查看: 35515|回复: 1
[电子] ET2102电平转换2路电平转换IC,适用通讯电平转换, 开漏输入/输出.
发表于 2019-7-16 14:22:06 | 显示全部楼层 |阅读模式
ET2102
一般说明
在广泛的输入和输出电压电平范围内转换。ET2102也可在推挽式中工作。
该设备的设计使得A端口跟踪VCCA级别,B端口跟踪VCCB级别。这允许在1.65V到5.5V的任何两个电平之间进行双向A/B端口电压转换。VCCA可以等于1.65V到5.5V的VCCB。任何一个VCC都可以先通电。如果任何一个VCC被移除,内部断电控制电路将设备置于3状态。
Features
● Bi-Directional Interface between Any Two Levels:1.65V to 5.5V
● No Direction Control Needed
● Internal 10K Pull-Up Resistors
● System GPIO Resources Not Required when OE tied to VCCA
● I2C-Bus Isolation
● A/B Port VOL = 175mV (Typical), VIL = 150mV, IOL = 6mA
● Open-Drain Inputs / Outputs
● Works in Push Pull Environment
● Accommodates Standard-Mode and Fast-Mode I2C-Bus Devices
● Fully Configurable: Inputs and Outputs Track VCC
● Non-Preferential Power-Up; Either VCC Can Power-Up First
● Outputs Switch to 3-State if Either VCC is at GND
● Tolerant Output Enable: 5V
● Packaged in 8-Terminal Leadless Ultrathin QFN (1.2mm x 1.4mm)
Pin Configuration
2284
发表于 2019-7-17 07:11:47 音频应用 | 显示全部楼层
欣赏了,谢谢楼主
GMT+8, 2025-7-22 02:15 , Processed in 0.023664 second(s), 8 queries , Redis On.
