´óС£º14.14 GB ¸ñʽ£ºKONTAKT ÊÊÓÃÆ½Ì¨£ºWin/Mac ¹ÙÍø£ºhttps://www.vsl.co.at/en/VI_Series/Symphonic_Cube ÏÂÔØ£ºhttp://www.audioba.com ΢ÐÅ£ºmiss-u77 ÃèÊö£º Chris Hein Horns ϵÁÐ͹ÜÀÖµÚËÄÌ×£¬More Brass n Woodwinds£¨¸ü¶à͹ÜÓëľ¹Ü£©ÒôÉ«¿â¡£Kontakt 4ÒôÉ«¿â¸ñʽ£¬°üº¬µÄǰÈý¸öϵÀàÖÐËùûÓеĸü¶à͹ÜÀÖÓëľ¹ÜÀÖÒôÉ«£¬Ò²°üº¬ºÜ¶àÑÝ×༼ÇÉ¡£ÕâËÄÌ××éºÏÔÚÒ»Æð¾ÍÊÇÍêÕûµÄChris Hein Horns ϵÁÐÒôÉ«¿âÁË¡£ Ó¢ÎÄ˵Ã÷£º Chris Hein Horns is an outstanding virtual sampled brass instrument library. With the release of CHH Vol.4, the Chris Hein Horns series is complete. It contain different groups of instruments perfectly matching each other. All instruments follow the same concept, so, if you know one, you know them all. Each volume contains solo-instruments as well as section combinations. Vol. 4 contains the following instruments2x Sax SopranSax-BassSax-ContraBassEb-ClarinetBb-ClarinetBass-ClarinetC-Bass-Clarinette4x Fluegelhorn2x TubaAlphornCimbasso9x Section-Combinations General Featuresaprox. 2.000 Samples per instrument18 different playing techniquesAll playing techniques in one programmUp to 8 Velocities per note72 control-features in 11 edit-pages6 DSP Efx21 high class convolution reverbsKey-Switch Presets, Hot-Keys, Key-Vibrato, Legato- and Glide-Mode, Growl-Control, and more ArticulationsThe large amount of up to 38 articulations is what makes "Chris Hein - Horns " so realistic. All articulations can be assigned over 18 keyswitch-keys, located on the lower notes of the keyboard. Access to every articulation is made possible via an intuitive combination of keyswitches and midi-controllers. Key-switchesKeyswitching is an elegant means of enabling the user to directly and immediately access different playing techniques from within a single patch. It uses pre-programmed MIDI notes to instantaneously switch between different articulations, meaning it is no longer necessary to reload each variant individually. The keyswitches themselves are exclusively controller keys. They make no sound, but instead are used to switch the entire group of samples which the main instrument keys trigger. Format: NKI NKX NKC
