µ÷Òǫ̂רҵÊõÓï²éѯ
µ÷Òǫ̂
µ÷Òǫ̂רҵÊõÓï²éѯ
2-Track 2¹ì´Å´ø£¨inÊäÈë outÊä³ö£©
AFL=After-fader Listen Ë¥¼õºó¼àÌý£¨ÍÆ×Óºó¼àÌý£©£¬Õâ¸öģʽÏ£¬¼àÌýÊä³öµÄÐźÅÊÇÀ´×ÔÓÚͨµÀµçÆ½ÍÆ¸ËÒÔºóµÄÐźÅ
Aux. =Auxiliary ¸¨Öú
Aux.return ¸¨Öú·µ»Ø£¨»òAux.RTN.»òAux.RET.£©ÓÃÓÚ½ÓÊÕÒôƵ´¦ÀíÉ豸£¨ÈçЧ¹ûÆ÷£¬¼¤ÀøÆ÷£©´¦ÀíºóµÄÒôƵÐźÅÓëÖ÷Êä³öÐźżÓÒÔ»ìºÏ¡£
Aux.send ¸¨ÖúËͳö£¬Ò»°ãÓÃÓÚÊä³öÐźŹ©ÐźŴ¦ÀíÉ豸½øÐд¦Àí£¬»òÊä³öÎę̀¼àÌýÐźš£
Balance ƽºâ£¬Ò»°ãÓÃÓÚÁ¢ÌåÉùÊäÈëͨµÀ£¬È·¶¨Á½Â·ÊäÈëÐźŸ÷×ÔµÄÆ½ºâ¡£
Bus ĸÏß,¹«¹²Ïߣ¬µ÷Òǫ̂ÄÚ²¿µÄÐźÅÏß·Á÷³Ì£¬¶à·ÐźŻãºÏµ½Ä³¸öÏß·ÉÏ£¬ÕâÌõÏß·¾ÍÊÇĸÏߣ¬Ò»°ãµÄ¸¨ÖúºÍ±à×é¶¼ÊÇĸÏ߽ṹ
Clip Ï÷²¨Ö¸Ê¾£¬´ËָʾµÆµãÁÁ»òÐÅºÅµçÆ½Ö¸Ê¾±í´ïµ½Õâ¸öλÖ㬱íÃ÷ÊäÈë»òÊä³öÐźÅÒѾ­´ïµ½¶¥µã¡£
Cue Ìáʾ,¼àÌý£¬°´Ïºó¿ÉÒÔÔÚ¼àÌý¶ú»ú»ò¼àÌýͨµÀ¼àÌý´Ë·µÄÐźš£
Direct Ö±½ÓµÄ(Êä³ö)²å¿Ú
Effect Ч¹û
EQ=Equalizer ¾ùºâÆ÷£¬µ÷Òǫ̂µÄ¾ùºâÒ»°ã·ÖÈý¶Î»òËĶΣ¬ÓÐЩ¾ßÓÐɨƵ¹¦ÄÜ£¬¿ÉÒÔ¶ÔÑ¡¶¨µÄƵ¶Î½øÐÐµçÆ½µÄÌáÉý»òË¥¼õ¡£
Fader Ë¥¼õÆ÷,ÍÆ×Ó
Foldback ·µËÍ
Gain ÔöÒæ,·Å´óÁ¿
Group ±à×é
HF=High Frequency ¸ßƵ¶Î
HP=Headphone=Phones ¶ú»ú
INS. =Insert ¶Ïµã²åÈë²å¿Ú,Ò²³ÆÓÖ³öÓÖ½ø²å¿Ú£¬Õâ¸ö²å×ùÒ»°ãÓÃÓÚ½«Ò»¸öÐźŴ¦ÀíÉ豸ֱ½Ó²åÈëµ½µ÷Òǫ̂µÄij¸öÊäÈë»òÕßÊä³öͨµÀ£¬¶Ô¸ÃͨµÀµÄÒôƵÐźŽøÐиü¾«Ï¸µÄ´¦Àí¡£
Level µçƽ
LF=Low Frequency µÍƵ¶Î
Limit ÏÞÖÆ
Line inÏß·»ò¸ß×迹É豸ÊäÈë²å¿Ú
LMF=Low-Mid Frequency ÖÐµÍÆµ¶Î
Low cut µÍƵÇгý(ÀýÈçÇÐÈ¥100HzÒÔÏÂÆµÂʳɷÖ)
