×ܽ᣺»ªÎª¡¢H3C¡¢Èñ½ÝÈý¼Ò½»»»»úÅäÖÃÃüÁîÏê½â
Ò»Ö±ÒÔÀ´£¬¶ÔÓÚ»ªÎª¡¢H3C¡¢Èñ½Ý½»»»»úµÄÃüÁîÅäÖ㬲»¶ÏµÄÓÐÅóÓÑÁôÑÔ£¬Èý¼Ò½»»»»úµÄÅäÖÃÃüÁîÈÝÒ×Ū»ì£¬¾­³£ÔÚʵ¼ÊÏîÄ¿ÅäÖÃÖгö´í£¬Òò´Ë£¬±¾ÆÚÎÒÃǽ«À´½éÉÜÕâÈý¼Ò½»»»»úµÄ»ù´¡ÅäÖÃÃüÁ´ó¼Ò¿ÉÒÔ·Ö±ðÀ´¿´ÏÂËûÃǵÄÃüÁîÓÐʲô²»Í¬¡£
ΪÁËÈôó¼Ò¸ü¼ÓÇå³þ£¬Ã¿ÐдúÂë¶¼ÓнâÊÍ¡£
Ò»¡¢»ªÎª½»»»»ú»ù´¡ÅäÖÃÃüÁî
1¡¢´´½¨vlan£º
<Quidway>     //Óû§ÊÓͼ£¬Ò²¾ÍÊÇÔÚQuidwayģʽÏÂÔËÐÐÃüÁî¡£
<Quidway>system-view      //½øÈëÅäÖÃÊÓͼ
[Quidway] vlan 10       //´´½¨vlan 10£¬²¢½øÈëvlan10ÅäÖÃÊÓͼ£¬Èç¹ûvlan10´æÔÚ¾ÍÖ±½Ó½øÈëvlan10ÅäÖÃÊÓͼ
[Quidway-vlan10] quit     //»Øµ½ÅäÖÃÊÓͼ
[Quidway] vlan 100     //´´½¨vlan 100£¬²¢½øÈëvlan100ÅäÖÃÊÓͼ£¬Èç¹ûvlan10´æÔÚ¾ÍÖ±½Ó½øÈëvlan100ÅäÖÃÊÓͼ
[Quidway-vlan100] quit     //»Øµ½ÅäÖÃÊÓͼ
2¡¢½«¶Ë¿Ú¼ÓÈëµ½vlanÖУº
[Quidway] interface GigabitEthernet2/0/1    (10G¹â¿Ú)
[Quidway- GigabitEthernet2/0/1] port link-type access    //¶¨Òå¶Ë¿Ú´«Êäģʽ
[Quidway- GigabitEthernet2/0/1] port default vlan 100   //½«¶Ë¿Ú¼ÓÈëvlan100
[Quidway- GigabitEthernet2/0/1] quit       //»Øµ½ÅäÖÃÊÓͼ
[Quidway] interface GigabitEthernet1/0/0       //½øÈë1ºÅ²å²ÛÉϵĵÚÒ»¸öǧÕ×Íø¿ÚÅäÖÃÊÓͼÖС£0´ú±í1ºÅ¿Ú
[Quidway- GigabitEthernet1/0/0] port link-type access   //¶¨Òå¶Ë¿Ú´«Êäģʽ
[Quidway- GigabitEthernet2/0/1] port default vlan 10   //½«Õâ¸ö¶Ë¿Ú¼ÓÈëµ½vlan10ÖÐ
3¡¢½«¶à¸ö¶Ë¿Ú¼ÓÈëµ½VLANÖÐ
[Quidway]vlan 10
[Quidway-vlan10]port GigabitEthernet 1/0/0 to 1/0/29   //½«0µ½29ºÅ¿Ú¼ÓÈëµ½vlan10ÖÐ
[Quidway-vlan10]quit
4¡¢½»»»»úÅäÖÃIPµØÖ·
[Quidway] interface Vlanif100     // ½øÈëvlan100½Ó¿ÚÊÓͼÓëvlan 100ÃüÁî½øÈëµÄµØ·½²»Í¬
[Quidway-Vlanif100] ip address 119.167.200.90 255.255.255.252      // ¶¨Òåvlan100¹ÜÀíIPÈý²ã ½»»»Íø¹ØÂ·ÓÉ
[Quidway-Vlanif100] quit       //·µ»ØÊÓͼ
[Quidway] interface Vlanif10    // ½øÈëvlan10½Ó¿ÚÊÓͼÓëvlan 10ÃüÁî½øÈëµÄµØ·½²»Í¬
