NewBlue ¿ìËÙµ÷É«²å¼þ ColorFast £¨x86/x64£©
NewBlue ColorFast ÊÇÒ»¸ö¼¯³É¼òµ¥¹¤×÷Á÷³Ì£¬¼ò»¯É«²ÊУÕýºÍÉ«²Ê·Ö¼¶µÄ²å¼þ¡£Ê¹ÓÃÎÒÃǵĹâÆ×ÑÕÉ«·ÖÀë¼¼Êõ£¬Äã¿ÉÒÔ¾«È·¿ØÖÆÑÕÉ«µ÷Õû¡£ÔÚ¾«È·µÄÇøÓò£¬»òÔÚÕû¸öÊÓÆµÍ¼ÏñÉÏ´´½¨ÄúÏëÒªµÄÍâ¹Û¡£Äã¿ÉÒÔÔں̵ܶÄʱ¼äÄÚ£¬µÃµ½µÄÐèÒªÒÕÊõЧ¹û¡£
Primary Color Correction Features
Exposure ¡ª Raise or lower the overall image luminance, with no curve changes.
White balance with eyedropper ¡ª Use an active decolorize process to achieve precise white balance results throughout the image.
White correction strength ¡ª Manage how much active white balance is applied to leverage original lighting casts when needed.
Brightness ¡ª Control the higher end of the luminance curve without affecting black levels.
Film Gamma ¡ª Simulate film by widening the contrast range without crushing whites or blacks in the process.
Saturation ¡ª Add or reduce color intensity from B/W through full legal color limits.
More Features
Skin tone preservation ¡ª With just a few clicks, you can create a mask for skin tones and preserve those colors in your final image. Then you can make more extreme adjustments in other regions (think sky, grass, background) and they won't bleed into your protected skin tone.
Luminance isolation mask ¡ª ColorFast allows you to use custom Low, Mid, High (Lift, Gamma, Gain) range definitions so that you can precisely isolate luminance regions for specific adjustments.
Shape mask ¡ª Our four-point, roundable shape mask is more flexible than simple ellipse and rectangle power masks, and it's just as easy to set up. Combine this with the luminance masks and you have unlimited isolation possibilities.
NewBlue ¿ìËÙµ÷É«²å¼þ ColorFast £¨x86/x64£© - ZHLMI - Ò¡°Ú¡¤Ó°Òô
×¢£º²»ÒªÊ¹Óùٷ½ÏÂÔØµÄԭʼ³ÌÐò°²×°£¬Ê¹ÓÃѹËõ°üÄڵݲװ³ÌÐò¡£
ÏÂÔØµØÖ·£º
http://dl.dbank.com/c0q40wozvt
NewBlue ¿ìËÙµ÷É«²å¼þNewblueFX Color Fastx86ºº»¯
http://www.dvedit.cn/thread-156304-1-1.html
¡¾An¾²de·ç ºº»¯¡¿NewBlue ¿ìËÙµ÷É«²å¼þ Color Fast (X64)¼òÌåÖÐÎĺº»¯
http://www.dvedit.cn/thread-156351-1-1.html
