查看: 21497|回复: 1
[其他] FL Studio Sylenth1 and Serum Presets
发表于 2020-5-7 21:35:07 | 显示全部楼层 |阅读模式
" k, ?6 [5 s1 a' j( vW. A. Production What About Dubstep Muscle WAV MiDi FL Studio Sylenth1 and Serum Presets9 }, ?" Y6 A3 a9 c' `0 R/ i
3 D4 Y0 D$ D  W
1.5 GB
* C7 t8 m# H) t) G2 V. ZWe are calling out to all you headbangers. Give your Dubstep a little something extra. Check out What about: Dubstep Muscle from W. A. Production. Get ready to experience a supersonic powerhouse of sound. We are giving you harder hits, bone-chilling progressions, melodic build-ups, heavy-hitting drops, and crisp alterations that are sure to catch anyone that thinks they know what will come next by surprise.2 `) Z; b  L; o/ g( t. c2 {: e
If you are not familiar with Construction Kits they are a great tool for professionals on the go, beginners learning about song structure and audio production, or those looking to stay current on multiple genres.+ }1 d0 R$ o" H4 F% q
Our top-notch producers have designed the demo track you will hear in each kit. Inside the kit, you will find every sample, preset, MIDI trigger, and plugin used to create the track. Not only is it broken down into one hits. Each track has been broken down layer by layer in its entirety. This gives you full control to piece it together, modify, and create your own track. You will be able to see the advanced techniques they used in order to obtain a high-value production.
* m) s+ L9 f5 l: B; AEver wonder how they make a heavy hitting wobble or face melting bassline? Or how top producers get such amazing drum sounds? It’s all in Dubstep Muscle from W. A. Production.$ |( o3 \9 x- J
The Fine Print:
* l6 E! b2 M  h% X: TOur packs are created by experienced and professional producers that are affluent in the EDM scene. You can buy our packs with confidence as W. A. Production delivers the most unique and innovative sounds with the highest regard to audio quality.  m3 P  m: P# |: U
" X% L+ r+ h! VPack Contents:- \5 a! O! ?0 G: G6 H' T1 \! g
•6 Construction Kits (+ MIDI & Presets). Z- b' I* Z" p2 ~' t! Q% Q
•6 FL Studio Templates$ y# W, X' O( |# C7 j: o6 ?  j4 U
•16 Melody Loops (+ MIDI)7 B" s; H* K0 F4 G+ {" i: {6 M+ C
•20 Percussion Loops" S1 u8 r5 S' [& i0 v* d
•20 Serum Presets- `3 L- U1 x( P: I7 g
•21 Sylenth1 Presets" b8 {( c* w/ A" P# ^# W4 I
•12 FX* p5 Q3 ~) W" k
•20 Kicks
& r( ]+ C2 z( H% J•20 Snares+ h/ h8 u& J9 }4 H0 ]
•20 Percussion- f: \& g. X. P5 |
•30 Cymbals
4 m& E: v4 _$ y! {6 p0 y•100% Royalty Free
% a7 t& b4 n7 o
2 g( l, [7 S) _7 H" G, ahome page
/ Y* N# R  R) d, Y& g# q9 n% hhttp://bit.ly/2Yf76Dv
/ i6 h) t* N$ N# J1 e 2020年3月29日 00:16  预设采样  82  6
1150
发表于 2020-5-21 06:03:09 音频应用 | 显示全部楼层
分享一下,谢谢楼主
GMT+8, 2025-7-20 21:08 , Processed in 0.032180 second(s), 10 queries , Redis On.