[Quidway-Vlanif10] ip address 119.167.206.129 255.255.255.128    // ¶¨Òåvlan10¹ÜÀíIPÈý²ã½»»»Íø¹ØÂ·ÓÉ
[Quidway-Vlanif10] quit
5¡¢ÅäÖÃĬÈÏÍø¹Ø£º
[Quidway]ip route-static 0.0.0.0 0.0.0.0 119.167.200.89 //ÅäÖÃĬÈÏÍø¹Ø¡£
6¡¢ ½»»»»ú±£´æÉèÖúÍÖØÖÃÃüÁî
<Quidway>save        //±£´æÅäÖÃÐÅÏ¢
<Quidway>reset saved-configuration     //ÖØÖý»»»»úµÄÅäÖÃ
<Quidway>reboot      //ÖØÐÂÆô¶¯½»»»»ú
7¡¢½»»»»ú³£ÓõÄÏÔʾÃüÁî
Óû§ÊÓͼģʽÏ£º
<Quidway>display current-configuration     //ÏÔʾÏÖÔÚ½»»»»úÕýÔÚÔËÐеÄÅäÖÃÃ÷ϸ
<Quidway>display device       //ÏÔʾ¸÷É豸״̬
<Quidway>display interface £¿    //ÏÔʾ¸ö¶Ë¿Ú״̬£¬Óã¿¿ÉÒԲ鿴ºó±ß¸úµÄÑ¡Ïî
<Quidway>display version      //²é¿´½»»»»ú¹Ì¼þ°æ±¾ÐÅÏ¢
<Quidway>display vlan £¿      // ²é¿´vlanµÄÅäÖÃÐÅÏ¢
8¡¢»Ö¸´½»»»»ú³ö³§ÉèÖÃ
¶þ¡¢H3C½»»»»úµÄ»ù±¾ÅäÖÃ
ÎÒÃÇÏÈÀ´Á˽âÏÂh3cµÄÅäÖÃÃüÁîÓ빦ÄÜ£¬¶¼Êdz£Óõ쬻ù±¾Éϴ󲿷ÖÍøÂçÅäÖö¼ÉÙ²»ÁËÕâЩÃüÁî¡£
1¡¢»ù±¾ÅäÖÃ
<H3C>           //Óû§Ö±ÐÐģʽÌáʾ·û,Óû§ÊÓͼ
<H3C>system-view        //½øÈëÅäÖÃÊÓͼ
[H3C] sysname xxx     //ÉèÖÃÖ÷»úÃû³ÉΪxxxÕâÀïʹÓÃÐÞ¸ÄÌØÈ¨Óû§ÃÜÂë
2¡¢Óû§ÅäÖÃ
<H3C>system-view
[H3C]super password H3C         //ÉèÖÃÓû§·Ö¼¶ÃÜÂë
[H3C]undo superpassword         //ɾ³ýÓû§·Ö¼¶ÃÜÂë
[H3C]localuser bigheap 1234561         //WebÍø¹ÜÓû§ÉèÖÃ,1Ϊ¹ÜÀí¼¶Óû§
[H3C]undo localuser bigheap        //ɾ³ýWebÍø¹ÜÓû§
[H3C]user-interface aux 0         //Ö»Ö§³Ö0
[H3C-Aux]idle-timeout 250         //ÉèÖó¬Ê±Îª2·Ö50Ãë,ÈôΪ0Ôò±íʾ²»³¬Ê±,ĬÈÏΪ5·ÖÖÓ
[H3C-Aux]undoidle-timeout         //»Ö¸´Ä¬ÈÏÖµ
[H3C]user-interface vty 0         //Ö»Ö§³Ö0ºÍ1
[H3C-vty]idle-timeout 250         //ÉèÖó¬Ê±Îª2·Ö50Ãë,ÈôΪ0Ôò±íʾ²»³¬Ê±,ĬÈÏΪ5·ÖÖÓ
[H3C-vty]undoidle-timeout         //»Ö¸´Ä¬ÈÏÖµ
[H3C-vty]set authentication password123456         //ÉèÖÃtelnetÃÜÂë,±ØÐëÉèÖÃ
[H3C-vty]undo set authenticationpassword      //È¡ÏûÃÜÂë
