发表于 2020-5-7
|阅读模式
( w" p& j. ~) {# W3 t
Ableton Live 10 Suite v10.1.9 MacOSX
4 d; X9 f* u% B1 q& j7 L/ o/ b1 s2 b: j( t ; H. ]. G) D z+ |! {9 L
o' J- q0 V% z4 i# M! O
Ableton Live 是一款音乐制作软件, 允许用户以自然的方式作曲, 录音, remix(重混音), 即席创作和编辑自己的音乐构思. 可将声响, 电子和虚拟乐器及数字录音置于单一的界面中, 极其易用. 它使用户可以把全部精力集中到真正该关注的东西: 你自己的音乐上。: d/ F9 e6 d- J% h4 x6 ~% l# M2 }7 K
" D; p9 m* j9 v2 p: [Create bolder sounds with Live’s new devices. Stay in the flow with a multitude of workflow improvements. Do even more away from the computer with Push. Build your sound with a curated library. And get the unlimited potential of Max for Live, seamlessly built in.& _: Y6 Z0 o6 V* A
P+ ]& p8 ~" {* O C
Create with new devices9 J9 d, a* [, e& z$ R1 \
Meet Wavetable, Echo, Drum Buss and Pedal: new devices that mean colorful new sounds are possible with Live’s instruments and effects." u8 I. S: H. e
/ u# o0 G' I$ Y" N! n( i( ^3 ?
Wavetable5 G* H7 c& w) Y. ]
Immediately playable, infinitely capable, Wavetable is a new synthesizer built by Ableton. Shape, stretch and morph sounds using wavetables derived from analog synths, and a range of other instruments and sounds. Start sculpting sounds right away—even without a deep knowledge of synthesis—or explore its rich palette and potential through an intuitive interface.
5 J: K4 w# b0 z& E. R$ @6 \7 O
Echo
2 ~3 M; J, E" ~( vEcho brings together the sound of classic analog and digital hardware delays in a single device—your new go-to delay. Drive and shape sounds with its analog-modeled filters, turn up the noise and wobble for vintage imperfections, or add modulation and reverb to create diffuse soundscapes, wailing feedback and more./ ]! H: l- S8 N) w: Y
, W4 F+ [& T9 R. I& c
Drum Buss
L- l' W6 G8 T' YDrum Buss is a one-stop workstation for drums, capable of adding subtle character or bending and breaking drums to your will. Add warmth and distortion with drive and crunch, take control of dynamics with compression and transient shaping, dial in and tune boom and control bass decay with the dedicated low end section." Y M( _! N! b- I. _6 M: F' T- C
: J9 q$ @6 }5 Z% e# b& ?0 `
Pedal7 A6 k& [8 W1 X! e
With separate circuit-level models of overdrive, distortion and fuzz guitar pedals, Pedal brings the character of analog stomp boxes to Live. The effect goes all the way from subtle to reckless—it excels at warming up vocals and other instruments, driving synth sounds or completely smashing drums. And of course, it sounds great with guitars.
, N) _9 e1 P5 p* R1 B
$ S1 ~& l X x) W, x! ?10.0.4 Release Notes6 B( n p3 e. O! E* }' C8 [
New features and improvements:
. |$ l$ J: Y- ~$ d, ]6 q DIntroduced Control Surface support for Novation SL mkIII
& H" i5 l- K0 c% L. Z" ?+ U* UReintroduced the ability of defining a custom path for the Max application in Live’s preferences.
0 d& ^4 ?4 P- C# ^+ M) V* g6 ^9 r1 k2 W0 z% b
Bugfixes:
3 w" w# ~3 z6 g* e5 D; ^. ]In combination with older GPUs, Live’s splash screen and GUI might appear completely blank on Windows.3 u! z4 G; L+ P7 B0 I1 p) d
4 o: G- O- F+ m8 T% UMac
9 R( }0 ]" A% M. a" n6 ?; _; [; s' KOS X 10.11.6 or later (see compatibility notes on macOS Mojave here)1 [6 y( P: f0 C# R* g
Intel® Core™2 Duo processor. Intel® Core™ i5 processor or faster recommended.( _, V- r) M3 y3 q; V1 S3 o
4 GB RAM (8 GB or more recommended) |
