
-24λÒôƵÖÊÁ¿£¨WAV£¬AIFF£©
-100£¥Ãâ°æË°µÄÄÚÈÝ
Ö÷Ò³
https://www.bunker8.com/products/cinematic/symphonic-intense-5/
¡®Symphonic Intense 5¡¯ is the largest collection in the ¡°Symphonic Intense¡± series to date. Ten full Construction Kits, over 397 files, 3.27 GB of fresh, over the top, adrenaline inducing symphonic arrangements.
¡®Symphonic Intense 5¡¯ features cellos, double bass, French horns, trumpets, bowed string sections/quartets, deep sub basses, throbbing sub sonic arps, everything you need and everything you hear in the demo tracks is in this collection. The live tracks have been seamlessly meshed with sampled instruments and full MIDI files have been included for all the parts in each Construction Kit. These Kits are ready to go for your trailers, fast action key cues, background instrumentation, etc. This is as versatile and pristine as it gets.
Each Kit comes with Loops, Full Stems and MIDI files. You will be able to break down, arrange, edit and construct your own mixes and arrangements in minutes.
Loops: 16 bar loop sets of every stem element for every track broken down with custom editing, leveling, and EQ. All you need to do is drop these into your favorite audio editor, DAW or sampler. These loops are all cross-platform compatible, so whether you need WAV files or AIFF Files, Bunker 8 got you covered.
Full Instrument Groups: In a hurry to create some demo arrangements? Need just the strings from your favorite loop set? Want to mix and match quickly across multiple Construction Kits without having to set up groups and load a bunch of loops that you don¡¯t need? Unique to Bunker 8, they supply complete bus stems of all the major sections of the orchestra, including separate groups of percussion, bass and drum parts.
MIDI: Each one of the Construction Kits comes with a full MIDI arrangement set aside so that you can dig deep into the intricacies of each of the parts and customize it the way you like. Make new tracks from the MIDI parts, add new arrangements, transpose at will without undo harshness or strange time stretch artifacts. This collection makes it all possible.
Product Details:
¨C 10 Construction Kits (Key & BPM Labelled)
¨C 397 Files in Total
¨C 10 MIDI Construction Kit Arrangements
¨C 24-Bit Audio Quality (WAV, AIFF)
¨C 100% Royalty-Free Content
0eam DECiBEL | 09 May 2020 | 2.82GB
home page
https://www.bunker8.com/products/cinematic/symphonic-intense-5/ |
