¹ã¶«µÃʤµç×ÓPC-k400רҵµçÈÝÂó¿Ë·ç£¨»°Í²£©
»°Í²
¹ã¶«µÃʤµç×ÓPC-k400רҵµçÈÝÂó¿Ë·ç£¨»°Í²£©( H; x# Q% B" g8 C4 |5 f
6 p; k/ Y, F* h' OPC-k400²úÆ·ÌØÐÔ(Features)( }5 I. M: K9 `% o8 i6 {) b
         ¡¤¹Åµä·ç¸ñµÄרҵÍâ¹ÛÉè¼Æ£¬È«½ðÊô½á¹¹±¾Ì壬ÌåÏÖרҵÂó¿Ë·çµÄµµ´Î¶¨Î»£¬Æ·Î¶¸ß¹óµäÑŵĹŵä·çÇé
/ |+ c2 r1 Z# R; j8 H/ U         ¡¤²ÉÓ᰹㶫µçÉùÑз¢ÖÐÐÄ¡±ÎªµçÄÔ¼Òô¶øÑз¢ÉùÒôÖÞ¾©¼¼ÊõTechSound Master£¬ÄÚÖøßÐÔÄܵçÈÝÒôÍ·£¬ÁéÃô¶È¸ß£¬ÆµÂÊÏìÓ¦¿í¹ã£¬¸÷ÖÖÉùÒôϸ½Ú¶¼µÃÒÔÕæÊµ»¹Ô­
! {1 R6 a/ d9 E0 s3 k         ¡¤³¬¿íµÄƵÂÊÏìÓ¦£¬µÍÒô¿ÉÒÔÑÓÉìµ½20HzÒÔϵij¬µÍƵ£¬¸ßÒô¿ÉÒÔÇáÒ×µÄ ´ïµ½20KHz£¬Õ¹ÏÖ¿í¹ãµÄƵÂÊÏìÓ¦ÌØÐÔ£¬ÄÜʰȡÈ˶úËùÄÜÌýµ½ÉùÒôµÄ¸ß¡¢ÖС¢µÍƵÒôÓò£¬ÕæÕýµÄʵÏÖÈ«ÒôÓòʰÒô
" k# a; f: t# O/ Z3 C) V+ D        ¡¤×î´óÉùѹ¼¶£¬¿ÉÒÔÑÓÉìµ½È˶úËùÄܳÐÊܵÄÒôÁ¿¼«ÏÞ140OB£¬²¢ÇÒÔÚÈç´Ë¸ßµÄÉùѹ¼«ÏÞÏ£¬ÈÔÈ»Äܽ«ÒôÖÊÍêºÃÎÞËðµÄÖØÏÖ³öÀ´# Z3 }- X: Z- s% A7 G
        ¡¤WPH Restrain 180¡ã TMÈý²ãÍøÎïÀíÂËÔë¼¼Êõ£¬ÓÐЧµÄÂ˳ý180¡ã²úÉúµÄºôÎüÉù¡¢·çÉùµÈµÍƵÔÓÒô
0 a6 b9 k3 [' a- j. j' h        ¡¤ÌṩµçÄÔרÓÃÁ¬½Ó·½Ê½£¬ÎÞÐèת»»£¬Ê¹Ó÷½±ã¡£Ë«Ð¾ÆÁ±ÎÏ߲쬯Á±ÎЧ¹ûºÃ£¬¿¹¸ÉÈÅÄÜÁ¦Ç¿9 ^  d+ n' O2 c- [5 T
        ¡¤Âó¿Ë·çβ²¿Ê¹Óñê×¼5/8"ÂÝÑÀ£¬¿ÉÓë¸÷ÖÖÖ§¼ÜÁ¬½Ó
. b7 n$ x6 w: f" a' e6 q        ¡¤ÅäÖÃ48V»ÃÏ󹩵çÆ÷¡¢×¨ÒµÏ߲ļ°×ÀÃæÖ§¼ÜµÈÅä¼þ£¬ÅäÌׯëÈ«£¬Ê¹Óøü·½±ã¡£
6 ^1 h, _) o9 w3 h1 v        ¡¤Classical style, professional and noble design" t* L9 i/ }! v, r2 c
        ¡¤High-performance capsule, adopting TechSound Master" technology to provide natural sound reproduction
) C, O4 F- A1 e        ¡¤Super wide frequency response range, high sensitivity
/ k% R: L; k: ]( Y; A% T        ¡¤Max. SPL can extend to human ear limit 140dB and without voice distortion3 _& U( V, |' O
        ¡¤The WPH Restrain 180¡ã3-layer mesh minimizes low frequency noise such as breathing, wind noise6 t, ^, I2 Q7 k
          .Provide computer special connection mode for convenience; T+ X: m, a) B* l5 O! h/ X4 m
        ¡¤Standard 5/8" screw thread at the bottom of the microphone for connecting with different kind of holder
7 a& c& U: Z' q/ H0 Q, o        ¡¤Full range of accessories for convenient use( A) T) N5 J4 |7 {/ k  t
! c% t( Q! Q# N) I8 z
14132148517.jpg   D$ k1 {' W" b+ m8 m; y
ÊÊÓó¡Ëù(Application)
8 P+ e% Q5 j2 z- b. x" o* E        ¡¤¸öÈ˼ÒôÊÒ¡¢×¨ÒµÂ¼ÒôÅï¡¢ÁÄÌìÊÒ¡¢¹ã²¥µç̨µÈ
( d7 R: l6 w8 ^* g) f2 U        ¡¤Recording, chat room, broadcasting
* k7 Q" y3 e, BÅäÖÃÒªÇó(Requirement)
9 I: b& D1 o: P! B9 A; i+ |0 z" h        ¡¤µçÄÔÉÏʹÓñ¾²úÆ·ÐèÅäÖû°·Å»òK¸èÉù¿¨