[H3C]displayusers         //ÏÔʾÓû§
[H3C]displayuser-interface         //Óû§½çÃæ×´Ì¬
3¡¢vlanÅäÖÃ
[H3C]vlan 2                //´´½¨VLAN2
[H3C]undo vlanall         //ɾ³ý³ýȱʡVLANÍâµÄËùÓÐVLAN,ȱʡVLAN²»Äܱ»É¾³ý
[H3C-vlan2]port Ethernet 0/4 to Ethernet0/7         //½«4µ½7ºÅ¶Ë¿Ú¼ÓÈëµ½VLAN2ÖÐ,´ËÃüÁîÖ»ÄÜÓÃÀ´¼Óaccess¶Ë¿Ú,²»ÄÜÓÃÀ´Ôö¼Ótrunk»òÕßhybrid¶Ë¿Ú
[H3C-vlan2]port-isolate enable       //´ò¿ªVLANÄڶ˿ڸôÀëÌØÐÔ£¬²»Äܶþ²ãת·¢,ĬÈϲ»ÆôÓøù¦ÄÜ
[H3C-Ethernet0/4]port-isolate uplink-portvlan 2       //ÉèÖÃ4ΪVLAN2µÄ¸ôÀëÉÏÐж˿ڣ¬ÓÃÓÚת·¢¶þ²ãÊý¾Ý,Ö»ÄÜÅäÖÃÒ»¸öÉÏÐж˿Ú,ÈôΪtrunk,Ôò½¨ÒéÔÊÐíËùÓÐVLANͨ¹ý,¸ôÀë²»ÄÜÓë»ã¾ÛͬʱÅäÖÃ
[H3C]display vlan all         //ÏÔʾËùÓÐVLANµÄÏêϸÐÅÏ¢
[H3C]user-group 20         //´´½¨user-group 20£¬Ä¬ÈÏÖ»´æÔÚuser-group 1
[H3C-UserGroup20]port Ethernet 0/4 toEthernet 0/7         //½«4µ½7ºÅ¶Ë¿Ú¼ÓÈëµ½VLAN20ÖУ¬³õʼʱ¶¼ÊôÓÚuser-group 1ÖÐ
[H3C]display user-group 20         //ÏÔʾuser-group 20µÄÏà¹ØÐÅÏ¢
ËÄ¡¢½»»»»úipÅäÖÃ
[H3C]vlan 20                //´´½¨vlan
[H3C]management-vlan 20          //¹ÜÀívlan
[H3C]interface vlan-interface 20         //½øÈë²¢¹ÜÀívlan20
[H3C]undo interface vlan-interface 20         //ɾ³ý¹ÜÀíVLAN¶Ë¿Ú
[H3C-Vlan-interface20]ip address192.168.1.2 255.255.255.0      //ÅäÖùÜÀíVLAN½Ó¿Ú¾²Ì¬IPµØÖ·
[H3C-Vlan-interface20]undo ipaddress         //ɾ³ýIPµØÖ·
[H3C-Vlan-interface20]ip gateway 192.168.1.1         //Ö¸¶¨È±Ê¡Íø¹Ø(ĬÈÏÎÞÍø¹ØµØÖ·)
[H3C-Vlan-interface20]undo ip gateway
[H3C-Vlan-interface20]shutdown        //¹Ø±Õ½Ó¿Ú
[H3C-Vlan-interface20]undo shutdown         //¿ªÆô
[H3C]display ip         //ÏÔʾ¹ÜÀíVLAN½Ó¿ÚIPµÄÏà¹ØÐÅÏ¢
[H3C]display interface vlan-interface20         //²é¿´¹ÜÀíVLANµÄ½Ó¿ÚÐÅÏ¢
<H3C>debugging ip         //¿ªÆôIPµ÷ÊÔ¹¦ÄÜ
<H3C>undo debugging ip
