À´×ÔMac App Store¹Ù·½½éÉÜ
s9 ?* c9 T1 t- B9 u7 w$ n
8 k, R' Y' c U- I+ k7 O9 G, i- h' f' n* @9 c' W( U5 L% t
M-Audio MicroTrack contains drivers for the MicroTrack 24/96.& T, w/ q2 k! |2 h) D7 V
v1.4°æ±¾Ð¹¦ÄÜ3 }6 L6 Y1 C! c. l
4 G/ y; ?0 ~$ z1 o* Y& \% o( \
* I: Z( `$ q4 X# I3 jVersion 1.4:
; v U6 R% S+ t$ l7 h- D+ ^) S5 GSometimes wouldn't use the entire available space of the media and would report media full before it actually was. Even after deleting previous recordings from the media.
' R3 G- S& n. u1 ~/ X) m8 g1 LSometimes reported incorrect file sizes on MP3s.. W- B$ P3 X4 o2 n. Y6 k
Outputs would turn off during playback of some files.; L8 [, o6 B0 q! r
Autosplit feature would not always record to full 2GB file size when source is S/PDIF
8 r- ^2 O) A5 uFiles sometimes were not saved properly if the battery would run out during a recording.$ @( v2 H2 d+ n7 k8 B! [, P
Sometimes would revert to default settings if the battery charge were to run out during use.; O m( g( R6 G. |- W8 @
Recordings would sometimes stop early (before filling media or reaching 2GB) when using S/PDIF as the source.
; l+ z% @1 H" N! K2 p9 uSome French characters and translations were incorrect.. }9 f5 A& x( [1 D5 L1 `" @: Z* C% b5 z0 g
Would not always display the full media message when it should.
- K3 ~$ C- H: p; i, bCould not play files from the 'Files' menu if the files were inside a folder., G" G3 r- C6 t8 N7 h
Sometimes would hang on writing very short (less than 1 second) recordings., H* Z1 `2 n: X; |* I7 V
Some S/PDIF recordings failed to start recording if they immediately followed an analog recording. |
