Sampletekk S.S.G KONTAKT/HALion¨C ¸ÖÇÙÒôÔ´
ÒôÔ´
KONTAKT | HALion | EXS | SFZ ¨C 1,74 GB
ST SSG -С¹¤×÷ÊÒGrandÊÇÒ»¸ö¸üСµÄ´ó¸ÖÇÙ£¬(6¡ä 1¡å)¸øÒ»¸ö¸ü½ô£¬¸üÃ÷È·µÄÉùÒô£¬È»ºó¸ü´óµÄÀÖÆ÷¡£ÕâÖÖÀÖÆ÷ÔÚµÍÒôÇøÓÐÉî¶ÈºÍÔ²¶È£¬·á¸»µÄÖÐÒôºÍÇåÎú£¬Çå´àµÄ¸ßÒô¡£
¼Ç¼ÔÚÒ»¸öÈðµä×îºÃµÄ·¿¼äΪÉùѧÒÇÆ÷£¬Ê¹ÓÃNeumann M269µÄºÍNeumann M250µÄÈ·±£¼Ç¼²ÄÁϸøÄã×îºÃµÄ±íÏÖ¿ÉÄÜ¡£
ËüµÄ21-28ËÙ¶ÈÑù±¾£¬Ëü¸øÄãµÄ¶¯Ì¬ÏìÓ¦ËùÐèµÄ¹¤×÷ÊÒʹÓã¬Ê¹Õâ¸öΰ´óµÄÀÖÆ÷ͬÑùÊʺÏÁ÷ÐУ¬¾ôÊ¿£¬Ò¡¹öºÍËùÓÐÖ®¼äµÄÊÂÇé!
SampletekkÂÖG¶à¸ñʽ½ØÍ¼
¨C 21-28±£³ÖËÙ¶Èˮƽ
-³¬¹ý1500¸öÑù±¾
-ʱ¼ä¼¶·¢²¼¼¼Êõ(Kontakt°æ±¾)
-Õæ¹²Õñ¼¼Êõ
-ͬÇé¹²Õñ(Kontakt°æ±¾)
-°´¼ü/̤°åÔëÒô¿É¿ØÖÆÒôÁ¿(Kontakt°æ±¾)
-½»¸Ð¹²ÕñºÍÕæ¹²ÕñµÄ¿É¿ØÒôÁ¿(Kontakt°æ±¾)
¨C 24bit 44.1Á¢ÌåÉù²ÉÑù
¶ÔÓÚKontakt°æ±¾£¬ÄãÐèÒªÖÁÉÙ5¸öÍêÕû°æ±¾!
ÔÚSforzandoÉϲâÊÔSFZ¸ñʽ¡£
Ö÷Ò³£ºhttps://www.sampletekk.com/grand-pianos&product_id=262
The ST SSG ¨C Small Studio Grand is a smaller Grand Piano, (6¡ä 1¡å) that give a tighter, more defined sound then a larger instrument. This instrument has depth and roundness in the bass register, rich midrange and a clear, crisp treble.
Recorded in one of Swedens best room for acoustic instruments, using Neumann M269¡¯s and Neumann M250¡¯s ensures that the recorded material gives you the best performance possible.
With its 21-28 velocity samples, it give you the dynamic response needed for studio use, making this great instrument equally suited for pop, jazz, rock and all things in between!
¨C 21-28 sustain velocity levels
¨C More the 1500 samples
¨C TimeVel Release Technology (Kontakt Version)
¨C True Resonance Technology
¨C Sympathetic Resonance (Kontakt Version)
¨C Controllable volume for key/pedal noise (Kontakt Version)
¨C Controllable volume for Sympathetic Resonance and True Resonance (Kontakt Version)
¨C 24 bit 44.1 stereo samples
For Kontakt version, you¡¯ll need minimum Kontakt 5 FULL version!
SFZ format tested on Sforzando.
home page£ºhttps://www.sampletekk.com/grand-pianos&product_id=262