5¡¢DHCP¿Í»§¶ËÅäÖÃ
[H3C-Vlan-interface20]ip address dhcp-alloc        // ¹ÜÀíVLAN½Ó¿Úͨ¹ýDHCP·½Ê½»ñÈ¡IPµØÖ·
[H3C-Vlan-interface20]undo ip address dhcp-alloc        // È¡Ïû
[H3C]display dhcp        //ÏÔʾDHCP¿Í»§ÐÅÏ¢
<H3C>debugging dhcp-alloc         //¿ªÆôDHCPµ÷ÊÔ¹¦ÄÜ
<H3C>undo debugging dhcp-alloc
6¡¢¶Ë¿ÚÅäÖÃ
[H3C]interface Ethernet0/3             //½øÈë¶Ë¿Ú
[H3C-Ethernet0/3]shutdown           //¹Ø±Õ¶Ë¿Ú
[H3C-Ethernet0/3]speed 100         //ËÙÂÊ¿ÉΪ10,100,1000ºÍauto(ȱʡ)
[H3C-Ethernet0/3]duplexfull         //Ë«¹¤,¿ÉΪhalf,fullºÍauto£¬¹â¿ÚºÍ»ã¾Ûºó²»ÄÜÅäÖÃ
[H3C-Ethernet0/3]flow-control        //¿ªÆôÁ÷¿Ø£¬Ä¬ÈÏΪ¹Ø±Õ
[H3C-Ethernet0/3]broadcast-suppression 20         //ÉèÖÃÒÖÖÆ¹ã²¥°Ù·Ö±ÈΪ20%,¿ÉÈ¡5,10,20,100,ȱʡΪ100,ͬʱ×é²¥ºÍδ֪µ¥²¥Ò²ÊÜ´ËÓ°Ïì
[H3C-Ethernet0/3]loopback internal         //ÄÚ»·²âÊÔ
[H3C-Ethernet0/3]port link-type trunk         //ÉèÖÃÁ´Â·µÄÀàÐÍΪtrunk
[H3C-Ethernet0/3]port trunk pvid vlan 20         //ÉèÖÃ20Ϊ¸ÃtrunkµÄȱʡVLAN£¬Ä¬ÈÏΪ1(trunkÏß·Á½¶ËµÄPVID±ØÐëÒ»ÖÂ)
[H3C-Ethernet0/3]port access vlan 20         //½«µ±Ç°access¶Ë¿Ú¼ÓÈëÖ¸¶¨µÄVLAN
[H3C-Ethernet0/3]port trunk permit vlanall         //ÔÊÐíËùÓеÄVLANͨ¹ýµ±Ç°µÄtrunk¶Ë¿Ú,¿É¶à´ÎʹÓøÃÃüÁî
[H3C-Ethernet0/3]mdiauto         //ÉèÖÃÒÔÌ«¶Ë¿ÚΪ×Ô¶¯¼à²â,normalΪֱͨÏß,acrossΪ½»²æÏß
[H3C]link-aggregation Ethernet 0/1 toEthernet 0/4         //½«1-4¿Ú¼ÓÈë»ã¾Û×é,1ΪÖ÷¶Ë¿Ú,Á½¶ËÐèҪͬʱÅäÖÃ,ÉèÖÃÁ˶˿ھµÏñÒÔ¼°¶Ë¿Ú¸ôÀëµÄ¶Ë¿ÚÎÞ·¨»ã¾Û
[H3C]undo link-aggregation Ethernet 0/1     //ɾ³ý¸Ã»ã¾Û×é
[H3C]link-aggregation mode egress         //ÅäÖö˿ڻã¾ÛģʽΪ¸ù¾ÝÄ¿µÄMACµØÖ·½øÐиººÉ·Öµ£,¿ÉѡΪ  ingress,egressºÍboth,ȱʡΪboth
[H3C]monitor-port Ethernet 0/2         //½«¸Ã¶Ë¿ÚÉèÖÃΪ¾µÏñ¶Ë¿Ú,±ØÐëÏÈÉèÖþµÏñ¶Ë¿Ú,ɾ³ýʱ±ØÐëÏÈɾ³ý±»¾µÏñ¶Ë¿Ú,¶øÇÒËüÃDz»ÄÜͬÔÚÒ»¸ö¶Ë¿Ú,¸Ã¶Ë¿Ú²»ÄÜÔÚ»ã¾Û×éÖÐ,ÉèÖÃоµÏñ¶Ë¿Úʱ,ÐÂÈ¡´ú¾É,±»¾µÏñ²»±ä
