Ë®¹û20 Image-Line FL Studio Producer Edition v20.0.2.25 °æ
* ~& ~# H- J% b- [8 d
/ D- j" r) U" W ) o O( }7 A1 x" e0 ?& R2 j& {
FL Studio is a complete software music production environment or Digital Audio Workstation (DAW). Representing more than 20 years of innovative development it has everything you need in one package to compose, arrange, record, edit, mix and master professional quality music.
+ ^( U9 S$ w! u) lThe Mixer
- Z2 L: V' r- [9 M6 U1 ]Mix and master music to the highest professional standards. All the features you need to create today's most complex productions including, effects chains, audio sends, sidechain control, advanced automation, plugin delay compensation and more...: E# F- ?( E0 | V' }, o8 T& R4 Y/ S( S- R
Piano Roll
6 s4 n+ p) M4 W5 sFL Studio's Piano roll has the well deserved reputation as the best Piano roll in the business. The Piano roll is used to send note and automation data to plugin instruments (sequencing). It includes a wide range of tools to aid complex score editing and manipulation. R% V B& v2 [& _6 ]# S3 G2 \
Browser and Playlist
1 S' X3 T" @# l2 g }5 z" gNo other DAW matches the flexibility of FL Studio¡¯s Playlist. Sequence all elements of the project to make the final song. Tracks can hold notes, audio and automation. Place any data type anywhere and even overlay them. Use the Browser to organize all the data in your project. Free your workflow and your mind!. W' n# s, |; Q
Over 80 plugins included
& @% l" M8 ~' o1 G. H' e2 [% T ]FL Studio Producer Edition includes over 80 instrument and effect plugins covering automation, sample playback/manipulation, synthesis, compression, delay, equalization filtering, flanging, phasing, chorus, reverb, distortion, bit-crushing and more. With FL Studio you will be ready to create just about any style.
, ~+ I/ _4 K6 Z/ r6 m" [* M! x! zInstruments & FX
i: Q& a. \5 o# WIf the huge array of native instruments and effects are not enough for you, FL Studio supports all VST standards 1, 2 and 3. VST gives you access to the wisest range of 3rd party plugins currently available. You can even use FL Studio itself as a VST plugin in another VST host.
% O6 n( S7 Y4 ]
' t' f& a/ u7 h( A9 c5 m( q
