TEAC SD-500HR Ä£ÄâÊý×ÖÒôÀÖת¼Æ÷
syxsunjun
2017-12-15 10:40:01
TEACÍÆ³öȫвúÆ·SD-500HR£¬ÕⲿÆ÷²ÄÄܹ»½«ÊÕµ½ÁËÄ£ÄâѶºÅת»»Îª¸ß½âÎöµÄÊý×ÖѶºÅ£¬¶øÇÒÄܹ»Ö±½Ó´¢´æÖÁ±ãÓÚЯ´øµÄ¼ÇÒ俨µ±ÖУ¬Ö§³ÖSDXC¡¢SDHC¡¢CFµÈ¹æ¸ñµÄ¼ÇÒ俨¡£×ªÎªÊý×Ö¼ÒôµµµÄ¸ñʽÄÜ´ïDSD 2.8/5.6 MHzÓëPCM×î¸ß24bit/192kHz¡£
ͨ¹ýSD-500HR£¬Ê¹ÓÃÕßÄܽ«¼ÒÖеļÒô¿¨´ø¡¢ºÚ½º³ªÆ¬»òÊÇÈκÎÄ£Äâ´¢´æÔØÌ嶼ת»»ÎªÊý×Ö¸ñʽ´¢´æ£¬Ò»À´¿ÉÒÔÓÀ¾Ã±£´æ£¬¶þÀ´¿ÉÓÚÊý×ÖѶԴÉϲ¥·Å£¬Ö§³Ö¼ÇÒ俨ת´æ¸üÄÜÖ±½ÓÔÚÖÇÄÜÊÖ»úµÈ×°ÖÃÉϲ¥·Å¡£
¸üÄܹ»Ê¹ÓÃTEACËùÌṩµÄÃâ·Ñ±à¼­Èí¼þ¡°TEAC Hi-Res Editor¡±£¬½«´æÓÚµçÄÔÖеÄÊý×ÖÎļþ×öÇиî±à¼­»ò¸ñʽת»»¡£¸ßÒôÖʲ¢²»Ö»ÊÇÔ´ÓÚ¸ßÈ¡ÑùÂÊ£¬¶øÊÇÔÚ×óÓÒÉùµÀµÄ·ÖÀë¶ÈÒÔ¼°Ë«µ¥ÉùµÀµç·Éè¼ÆÊµÏÖÁË´¿´âµÄѶºÅ´¦Àí£¬ÒÖÖÆ×óÓÒÉùµÀÖ®¼äµÄ¸ÉÈÅÓëÔëÉù¡£
SD-500HRʹÓÃÁËBurr-Brown PCM 1795Êý×ÖÄ£Äâת»»Ð¾Æ¬(DAC)£¬Burr-Brown PCM 4202Ä£ÄâÊý×Öת»»Ð¾Æ¬(ADC)¡£ÁíÍâSD-500HR×°ÔØÁËTCXO¸ß¾«¶ÈʱÖÓ£¬×÷ΪѶºÅ´¦ÀíʱµÄÄÚ²¿Ö÷ʱÖÓ£¬ÁíÍâ´îÅäWord InÊäÈ룬¿ÉÒÔÁ¬½ÓÍⲿ¸ü¾«È·µÄ¶ÀÁ¢Ê±ÖÓÆ÷²Ä¡£
SD-500HR¿ÉÁ¬½Ó·á¸»µÄ¸÷ʽÆ÷²Ä£¬¾ß±¸XLRƽºâÄ£ÄâÊäÈëÓëÊä³ö¶Ë×Ó¡¢RCAµ¥¶ËÄ£ÄâÊäÈëÓëÊä³ö¶Ë×Ó£¬Êý×ÖÊäÈëÓëÊä³ö¶Ë×ÓÓÐAES/EBU: XLR¡¢SPDIF/Cascade: RCA¡¢SDIF: BNC¸÷Ò»×é¡£
TEAC SD-500HR Ä£ÄâÊý×ÖÒôÀÖת¼Æ÷¹æ¸ñ
¡¤Ö§³Ö¼ÒôÔØÌå: SDXC (max 256GB) SDHC (max 32GB) CF Card (max 128GB)
¡¤Ö§³Ö¼Òô¸ñʽ: DSD 2.8/5.6MHz, PCM 44.1/48/88.2/96/176.4/192kHz, 16/24-bit
¡¤ÆµÂÊÏìÓ¦: Rec/Play 20-100kHz (DSD +0.1/¨C12dB) 20-50kHz (DSD +0.1/¨C3dB) 20-80kHz (PCM 176.4/192kHz +0.1/¨C6dB)
¡¤×Üг²¨Ê§ÕæÂÊ: Rec <0.005% (DSD/PCM-24bit ) Play <0.003% (DSD/PCM-24bit Balanced) <0.001% (DSD/PCM-24bit Unbalanced)
¡¤ÔëѶ±È: Rec >106dB (DSD ¨C20dB/Bal, AES-17 20k LPF) >111dB (PCM 24-bit Unbalanced) Play >116dB (DSD ¨C20dB/Bal, AES-17 20k LPF) >118dB (PCM 24-bit ¨C20dB Balanced) >116dB (PCM 24-bit Unbalanced)
¡¤Cross Talk: >10dB (Recording, 1kHz JEITA)
¡¤Ä£ÄâÊäÈë: Balanced: XLR¡Á1 pair Unbalanced: RCA¡Á1 pair
¡¤Êý×ÖÊäÈë: AES/EBU: XLR¡Á1 SPDIF/Cascade: RCA¡Á1 SDIF: BNC¡Á1
¡¤Ä£ÄâÊä³ö: Balanced: XLR¡Á1 pair Unbalanced: RCA¡Á1 pair
¡¤Êý×ÖÊä³ö: AES/EBU: XLR¡Á1 SPDIF/Cascade: RCA¡Á1 SDIF: BNC¡Á1
¡¤ÍⲿʱÖÓÁ¬½Ó: Word IN: BNC¡Á1
¡¤Ê±ÂöÊä³ö¶Ë×Ó: BNC¡Á1
¡¤USB: USB A-type¡Á1 (for USB ¿ìÉÁ¼ÇÒäÌå)
¡¤¼üÅÌÁ¬½Ó: USB A-type¡Á1 (for USB ÏÞ¼üÅÌʹÓÃ)
¡¤¶ú»úÊä³ö: 1/8¡± (3.5mm) Stereo Mini¡Á1
¡¤ÊÊÓõçÔ´: AC 120V, 60Hz (US/Canada)
¡¤ÏûºÄ¹¦ÂÊ: 24W
¡¤³ß´ç (¿í¡Á¸ß¡ÁÉî): 442.6¡Á57.5¡Á305 mm
¡¤ÖØÁ¿: 9.7 lbs. / 4.4 kg
ÆÀÂÛÁÐ±í£¨1£©
µãÔÞÁË£¬ºÃÎÄÕ£¬²»´í°¡£¬¿ÉÒÔÊÕ²ØÑ§Ï°Á˰¡£¡~
2017-12-16 14:45:04 »Ø¸´