[H3C]mirroring-port Ethernet 0/3 toEthernet 0/4 both         //½«¶Ë¿Ú3ºÍ4ÉèÖÃΪ±»¾µÏñ¶Ë¿Ú,bothΪͬʱ¼à¿Ø½ÓÊպͷ¢Ë͵ı¨ÎÄ,inbound±íʾ½ö¼à¿Ø½ÓÊյı¨ÎÄ,outbound±íʾ½ö¼à¿Ø·¢Ë͵ı¨ÎÄ
[H3C]display mirror
[H3C]display interface Ethernet 0/3
<H3C>resetcounters         //Çå³ýËùÓж˿ڵÄͳ¼ÆÐÅÏ¢
[H3C]display link-aggregation Ethernet0/3         //ÏÔʾ¶Ë¿Ú»ã¾ÛÐÅÏ¢
[H3C-Ethernet0/3]virtual-cable-test        //Õï¶Ï¸Ã¶Ë¿ÚµÄµç·״¿ö
7¡¢qosÓÅÏȼ¶ÅäÖÃ
  QoSÅäÖò½Ö裺ÉèÖö˿ڵÄÓÅÏȼ¶,ÉèÖý»»»»úÐÅÈα¨ÎĵÄÓÅÏȼ¶·½Ê½,¶ÓÁе÷¶È,¶Ë¿ÚÏÞËÙ
[H3C-Ethernet0/3]priority 7         //ÉèÖö˿ÚÓÅÏȼ¶Îª7£¬Ä¬ÈÏΪ0
[H3C]priority-trustcos         //ÉèÖý»»»»úÐÅÈα¨ÎĵÄÓÅÏȼ¶·½Ê½Îªcos(802.1pÓÅÏȼ¶,ȱʡֵ),»¹¿ÉÒÔÉèΪdscp·½Ê½
[H3C]queue-scheduler hq-wrr 2 4 6 8         //ÉèÖöÓÁе÷¶ÈË㷨ΪHQ-WRR(ĬÈÏΪWRR),È¨ÖØÎª2,4,6,8
[H3C-Ethernet0/3]line-rate inbound 29      //½«¶Ë¿Ú½ø¿ÚËÙÂÊÏÞÖÆÎª2Mbps,È¡1-28ʱ,ËÙÂÊΪrate*8*1024/125,¼´64,128,192...1.792M£»
29-127ʱ,ËÙÂÊΪ(rate-27)*1024,¼´2M,3M,4M...100M¡£
[H3C]displayqueue-scheduler         //ÏÔʾ¶ÓÁе÷¶Èģʽ¼°²ÎÊý
[H3C]displaypriority-trust         //ÏÔʾÓÅÏȼ¶ÐÅÈÎģʽ
Èý¡¢Èñ½Ý½»»»»ú»ù´¡ÃüÁîÅäÖÃ
Á¬½ÓÉϽ»»»»úºó£¬¿Ï¶¨ÊÇÐèÒª½øÐÐÃüÁîÅäÖã¬ÎÒÃÇÀ´¿´Ï»ù´¡ÃüÁîÅäÖá£
1¡¢×¼±¸ÃüÁî
>Enable       //½øÈëÌØÈ¨Ä£Ê½
#Exit           //·µ»ØÉÏÒ»¼¶²Ù×÷ģʽ
#End            //·µ»Øµ½ÌØÈ¨Ä£Ê½
#copy running-config startup-config    //±£´æÅäÖÃÎļþ
#del flash:config.text    //ɾ³ýÅäÖÃÎļþ(½»»»»ú¼°1700ϵÁзÓÉÆ÷)
#erase startup-config    //ɾ³ýÅäÖÃÎļþ(2500ϵÁзÓÉÆ÷)
#del flash:vlan.dat    //ɾ³ýVlanÅäÖÃÐÅÏ¢£¨½»»»»ú£©
#Configure terminal    //½øÈëÈ«¾ÖÅäÖÃģʽ
(config)# hostname switchA    //ÅäÖÃÉ豸Ãû³ÆÎªswitchA
(config)#banner motd &       //ÅäÖÃÿÈÕÌáʾÐÅÏ¢ &ΪÖÕÖ¹·û
(config)#enable secret level 1 0 star    //ÅäÖÃÔ¶³ÌµÇ½ÃÜÂëΪstar
