ÏÂÔØµØÖ·£ºhttps://www.audioba.com/ Ìí¼Ó΢ÐÅ»ñÈ¡£ºmiss-u77 Team R2R | 12 November 2019 | WiN: 672 MB | MAC: 690 MB home paqe :
https://cn.ikmultimedia.com/products/st4/?pkey=sampletank-4-max The new SampleTank 4 has been re-designed from the ground up to be every musician¡¯s ¡°go to¡± workstation for music creation, with a completely new rescalable interface, a massively expanded sample library and a new cutting-edge sound engine with efficient disk streaming, to deliver more powerful music creation tools than you ever imagined. What might usually take dozens of plug-ins can be accomplished right inside SampleTank 4, for lightning-fast workflow that keeps your inspiration going. Find any type of sound fast and tailor them to your needs with the new deep, powerful editing options and a new modulation matrix. New dynamic ¡°groove players¡± ¨C an arpeggiator, strummer, and pattern and loop players ¨C turn your sounds into songs faster than ever. Plus a new live mode makes SampleTank 4 the perfect performance partner, with the ability to create entire set lists and easily map every parameter just how you need it. Inspiring new sounds, powerful sound design features, advanced groove creation and tour-ready stage optimization. SampleTank 4 will take you wherever you want to go.