L-R=Left-Right ×ó-ÓÒ
Main Sum »ìºÏµ¥ÉùµÀ£¬Õâ¸öÊä³ö²å×ùÊä³öµ÷Òǫ̂ÄÚ²¿»ìºÏºÃµÄµ¥ÉùµÀÐźš£
Master Ö÷¿Ø,Ö÷Êä³ö¡£
Matrix ¾ØÕóÊä³ö
Meter Assign ±íÍ·É趨£¬È·¶¨µçƽָʾ±íÏÔʾʲôÄÚÈÝ£¬±ÈÈçÖ÷Êä³ö»ò±à×éÊä³ö¡£
MF=Mid Frequency ÖÐÆµ¶Î
MHF=Mid-High Frequency ÖÐ¸ßÆµ¶Î
Mic. =Microphone »°Í²»òµÍ×迹É豸²å¿Ú
Mix »ìºÏ
Mixer »ìºÏÆ÷£¬»ìÒôÆ÷
Monitor ¼àÊÓ£¬¼àÌý£¬¼àÊÓÆ÷£¬¼àÌýÒôÏä
Mono µ¥Éù
Music ÒôÀÖ
Mute ÑÆÒô£¬¾²Òô
On ½Óͨ
Osc. =Oscillator Õñµ´Æ÷£¬Ò»°ã¿ÉÊä³ö20Hz£­20KHz»òµ¥¶ÀµÄ1KHzµÄÕýÏÒ²¨»ù׼ƵÂÊÐźţ¬ÓÃÓÚ²âÊÔϵͳ¡£
Pad ¶¨ÖµË¥¼õ£¬Ò»°ã½«ÊäÈëÐÅºÅµçÆ½Ë¥¼õ10»ò20·Ö±´
Pan ÉùÏñµ÷½Ú£¬½«ÊäÈëÐźŷÖÅäµ½×ó·ͨµÀÓëÓÒ·ͨµÀÖ®¼äµÄÈÎÒâλÖá£
PFL=Pre-Fader Listen Ë¥¼õǰ¼àÌý£¨ÍÆ×Óǰ¼àÌý£©
Phantom+48V »ÃÏóµçÔ´+48V£¬ÓÃÓÚÁ¬½ÓµçÈÝ»°Í²Ê±£¬¸øµçÈÝ»°Í²¹©µç¡£
PK. =Peak ·åֵָʾµÆ£¬´ËµÆÉÁÁÁʱ£¬±êÃ÷ÊäÈëÐÅºÅµçÆ½Ç¿¶ÈÒѾ­´ïµ½×î¸ß¡£
Power Switch µçÔ´¿ª¹Ø
Quartz Oscillator ʯӢ¾§ÌåÕñµ´Æ÷
Slate 񈬀
Solo ¶À×࣬¶ÀÁ¢¼àÌý°´Å¥£¬ÔÚµ÷Òǫ̂ÉÏÓëCUEÓÐͬÑùµÄÒâÒå¡£
Stereo Á¢ÌåÉù
Sub. in ¸½¼ÓÊäÈë
Tape ´Å´øÊäÈë²å¿Ú
TB=Talkback ¶Ô½²
Trim. ·Å´óÁ¿µ÷½Ú
Unbalance ·Çƽºâ
Value ÊýÖµ
Volume ÒôÁ¿£¬¾í
¶þ¡¢Óйش«ÉùÆ÷µÄרҵӢÎÄ´Ê»ã
Bidirectional Ë«ÏòÐÔµÄ
Cardioids ÐÄÐÎ
Condenser Microphone µçÈÝʽ´«ÉùÆ÷£¨µçÈÝ»°Í²£©
Counteracting Proximity Effect ¿¹½ü¾àÀëЧӦ£¨½ü½²´«ÉùÆ÷£©
Dynamic Microphone µç¶¯Ê½´«ÉùÆ÷£¨¶¯È¦»°Í²£©