(config)#enable secret level 15 0 star   //ÅäÖÃÌØÈ¨ÃÜÂëΪstar
Level 1ΪÆÕͨÓû§¼¶±ð£¬¿ÉѡΪ1~15£¬15Ϊ×î¸ßȨÏÞ¼¶±ð£»0±íʾÃÜÂë²»¼ÓÃÜ
(config)#enable services web-server  //¿ªÆô½»»»»úWEB¹ÜÀí¹¦ÄÜ
Services ¿ÉÑ¡ÒÔÏ£ºweb-server(WEB¹ÜÀí)¡¢telnet-server(Ô¶³ÌµÇ½)µÈ
2¡¢²é¿´ÐÅÏ¢
#show running-config       //²é¿´µ±Ç°ÉúЧµÄÅäÖÃÐÅÏ¢
#show interface fastethernet 0/3   //²é¿´F0/3¶Ë¿ÚÐÅÏ¢
#show interface serial 1/2      //²é¿´S1/2¶Ë¿ÚÐÅÏ¢
#show interface                //²é¿´ËùÓж˿ÚÐÅÏ¢
#show ip interface brief          //ÒÔ¼ò½à·½Ê½»ã×ܲ鿴ËùÓж˿ÚÐÅÏ¢
#show ip interface         //²é¿´ËùÓж˿ÚÐÅÏ¢
#show version               //²é¿´°æ±¾ÐÅÏ¢
#show mac-address-table       //²é¿´½»»»»úµ±Ç°MACµØÖ·±íÐÅÏ¢
#show vlan                 //²é¿´ËùÓÐVLANÐÅÏ¢
#show vlan id 10          //²é¿´Ä³Ò»VLAN (ÈçVLAN10)µÄÐÅÏ¢
#show interface fastethernet 0/1   //²é¿´Ä³Ò»¶Ë¿Úģʽ(ÈçF 0/1)
#show aggregateport 1 summary    //²é¿´¾ÛºÏ¶Ë¿ÚAG1µÄÐÅÏ¢
#show spanning-tree      //²é¿´Éú³ÉÊ÷ÅäÖÃÐÅÏ¢
#show spanning-tree interface fastethernet 0/1   //²é¿´¸Ã¶Ë¿ÚµÄÉú³ÉÊ÷״̬
#show port-security     //²é¿´½»»»»úµÄ¶Ë¿Ú°²È«ÅäÖÃÐÅÏ¢
#show port-security address    //²é¿´µØÖ·°²È«°ó¶¨ÅäÖÃÐÅÏ¢
#show ip access-lists listname   //²é¿´ÃûΪlistnameµÄÁбíµÄÅäÖÃÐÅÏ¢
3¡¢¶Ë¿ÚµÄ»ù±¾ÅäÖÃ
(config)#Interface fastethernet 0/3          //½øÈëF0/3µÄ¶Ë¿ÚÅäÖÃģʽ
(config)#interface range fa 0/1-2,0/5,0/7-9     //½øÈëF0/1¡¢F0/2¡¢F0/5¡¢F0/7¡¢F0/8¡¢F0/9µÄ¶Ë¿ÚÅäÖÃģʽ
(config-if)#speed 10      //ÅäÖö˿ÚËÙÂÊΪ10M,¿ÉÑ¡10,100,auto
(config-if)#duplex full     //ÅäÖö˿ÚΪȫ˫¹¤Ä£Ê½,¿ÉÑ¡full(ȫ˫¹¤),half(°ë˫ʽ),auto(×ÔÊÊÓ¦)
(config-if)#no shutdown                    //¿ªÆô¸Ã¶Ë¿Ú
(config-if)#switchport access vlan 10     //½«¸Ã¶Ë¿Ú»®ÈëVLAN10ÖÐ,ÓÃÓÚVLAN
