查看: 33976|回复: 1
[技术] DVON迪华澳专业UHF无线麦克风系统
发表于 2010-7-29 16:49:41 | 显示全部楼层 |阅读模式
DVON迪华澳专业UHF无线麦克风系统
$ P  H" M& g* F/ n1 M% o# j! M- T, g0 s
       频率范围:UHF500MHz-96OMHz(可选调制方式:FM(PLL)频偏:+25KHz/ 148KHz频率稳定度:+15ppm频率响应:60Hz一18KHz信噪比: ) 11 OdB(A) T. H .D:1%工作温度:一10℃一+55℃接收形式:分集接收灵敏度:3uV(52dB S/N)音频输出电平:
- T/ ]* f, P6 m4 |. G4 r 14204321e96.jpg % }4 _) C8 u* e2 p
' Q% P! n1 X2 G  B       平衡输出:+1OdB(XLR)  音频输出:+4dB(1/4", 6.3mm jack socket)邻道干扰比:>80dB镜像干扰比::80dB RF发射功率(50): 8mW一30mW谐波抑制:>50dB Frequency Range:UHF 500一960MHz(Tunable) Modulation Mode:FM(PLL)ominal/peak deviation:+25KHz/_+48KHz Frequency Stability:+15ppm Frequency Response: 60Hz一18KHz S/N(1    mV RF and peak deviation)Ratio:〕11 OdB(A)T.H .D(at nominal deviation and 1 KHz):1% Temperature range:一10℃一+55t* I! V+ }1 `3 H+ p6 c
9 m! G2 S! e: M" P0 }* A6 @1 F 1420435436f.jpg 1 x7 l) I$ x8 J: V& A, [
. [# d* G% g+ ?% [9 u
       Receiver principle:  Predictive diversity Sensitivity (Peak deviation):3uV(52dB S/N) AF output Voltage(at peak deviation 1 KHz AF out):      Balanced:+1 OdB(XLR)      Unbalanced:+4dB(1/4",6.3mm jack socket)F/N Ratio : ) 80dB
5 p8 O5 j6 |4 i, W6 c& q( bP/N Ratio:〕80dB RF output power at 50Q :  8mw一30mW RF squelch:>50dB
5万
音频应用中级会员
Rank: 5Rank: 5Rank: 5
发表于 2010-7-29 21:34:08 | 显示全部楼层
学习了,支持朋友。
GMT+8, 2025-7-22 06:05 , Processed in 0.023533 second(s), 6 queries , Redis On.
