androidϵ÷ÊÔÉù¿¨Çý¶¯Ö®Machine²¿·Ö
924177110
2016-7-12 08:42:20
¼¼Êõ
±¾ÎĽéÉܵĴúÂëÊÇÔÚCPU£¨imx6£©ºÍCodec£¨wm8960£©ÉÏ×öµÄµ÷ÊÔ²¢ÇÒCodec×öÖ÷ģʽ£¬ÔÚ¡°¸ÅÊöƪ¡±ÖÐÌáµ½Codec²¿·Ö¡¢
Platform²¿·Ö´úÂëÓÉÉ豸ԭ³§ÌṩºÍϵͳÌṩ£¬ËùÒÔÎÒÃÇÔÚÉù¿¨µ÷ÊÔÖÐÐèÒª×öµÄÖ»ÓÐMachine²¿·Ö£¬ÆäËû´úÂëÔÚÐèÒªµÄÇé¿öÏÂÂÔ×ö΢
µ÷¼´¿É£¬µ÷ÊÔ¹ý³ÌÖл¹Òª×¢ÒâÔÚBSPÎļþÀïÅäÖúÃI2S£¨SSIºÍAUD¸´Óã©¡£
1¡¢imx_hifi_hw_paramsº¯Êý½éÉÜ
static int imx_hifi_hw_params(struct snd_pcm_substream *substream,
                                     struct snd_pcm_hw_params *params)
        /* ÉèÖÃCodecÓëCPUÒôƵÊý¾ÝͨПñʽΪI2S£¬BLCK²»·´×ª£¬CodecΪÖ÷ģʽ*/
        dai_format = SND_SOC_DAIFMT_I2S | SND_SOC_DAIFMT_NB_NF |
                SND_SOC_DAIFMT_CBM_CFM;
        /*  set codec DAI configuration */
        ret = snd_soc_dai_set_fmt(codec_dai, dai_format);
    if( ret < 0 ){
        printk( "%s: Codec DAI configuration error, %d\n", __func__, ret );
        return ret;
        /*  set i.MX active slot mask */
        snd_soc_dai_set_tdm_slot(cpu_dai,
                        channels == 1 ? 0xfffffffe : 0xfffffffc,
                        2, 32);
        /* ÉèÖÃCPUÓëCodecÒôƵÊý¾ÝͨПñʽΪI2S£¬BLCK²»·´×ª£¬CPUΪ´Óģʽ*/
        /*  set cpu DAI configuration */
        ret = snd_soc_dai_set_fmt(cpu_dai, dai_format);
    if( ret < 0 ){
        printk( "%s: AP DAI configuration error, %d\n", __func__, ret );
        return ret;
        sample_rate = params_rate(params);
        switch (sample_rate) {
       case 44100:
        if (channels == 1) { // ¸ù¾ÝͨµÀÊýÅäÖÃÏà¹ØÊ±ÖÓÆµÂÊ£¨1£º´ú±íµ¥Í¨µÀ£©
            /* Mono mode */
            dacdiv = WM8960_DAC_DIV_2; /* 22.05 KHz */
            bclk = WM8960_BCLK_DIV_16;
        else {
            /* Stereo Mode */
            dacdiv =WM8960_DAC_DIV_1; // 44.1 KHz£¬ÎªÉèÖòÉÑùƵÂÊ£¨LRCK£©£¬ÅäÖÃCodec¼Ä´æÆ÷µÄÖµ
            bclk = WM8960_BCLK_DIV_4; // ΪÉèÖÃBCLKƵÂÊ£¬ÅäÖÃCodec¼Ä´æÆ÷µÄÖµ
                        dclk = WM8960_DCLK_DIV_16;// ΪÉèÖÃDÀà·Å´óÆ÷ʱÖÓÆµÂÊ£¬ÅäÖÃCodec¼Ä´æÆ÷µÄÖµ
        sysclk_div = WM8960_SYSCLK_DIV_2; // ΪÉèÖÃCodecµÄϵͳʱÖÓÆµÂÊ£¬ÅäÖÃCodec¼Ä´æÆ÷µÄÖµ
        pll_out = 11289600; // É趨PLLµÄƵÂÊÖµ
        break;
      default:
        printk("do not support this sample frequency");
        return -EINVAL;
    /* ÉèÖÃCodecµÄPLLƵÂÊ£º11289600*/