Electrets Condenser Microphone פ¼«Ìå´«ÉùÆ÷£¨³£ÓÃÓÚ²âÊÔÒÇÆ÷ÉÏ£©
Frequency Range ƵÂÊ·¶Î§
Mic. = Microphone ´«ÉùÆ÷
Output Impedance Êä³ö×迹
Polar pattern ¼«ÐÔͼ
SPL=Sound Pressure Level Éùѹ¼¶
Sensitivity ÁéÃô¶È
Supercardioid=Hypercardioid ³¬ÐÄÐÎ
Unidirectional µ¥ÏòÐÔµÄ
Wireless Mic. ÎÞÏß´«ÉùÆ÷
Èý¡¢Óйع¦ÂÊ·Å´óÆ÷µÄרҵӢÎÄ´Ê»ã
Bridge Mono ÇÅʽµ¥ÉùµÀ¹¤×÷ģʽ
Clip Ï÷²¨Ê§ÕæÖ¸Ê¾£¬µ±Õâ¸öָʾµÆµãÁÁʱ£¬±êÃ÷¹¦·ÅµÄÊäÈëÐÅºÅµçÆ½ÒѾ­´ïµ½²¢³¬¹ý¹¦·Å¶î¶¨ÊäÈëµÄÁéÃô¶Èµçѹ¡£
Damping Factor ×èÄáϵÊý£¬×èÄáÒò×Ó£¬Ó°Ï칦·Å¶ÔÒôÏäµ¥ÔªµÄ¿ØÖÆÄÜÁ¦£¬×èÄáϵÊýÔ½¸ß£¬¿ØÖÆÄÜÁ¦Ô½Ç¿£¬ÉùÒôËÙ¶ÈÔ½¿ì£¬µ¯ÐÔÔ½²î¡£
GND=Ground ½ÓµØ
Input Impedance ÊäÈë×迹
Input Level ÊäÈëµçƽ
Left ÍѵØ×´Ì¬£¬¹¦·ÅºóÃæµÄ½ÓµØ¿ª¹Ø´¦ÓÚÕâ¸öλÖã¬ÄÚ²¿µÄÐźŽӵØÓëÍâ¿Ç½ÓµØ·Ö¿ª¡£
Parallel Mono ²¢½Óµ¥Éù£¬·Å´óÆ÷Á½¸ö·Å´óͨµÀ½ÓÊÕͬһ¸öÊäÈëÐźŽøÐзŴó¡£
Power Amplifier ¹¦ÂÊ·Å´óÆ÷
Professional רҵµÄ
Protection ±£»¤
Rate Power ¶î¶¨¹¦ÂÊ
Signal ÐźÅָʾ
Slew Rate ת»»ÂÊ
Stereo Mode Á¢ÌåÉùģʽ
THD=Total Harmonic Distortion ×Üг²¨Ê§Õæ
ËÄ¡¢Óйصç×Ó·ÖÆµÆ÷¡¢ÑïÉùÆ÷¡¢ÒôÏäµÄרҵӢÎÄ´Ê»ã
3-Way Stereo 3·ÖƵÁ¢ÌåÉùģʽ
Bass µÍÒô
Cross Frequency ·ÖƵÆ÷½»²æÆµµã
Crossover Network="Crossover" ·ÖÆµÍøÂ磬ÒôÏäÄÚ²¿µÄÎÞÔ´·ÖƵÆ÷¡£
Divided by 10 ±»10³ý£¨Ê®·ÖÖ®Ò»£©£¬Ò»°ã±êÓÚÆµÂÊÑ¡Ôñ£¬ÐýÅ¥ËùÑ¡µÄƵÂʵÄÊ®·Ö֮һΪʵ¼ÊÑ¡ÔñµÄƵÂÊ¡£
