VST - VST3 - AAX | 252 MB
home pagehttps://www.bluecataudio.com/Products/Product_MB7Mixer/
Blue Cat's MB-7 Mixer is a unique plug-in that splits the signal into several frequency bands and lets you mix and process them as if they were separate tracks.
Each band proposes controls that can be found on a mixing console, and more: bypass, mute or solo each band separately to isolate frequencies you want to work on, adjust the gain, the "stereoness" and the position in the stereo field. When manipulating the stereo image, a master mono switch also lets you check mono compatibility.
You can also apply different audio effects to each band to achieve any kind of spectral manipulation: the plug-in can operate as a multiband plug-ins host. You can process each band independently with your favorite VST, VST3 or Audio Unit plug-ins or choose from any of the 28 built-in effects! Up to four plug-ins can be loaded on each band, pre or post fader. It also include 25 built-in audio effects that can be inserted in each plug-in slot. Latency compensation, presets management, undo/redo integration, and individual plug-in bypass are included for optimal operation.
The plug-in also proposes unique linking and grouping options thanks to our multi-instances technology. You can link bands together within a single instance or between several instances of the plug-in on different tracks. This lets a simple fader control as many bands on as many tracks as you want. This is particularly useful when adjusting the placement or the balance of several competing tracks.
And as usual with Blue Cat Audio, the plug-in provides comprehensive visual feedback to let you know what's exactly going on: for each channel, monitor the spectrum, the in/out levels and the frequency response.
Thanks to its advanced MIDI and automation input capabilities, when combined with our other plug-ins, Blue Cat's MB-7 Mixer is capable of advanced side-chaining features that really unveils its potential. Check out our MB-7 Mixer Tutorials for more details.