. ?+ a% @, h) X/ B1 {& t3 I        ¡¤You need to use the microphone amplifier or sound card when you use it  together with computer' x6 y6 l7 O! A/ D
¼¼Êõ²ÎÊý(Specification)# B1 Q, ^+ [) B+ `/ @
Âó¿Ë·ç²ÎÊýÖ¸±ê(Microphone Specification)6 ~0 [4 |& n/ ~4 h2 m6 v
         ¡¤ÒôÍ·(Transducer Principle):µçÈÝʽCondenser  l0 q0 G  V' G! x. Z4 c- M
         ¡¤Ö¸ÏòÐÔ(Directivity Characteristic):ÐÄÐÍCardioid
1 ?4 Y5 p' C, a; ]: Y' Z0 I  {         ¡¤ÆµÂÊÏìÓ¦(Frequency Response): 30Hz-2OkHz
8 A. q% \: `8 Q; d; G# Q         ¡¤ÁéÃô¶È(Sensitivity):Ò»35dBÊ¿2dB (0dB=1 V/Pa atlkHz)
( @3 ^4 [/ z# m9 ~8 U4 d& B         ¡¤Êä³ö×迹(Output Impedence): 200¦¸Ê¿30% (at 1kHz)
! z0 X  ]$ ?( q/ c1 l         ¡¤¸ºÔØ×迹(Load Impedence):¡Ý1000¦¸
& n  Y( O( m3 y( Z         ¡¤µÈЧÔëÉù¼¶(Equivalent Noise Level): ¡Ü20dB A (IEC 581-5)
2 [, m7 S( K9 x) x% r8 e9 M         ¡¤×î´óÊäÈëÉùѹ¼¶(Max.lnput SPL): 140dB (THD ¡Ü1.0% at 1 kHz)& q5 g* z3 A1 T& f8 S
         ¡¤Âó¿Ë·çÊä³ö½Ó¿Ú(Output Connector):ÄÚÖÃÈýÕëXLRM¿¨Ù¯¹«Í·XLRM
9 h" a3 q0 u; ^8 D7 U2 p& Q% d        ¡¤¹©µç·½Ê½(Power Supply): 48V»ÃÏ󹩵ç48V Phantom Power
1 u: W8 ~* `+ a' \        ¡¤ÖØÁ¿(Weight): 650g
# T; ~, I8 _0 x) D»ÃÏ󹩵çÆ÷²ÎÊýÖ¸±ê( Phantom Power Specification)0 p/ ]9 d& o" O: Y+ b( m
       ¡¤»ÃÏ󹩵ç(Power supply): +48V
+ G6 F6 ^  X! a3 t" u  ^       ¡¤ÊäÈëµçÔ´(Input Power): AC 18V 300mA
# H: o) e$ J7 }8 u       ¡¤ÊäÈë¶Ë¿Ú(INPUT) (Input Connector):±ê×¼Cannon(XLR)ƽºâÊäÈë3 \1 h4 ]( M/ S6 q1 C& V
                                Standard XLR balanced input
+ d! v+ i4 d4 N' j3 K       ¡¤Êä³ö¶Ë¿Ú(OUTPUT) (Output Connector):±ê×¼Cannon (XLR)ƽºâÊä³ö
6 u! C4 b* K7 G- v# H                                  Standard XLR balanced output
8 t7 k+ u+ N! x4 t& `7 j        ¡¤²úÆ·¹æ¸ñ(Dimension): 90.3 x 98 x 41.8mm(³¤x¿íx¸ß)
6 |2 \8 T4 m5 G% o. H% y                    90.3mm x 98mm x 41.8mm (L x W x H)' D% a* O/ ^8 }! P5 [
         ¡¤Êä³öµçѹ(Output Voltage): DC48V  {4 W& A" t5 d# F3 O* W
        ¡¤ÏûºÄ¹¦ÂÊ(Power Consumption):¡Ü5W. y9 S- r% J+ T/ d; i0 C
        ¡¤ÔëÉù(Noise):¡Ü1.8uV0 S, W& f' j3 ~
       ¡¤ÖØÁ¿(Weight): 430g
ÆÀÂÛÁÐ±í£¨5£©
:victory:
2010-7-16 20:13:00 »Ø¸´
ѧϰ¡¢Ö§³Ö:victory::victory:
2010-7-18 06:46:45 »Ø¸´
Ö§³Ö£¡£¡ÐÀÉÍ£¡£¡
2010-7-22 00:19:15 »Ø¸´
:victory::victory:ѧϰ¡£
2010-7-25 07:12:35 »Ø¸´
ÐÀÉÍ£¬Ö§³Ö
2010-7-31 01:28:48 »Ø¸´