(config-if)#switchport mode trunk      //½«¸Ã¶Ë¿ÚÉèΪtrunkģʽ,¿ÉѡģʽΪaccess , trunk
(config-if)#port-group 1     //½«¸Ã¶Ë¿Ú»®Èë¾ÛºÏ¶Ë¿ÚAG1ÖÐ,ÓÃÓھۺ϶˿Ú
4¡¢¾ÛºÏ¶Ë¿ÚµÄ´´½¨
(config)# interface aggregateport 1    //´´½¨¾ÛºÏ½Ó¿ÚAG1
(config-if)# switchport mode trunk    //ÅäÖò¢±£Ö¤AG1Ϊ trunk ģʽ
(config)#int f0/23-24
(config-if-range)#port-group 1        //½«¶Ë¿Ú£¨¶Ë¿Ú×飩»®Èë¾ÛºÏ¶Ë¿ÚAG1ÖÐ
5¡¢Éú³ÉÊ÷
ÅäÖöàÉú³ÉÊ÷ЭÒé:
switch(config)#spanning-tree                    //¿ªÆôÉú³ÉÊ÷ЭÒé
switch(config)#spanning-tree mst configuration     //½¨Á¢¶àÉú³ÉÊ÷ЭÒé
switch(config-mst)#name ruijie                      //ÃüÃûΪruijie
switch(config-mst)#revision 1           //É趨У¶©±¾Îª1
switch(config-mst)#instance 0 vlan 10,20      //½¨Á¢ÊµÀý0
switch(config-mst)#instance 1 vlan 30,40      //½¨Á¢ÊµÀý1
switch(config)#spanning-tree mst 0 priority 4096   //ÉèÖÃÓÅÏȼ¶Îª4096
switch(config)#spanning-tree mst 1 priority 8192   //ÉèÖÃÓÅÏȼ¶Îª8192
switch(config)#interface vlan 10
switch(config-if)#vrrp 1 ip 192.168.10.1 //´ËΪvlan 10µÄIPµØÖ·
switch(config)#interface vlan 20
switch(config-if)#vrrp 1 ip 192.168.20.1 //´ËΪvlan 20µÄIPµØÖ·
switch(config)#interface vlan 30
switch(config-if)#vrrp 2 ip 192.168.30.1 //´ËΪvlan 30µÄIPµØÖ·(ÁíÒ»Èý²ã½»»»»ú)
switch(config)#interface vlan 40
switch(config-if)#vrrp 2 ip 192.168.40.1 //´ËΪvlan 40µÄIPµØÖ·(ÁíÒ»Èý²ã½»»»»ú)
6¡¢VLANµÄ»ù±¾ÅäÖÃ
(config)#vlan 10       //´´½¨VLAN10
(config-vlan)#name vlanname      // ÃüÃûVLANΪvlanname
ij¶Ë¿ÚµÄ½Ó¿ÚÅäÖÃģʽϽøÐÐ
(config)#interface vlan 10         //½øÈëVLAN 10µÄÐéÄâ¶Ë¿ÚÅäÖÃģʽ
(config-if)# ip address 192.168.1.1 255.255.255.0     //ΪVLAN10µÄÐéÄâ¶Ë¿ÚÅäÖÃIP¼°ÑÚÂ룬¶þ²ã½»»»»úÖ»ÄÜÅäÖÃÒ»¸öIP£¬´ËIPÊÇ×÷Ϊ¹ÜÀíIPʹÓã¬ÀýÈ磬ʹÓÃTelnetµÄ·½Ê½µÇ¼µÄIPµØÖ·
(config-if)# no shutdown        //ÆôÓøö˿Ú
