GetGood Drums Matt Halpern Signature Pack v2.0 KONTAKT
ÎÒÃDz߻®µÄµÚÒ»¸ö¹Ä£¬îàºÍÂó¿Ë·ç¿â¡£µ÷Õû£¬²¶»ñºÍÖ´ÐÐÓë×î´óµÄ×¢Òâϸ½Ú£¬±£ÁôÔʼµÄÄÜÁ¿ºÍÐÅÄîËùÐèµÄÕæÕýÌØÊâµÄÉùÒô¡£·Ç³£×ÔºÀ£¬ÎÒÃÇÌṩGGD Matt HalpernרÊô°ü¡£ V2.0ÊÇÒ»¸ö¹Ù·½KontaktÀÖÆ÷£¬ÕâÒâζ×ÅÄã²»ÐèÒªÍêÕû°æµÄKontakt£¡Ö»Òª¼ÓÔØµ½Ãâ·ÑµÄKontakt²¥·ÅÆ÷£¬Äã¿ÉÒÔʹÓÃGGDûÓÐʱ¼äÏÞÖÆ¡£
ÔÎÄ
Our first curated library of drums, cymbals, and microphones. Tuned, captured, and performed with the utmost attention to detail, retaining the raw energy and conviction needed for a truly special sound. With great pride, we present the GGD Matt Halpern Signature Pack. V2.0 is an official Kontakt instrument which means you do NOT need the full version of Kontakt! Just load it into the free Kontakt Player and you can use GGD with no time limits or restrictions.
All the bells & whistles for effortless songwriting and mixing
We built the Matt Halpern library as the tool we wished we had years ago, with all the little details and creature comforts we couldn¡¯t find in other libraries:
- The Halpern library is now a Player Library (NKS) and can be used with Kontakt¡¯s Free Player ¨C no need to buy the full version of Kontakt to use GGD!
- A fully-featured and intuitive UI for building your kit and working with spot and room mics
- Full range of velocity layers¨C hard hits that are actually hard, with that hard-to-get mix of body and attack
- Wide variety of articulations: snare on and off; center and rim hits on snare and toms; bell and side-stick on the ride cymbal
- Cymbal matrix
- Different tunings for each of the 5 snares to give you a full range of sonic options without having to resort to pitch shifting or other tricks that degrade the tones
- The entire kit is tuned to perfection, so you¡¯ll never be fighting against sour notes in your mix
- Every sample is phase-coherent for easy layering
Whether you¡¯re sketching out a song idea or working on a final mix, the Matt Halpern library gives you all the tools you need to bring your ideas to life.
GetGood Drums Matt Halpern Signature Pack v2.0 KONTAKT | 5.6 Gb
ÏÂÔØµØÖ·£ºÓοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë »Ø¸´ |
