¹ØÓÚÒôȦ²ÄÖʶԶÔSPKµÄÓ°Ïì
×ªÔØ
SPK Ϊ2´ç  ÄÚ´Åʽ  ²âÁ¿¾àÀëΪ20CM  Èí¼þÉè-16DB
ÎÒÓà ÄÚ¾¶14.28*3.2¦¸*0.13/2FµÄ KAPTONºÍÂÁ¹Ç¼Ü·Ö±ð×öÁËÒ»¸ö2´çµÄ SPK
ºìÉ«SPL »Ò°××迹 Ϊ1ºÅ  ÂÁ¹Ç¼Ü  µ¯²¨1  ÆäËûÒ»ÖÂ
ÂÌÉ«SPL »ÆÉ«×迹 Ϊ2ºÅ  ÂÁ¹Ç¼Ü µ¯²¨2 ÆäËûÒ»ÖÂ
³ÈÉ«SPL À¶É«×迹 Ϊ3ºÅ  KAPTON µ¯²¨1 ÆäËûÒ»ÖÂ
µ­À¶SPL ×ÏÉ«×迹 Ϊ4ºÅ  KAPTON µ¯²¨2 ÆäËûÒ»ÖÂ
1¡¢ÔÚ5KHZÒÔÉÏKAPTON SPL ÓÐÃ÷ÏÔµÄÉÏÉýÇ÷ÊÆ  ÄÇô ÊÇ·ñ¿ÉÒÔ˵µ±  µ÷Õû ¹Ç¼Ü²ÄÖÊ Ò²Êǵ÷ÕûSPLµÄ ÖØÒªÊֶΠ »òÕß´ÎÒªÊÖ¶Î
2¡¢²»Í¬¹Ç¼Ü ¶Ô×迹µÄÓ°Ïì
Çë¸÷λ´óʦָµã
For your questions:
1. Sometimes, depend on size of loudspeaker. As we can see, the increase the SPL is from raw issue -Weight (Mass) of Kapton.
2.Yes, difference material will be effected to impedance of loudspeaker, the big difference is between Al Conducting(Metal) and Kapton non-conducting(Plastic) as raw issue-Faraday Electromagnetic Effect.
    Summary, you need to concerning on the 2 most important when use Al and Kapton material for bobbin
               A: Power handling
               B: Sound quality
1¡¢¸ù¾ÝSPKµÄ¿Ú¾¶ ÓÐʱºòÕâÊÇÒ»ÖÖÊֶΣ¬ Æä±¾ÖÊÊÇ ¹Ç¼ÜÖØÁ¿µÄ±ä»¯ ¶ÔSPK ²úÉúÓ°Ïì  ¡£
2¡¢Êǵ쬲»Í¬²ÄÁϽ«»áÓ°Ïìµ½ÑïÉùÆ÷µÄ×迹£¬ÆäÖнðÊô£¨µ¼Ì壩ÓëËÜÁÏ£¨·Çµ¼Ì壩¶Ô×迹ÓкܴóÓ°Ï죬ԭÒòΪµç´ÅЧӦ
  Äã¸Ã²¹¿ÎÁË£¨ÑïÉùÆ÷֮·ÂþÂþÙ⣬¿´ÊéÈ¥¡£Í¼Æ¬µã»÷¿ÉÔÚд°¿Ú´ò¿ª²é¿´£©
A:µçÔ´´¦Àí   B:ÉùÒôÖÊÁ¿   £¨Õâ¸ö¿´²»¶®»ò·­Òë²»ÁËͼƬµã»÷¿ÉÔÚд°¿Ú´ò¿ª²é¿´£©
²»ÖªµÀÊDz»ÊÇÕâ¸öÒâ˼ ÓдíÎóÇë Ö¸Õý  Ð»Ð»£¡£¡£¡
Á½Õ߹ǼܵÄÖØÁ¿²»Í¬,¸ßÆµÖøÈ»Ò²ÊDz»Í¬.µ±È»×ÐϸÌýÒôÒ²»áÓÐËù²»Í¬.
ÁíÍâ,¶Ô×迹ÇúÏߵķåÖµ¸ß¶ÈÒ²ÊDz»Í¬µÄ.Õâ¹ØÏµµ½QMSµÄ²îÒì.
ÆÀÂÛÁÐ±í£¨1£©
ÐÀÉÍÁË£¬Ð»Ð»Â¥Ö÷·¢²¼°¡ £¬ÎÒÊÕ²ØÁ˰¡
2010-5-11 23:26:31 »Ø¸´