7¡¢¶Ë¿Ú°²È«
(config)# interface fastethernet 0/1      //½øÈëÒ»¸ö¶Ë¿Ú
(config-if)# switchport port-security     //¿ªÆô¸Ã¶Ë¿ÚµÄ°²È«¹¦ÄÜ
a¡¢ÅäÖÃ×î´óÁ¬½ÓÊýÏÞÖÆ
(config-if)# switchport port-secruity maxmum 1     //ÅäÖö˿ڵÄ×î´óÁ¬½ÓÊýΪ1£¬×î´óÁ¬½ÓÊýΪ128
(config-if)# switchport port-secruity violation shutdown
   //ÅäÖð²È«Î¥ÀýµÄ´¦Àí·½Ê½Îªshutdown£¬¿ÉѡΪprotect (µ±°²È«µØÖ·ÊýÂúºó£¬½«Î´ÖªÃûµØÖ·¶ªÆú)¡¢restrict(µ±Î¥Àýʱ£¬·¢ËÍÒ»¸öTrap֪ͨ)¡¢shutdown(µ±Î¥Àýʱ½«¶Ë¿Ú¹Ø±Õ£¬²¢·¢ËÍTrap֪ͨ£¬¿ÉÔÚÈ«¾ÖģʽÏÂÓÃerrdisable recoveryÀ´»Ö¸´)
b¡¢IPºÍMACµØÖ·°ó¶¨
(config-if)#switchport port-security mac-address xxxx.xxxx.xxxx ip-address 172.16.1.1
//½Ó¿ÚÅäÖÃģʽÏÂÅäÖÃMACµØÖ·xxxx.xxxx.xxxxºÍIP172.16.1.1½øÐаó¶¨(MACµØÖ·×¢ÒâÓÃСд)
8¡¢Èý²ã·Óɹ¦ÄÜ(Õë¶ÔÈý²ã½»»»»ú)
(config)# ip routing           //¿ªÆôÈý²ã½»»»»úµÄ·Óɹ¦ÄÜ
(config-if)# no switchport    //¿ªÆô¶Ë¿ÚµÄÈý²ã·Óɹ¦ÄÜ(ÕâÑù¾Í¿ÉÒÔΪijһ¶Ë¿ÚÅäÖÃIP)
9¡¢Èý²ã½»»»»ú·ÓÉЭÒé
(config)# ip route 172.16.1.0 255.255.255.0 172.16.2.1   //ÅäÖþ²Ì¬Â·ÓÉ
×¢:172.16.1.0 255.255.255.0         //ΪĿ±êÍøÂçµÄÍøÂçºÅ¼°×ÓÍøÑÚÂë
172.16.2.1 ΪÏÂÒ»ÌøµÄµØÖ·£¬Ò²¿ÉÓýӿڱíʾ,Èçip route 172.16.1.0 255.255.255.0 serial 1/2(172.16.2.0Ëù½ÓµÄ¶Ë¿Ú)
(config)# router rip     //¿ªÆôRIPЭÒé½ø³Ì
(config-router)# network 172.16.1.0     //ÉêÃ÷±¾É豸µÄÖ±Á¬Íø¶ÎÐÅÏ¢
(config-router)# version 2        //¿ªÆôRIP V2£¬¿ÉѡΪversion 1(RIPV1)¡¢version 2(RIPV2)
(config-router)# no auto-summary   //¹Ø±Õ·ÓÉÐÅÏ¢µÄ×Ô¶¯»ã×ܹ¦ÄÜ(Ö»ÓÐÔÚRIPV2Ö§³Ö)
(config)# router ospf   //¿ªÆôOSPF·ÓÉЭÒé½ø³Ì£¨Õë¶Ô1762£¬ÎÞÐèʹÓýø³ÌID£©
(config)# router ospf 1    //¿ªÆôOSPF·ÓÉЭÒé½ø³Ì£¨Õë¶Ô2501£¬ÐèÒª¼ÓOSPF½ø³ÌID£©
(config-router)# network 192.168.1.0 0.0.0.255 area 0
//ÉêÃ÷Ö±Á¬Íø¶ÎÐÅÏ¢£¬²¢·ÖÅäÇøÓòºÅ(area0Ϊ¹Ç¸ÉÇøÓò)
¿ÉÒÔÃ÷ÏÔ¿´³ö£¬Èý¼ÒÃüÁî´óͬСÒ죬Æäʵ»ªÎªÓëH3C¸ü¼ÓÀàËÆ¡£
