DVONµÏ»ª°ÄרҵUHFÎÞÏßÂó¿Ë·çϵͳACT-9292
) t+ G2 M- p! k5 K3 N" ^
, o/ X4 e' c! o) s.¾ßÓÐÊÀ½çÏȽøµÄACT(×Ô¶¯ÆµµÀËø¶¨)¹¦ÄÜ£¬ÄÜ¿ìËÙ: U$ r- w7 h. H) J9 k( A
¾«È·µÄ×Ô¶¯Ëø¶¨½ÓÊÕ»úµÄ¹¤×÷ƵÂÊ;
4 Q9 a- D/ S" ?# {.ÓÐ8ÖÖÑÕɫרÓòÊɫβ¸ÇƵµÀʶ±ð;0 j S, t" @/ R# U
.²ÉÓøߴ«Õæ.¿íÒôÓò.¸ß¶¯Ì¬·¶Î§.¸ßÖÊÇåÎúÁÁ
& p" E8 W; I/ C7 I, B6 |8 K ÀöµÄ³¬ÐÄÐÍÖ¸ÏòÐÔµÄßäо;
" W0 w$ }/ ^) @5 n. U- n.CPU¿ØÖÆ;
, N; }/ [ W: C.ËøÏ໷ƵÂʺϳɼ¼Êõ;
5 W& O) O1 e2 R% A( h 4 l9 O. h8 b8 p- B" K+ E2 O) o
.ƵÂÊ·¶Î§:UHF500MHz~96OMHz ¿ÉÑ¡
+ q" V8 C. ?0 A2 O u.µ÷ÖÆ·½Ê½:FM(PLL)( Z# T% N4 Z) B. n* l
.Ƶ ƫ:+25KHz/<+48KHz
& H- d# t V" O& l$ K8 L.ƵÂÊÎȶ¨¶È:<+15ppm
$ t( W- } K- ?) m {" M6 h.ƵÂÊÏìÓ¦:60Hz~18KHz
; A" X& j* f( g7 e0 ^' u8 }.ÐÅÔë±È:>11OdB(A)
/ K% t, r7 t) v j( \.T.H.D:<1%
) |0 A* K' Y I n.¹¤×÷ζÈ:-10¡æ~+55¡æ
0 L; c. r2 L4 H( x% b6 n/ r m/ m& `.½ÓÊÕÐÎʽ:Õæ·Ö¼¯½ÓÊÕ
6 F1 O( B0 T) [1 N# W. _# n: S.ÁéÃô¶È:3uV(52dB S/N)( U7 j. n: P" w; z
.ÒôƵÊä³öµçƽ:6 ~5 M* ~+ C5 n" K6 N; m: C
ƽºâÊä³ö:+1OdB(XLR)( u3 E! ]$ {2 q! k; e' Y1 f
ÒôƵÊä³ö:+4dB(1/4", 6.3mm jack socket). O6 r1 z& B! t
.ÁÚµÀ¸ÉÈűÈ:>80dB
1 q7 y5 {: B4 F& s.¾µÏñ¸ÉÈűÈ:>80dB
. p* ^' ?$ f$ O4 W# |9 l. V& l3 _
.ÕæÕý·Ö¼¯¼¼Êõ;6 i3 V' V5 w T: W! w" O
.´óÆÁÄ»¶¯Ì¬Òº¾§ÏÔʾ£¬¿É¶¯Ì¬ÏÔʾAF, RFµçƽ¼°
j9 r7 f0 t. A( t, A ѶµÀת»»;7 f: ^7 I: n1 c9 V0 ~0 K3 m; K) Q$ B
.100ѶµÀ¿Éµ÷;
& X; ]9 t3 i) H" q; p.Ãæ°å¿ÉÉ趨¹¤×÷¾àÀ룬ÏÔʾ·½Ê½£¬Ãæ°åËø¹¦ÄÜ¡£: }4 q' n6 [ o5 R. h
.ÊʺÏÎę̀Ñݳö7 F; H4 y) d* j M- s) p. y: Z
.Frequency Range:UHF 500~960MHz(Tunable)
}" `- r) P0 n+ q.Modulation Mode:FM(PLL)
& t S5 G# \( \. [.Nominal/peak deviation:+25KHz/+48KHz {: P3 e. w0 L2 U* T7 a
.Frequency Stability:<+15ppm8 s$ y# v) j \6 U4 o
.Frequency Response: 60Hz~18KHz8 Q; B9 D# @9 r8 P( W4 z
.S/N(1 mV RF and peak deviation)Ratio:>11OdB(A)! T5 j$ K4 j: S, C9 c
.T.H.D(at nominal deviation and 1 KHz):<1% y* R9 S) {. m& e
.Temperature range:-10¡æ~+55t! @, H& ]2 r4 A, z* h' B
.Receiver principle:True predictive diversity6 F3 Q4 I. ^8 H0 V6 n5 s B& F
.Sensitivity (Peak deviation):3uV(52dB S/N)4 r, R2 h3 F7 B
.AF output Voltage(at peak deviation 1 KHz AF out):
7 V9 q1 v7 X' ?; h" M" Q Balanced:+1OdB(XLR)' F; E3 b" b' j6 E `
Unbalanced:+4dB(1 /4"£¬6.3mm jack socket), V2 D( q- s8 |% H+ W9 j& ^1 O: R
.F/N Ratio:>80dB# F* d6 R1 r8 I$ q4 K) B' {. l
.P/N Ratio:>80dB
0 o. U5 P8 ]3 @6 J/ y. b9 H; _ ~9 l: ] 0 U0 _) y J" Z3 W
