1 n0 A3 G! ^1 d8 K1 U5 E. ?& F
3550 released - x86 and x64 & n# _) N$ x$ [" @% ?5 u, o
hi guys!2 \ G- o( w' ]7 ^* k3 N
7 B) N* J& @5 |; _
version 3550 is out!0 ?$ a4 \$ N9 w- t" c
q. n- F+ o- s. y0 f$ R9 @
changes:
$ O& V3 E4 O$ e P- D( d
- F9 G7 {9 C% s* fixed issues with '>2Gb memory' PCs" B$ i/ V4 v+ o( T- _5 h* x* T4 {2 p
* fixed issue with add-ons on multidevice configurations (E-DSP Control, menu_idx)1 e+ [' e! A8 R( C9 R9 H5 x8 ~
* fixed issue with kX Console unable to launch from the tray( V8 k6 i Z$ r. G
* fixed 'slow tooltips' issue in kX DSP
8 f/ `; |/ q% _4 @8 ` W* fixed 'no labels' issue in kX DSP
3 J: b" ]* M8 m: L
. O5 `2 X3 S5 m8 tknown issues:
- k( n) E* m7 H* soundfonts may not work properly, because sfman32.dll requires kxapi.dll, which is no longer in the system32 folder. Add kX folder to your PATH to solve the problem4 N$ W3 B# l/ P2 P9 m& R
* as earlier, 'speaker test' will NOT work in Vista/Windows7: p$ v! O! Y+ o$ m0 y! ?
* you may need to increase kX buffer size in Windows7/Vista to avoid clicks
! K: m' k: d" }' x9 \2 y1 K3 P9 W& J8 n" y% n% d% e, ]4 i, r
please post your bug reports here3 o6 ^% u% }0 a9 _4 I4 O* i8 ?
6 B2 r. ?, X2 y3 H* ~) B" ]
download:0 u0 r1 n0 d( Y: ]8 U o1 T
8 H( H5 @# U- L, a N3 d
: g$ Y3 u9 F0 `& b2 G3 Ux86 version (Windows XP, Windows Vista, Windows 7): kxdrv3550-x86-full.exe9 V y* h+ @( L- m8 _) a9 d
x64 version (Windows XP, Windows Vista, Windows 7): kxdrv3550-x64-full.exe0 A8 Q, F: v; I9 U M' B
' |: l; Y! ]- I3 @3 u1 L% y* H
* s* W. S* y& h4 S% o: s' p: h% u7 e* K! P: X4 Z. D/ u
Read more: http://www.driverheaven.net/gene ... .html#ixzz0RTBA4IoW% }. @% ?' c! {: @
7 g+ b3 S* X: V* n& J# }5 F2 Z3 g: z" S* m: c( t
ÁíÍâ·ÖÏíÒ»ÏÂÎÒ¹ØÓÚrealtekÔÚWIN 7ϱ¬ÒôµÄ½â¾ö·½·¨0 @0 F7 Z$ {0 Z F$ S$ Q! M- j
7 Q7 L2 S* e9 ?% ]. gÒ»Ö±ÒÔÀ´ÔÚXPÏÂʹÓõͼÊÇsblive£¬µ½ÁËwin7ºóÒ»Ö±Ö»ÄÜÓü¯³ÉµÄALC888£¬µ«ÊDZ¬ÒôµÄÎÊÌâÒ»Ö±ºÜÍ·ÌÛ£¬ÎÒµÄÖ÷°åÊǼ¼¼ÎµÄMA770-US3£¬ºóÀ´·¢ÏÖÊÇÒòΪװÁ˼¼¼ÎµÄ×Ô¶¯³¬ÆµÈí¼þEasytune6µ¼ÖÂÆµÂÊÒ»Ö±ÉÏϲ¨¶¯£¬²ÅÒýÆðÁ˱¬Òô£¬ÏÖÔÚÎÒ°ÑEasytune6ɾµôÁË£¬±¬ÒôÔÙҲû³öÏÖ¹ý£¬½ñÌì¸Õ·¢ÏÖ³ýÁË×îеÄKXÇý¶¯£¬½â¾öÁË4GÄÚ´æÎÊÌ⣬ÎÒ»¹Ã»À´µÃ¼°ÊµÑ飬µÈÓнá¹ûÁËÔںʹó¼Ò·ÖÏí2 @& G( a! W- C. N- X
ÊÕ |