        ret=snd_soc_dai_set_pll(codec_dai,1,0,priv->sysclk/2,pll_out);
    if( ret < 0 ){
        printk( "%s: AP codec pll error, %d\n", __func__, ret );
        return ret;
        /* ÉèÖÃCodecµÄϵͳʱÖÓ£º11289600*/
    ret = snd_soc_dai_set_clkdiv( codec_dai, WM8960_SYSCLKDIV, sysclk_div );
    if( ret < 0 ){
        printk( "%s: Codec SYSCLKDIV setting error, %d\n", __func__, ret );
        return ret;
        /* ÉèÖòÉÑùƵÂÊ£¨LRCK£©µÄʱÖÓ£¬lrckclk= sysclk/1*256=44100 */
    ret = snd_soc_dai_set_clkdiv( codec_dai, WM8960_DACDIV, dacdiv);
    if( ret < 0 ){
        printk( "%s: Codec DACDIV setting error, %d\n", __func__, ret );
        return ret;
        /* ÉèÖÃDÀà·Å´óÆ÷ʱÖÓÆµÂÊ:dclk= sysclk/16 */
        ret = snd_soc_dai_set_clkdiv( codec_dai, WM8960_DCLKDIV,dclk);
        if( ret < 0 ){
                printk( "%s: Codec DCLKDIV setting error, %d\n", __func__, ret );
                return ret;
        /* ÉèÖÃBCLKÀà·Å´óÆ÷ʱÖÓÆµÂÊ:bitclk=sysclk/4 = 2822400 */
        ret = snd_soc_dai_set_clkdiv( codec_dai, WM8960_BCLKDIV, bclk);
        if( ret < 0 ){
        printk( "%s: Codec WM8960_BCLKDIV setting error, %d\n", __func__, ret );
        return ret;
    return 0;
2¡¢snd_soc_dai_link½á¹¹Ìå½éÉÜ
platform Á¬½Ó codec Óë cpu µÄÇý¶¯Ê±£¬ÐèҪͨ¹ýÄں˺¯Êý½á¹¹Ìåsnd_soc_dai_linkÀ´ÉèÖÃÁ½±ßµÄ½Ó¿Ú¡£
static struct snd_soc_dai_link imx_dai[] = {
                .name = "HiFi",
                .stream_name = "HiFi",
                .codec_dai_name        = "wm8960-hifi",
                .codec_name        = "wm8960.1-001a",
                /* wm8960.1-001a´ú±íµÄÊÇÓÃI2C1À´¿ØÖÆcodec,ÆäI2CµØÖ·Îª0x1a;I2CX, X´ú±íµÄÊÇ0,1,2,¿ªÊ¼ */
                .cpu_dai_name        = "imx-ssi.1",
                 * ´ú±íµÄÊÇͬһ¸öÉù¿¨ÖеĵÚÒ»¸öÉ豸ÓëSSI1ÏàÁ¬;I2SX X´ú±í0,1,2;ssi.1´ú±íSSI1¡£
                 * IMX6ÖеÄSSI½Ó¿ÚÓÐ3¶Ô¿ÉÒÔ½Ó×Å·I2S£»Èý·SSI¿ÉÒÔÿ·SSI µ¥¶À×÷Ϊһ¸öÉù¿¨£¬
                 * Ò²¿ÉÒÔÊÇÒ»¸öÉù¿¨°üº¬¶à¸öÉ豸£»
                .platform_name        = "imx-pcm-audio.1",
                /* ´ú±íµÄÁ¬½Ó½Ó¿ÚÓëSSIÀ´¶ÔÓ¦£¬ÓÃÄÄ·SSI£¬ÆäºóÃæµÄÊý×Ö¾ÍÊǼ¸¡£ */
                .init                = imx_wm8960_init,
                .ops                = &imx_hifi_ops,
ÆÀÂÛÁÐ±í£¨1£©
·ÖÏí,лл¥Ö÷·¢²¼°¡
2017-6-15 09:11:59 »Ø¸´