Enclosure ÒôÏ䣨һ°ãÖ¸ÏäÌ壩
HF ¸ßƵ¶Î
Input Gain ÊäÈëÔöÒæ
LF µÍƵ¶Î
MF ÖÐÆµ¶Î
Mid Range Speaker ÖÐÆµÑïÉùÆ÷
Mid ÖÐÒô
Mute ÑÆÒô£¨¼ü£©
Power Capacity £¨INPUT POWER£©¹¦ÂÊÈÝÁ¿
Reverse Phase Ïàλµ¹×ª£¨·´Ïࣩ
Subwoofer ³¬µÍÒôÑïÉùÆ÷
Treble ¸ßÒô
Tweeter ¸ßƵÑïÉùÆ÷
WooferµÍƵÑïÉùÆ÷
Îå¡¢ÓйؾùºâÆ÷µÄרҵӢÎÄ´Ê»ã
BPF=Band Pass Filter ´øÍ¨Â˲¨Æ÷
EQ=Equalizer ¾ùºâÆ÷
EQ Control Range ¾ùºâ¿ØÖÆ·¶Î§
Graphic Equalizer ͼʾ¾ùºâÆ÷
High Cut ¸ßÇУ¨ÀýÈçÇгý6kHzÒÔÉÏÆµÂʳɷ֣©
HPF=High Pass Filter ¸ßͨÂ˲¨Æ÷£¬¸ßÓÚÕâ¸öÂ˲¨Æ÷É趨ƵÂʵÄÐźſÉÒÔͨ¹ý¡£
In/Out ½Óͨ¿ª¹Ø
Input Gain ÊäÈëÔöÒæ
Low CutµÍÇУ¨ÀýÈçÇгý200HzÒÔÏÂÆµÂʳɷ֣©
LPF=Low pass Filter µÍͨÂ˲¨Æ÷
Parameter Equalizer ²ÎÁ¿¾ùºâÆ÷
Room Equalizer ·¿¼ä¾ùºâÆ÷
Sweep Frequency ɨƵ
Áù¡¢ÓйØÑ¹ÏÞÆ÷µÄרҵӢÎÄ´Ê»ã
Attack Time Æð¶¯Ê±¼ä£¬±íÃ÷µ±ÊäÈëµçƽµ½´ïѹËõÆ÷Æô¶¯µçƽʱ£¬Ñ¹ËõÆ÷¿ªÊ¼¹¤×÷ËùÐèÒªµÄʱ¼ä¡£
Compress Switch ѹËõ¿ª¹Ø£¬°´ÏÂÕâ¸ö¿ª¹Ø£¬Ñ¹ËõÆ÷½øÈ빤×÷״̬£¬·´Ö®²»Æð×÷Óá£
Compress Ratio ѹËõ±È£¬µ÷ÕûÔÚѹËõÆ÷¿ªÊ¼¹¤×÷ʱ£¬Ñ¹ËõÆ÷°´ÕÕʲôÑùµÄѹËõ±ÈÀý¶ÔÊäÈëÐźų¬¹ýÆô¶¯µçƽµÄ²¿·Ö½øÐÐѹËõ¡£
Compressing Threshold ѹËõãУ¬Ñ¹ËõÆ÷µÄÆô¶¯µçƽֵ£¬µ±ÊäÈëµçƽ´ïµ½²¢¸ßÓÚÕâ¸öÊýֵʱ£¬Ñ¹ËõÆ÷¿ªÊ¼¹¤×÷£¬¶ÔÊäÈëÐźſªÊ¼Ñ¹Ëõ¡£
Compressor/Limiter ѹÏÞÆ÷£¨Ñ¹ËõÏÞ·ùÆ÷£©
Compressor ѹËõÆ÷
Gain Reduction ÔöÒæË¥¼õ
Gate Threshold ÃÅãУ¬ÔëÉùÃÅ¿ªÆôµÄµçƽֵ£¬µÍÓÚÕâ¸öÊýÖµµÄÊäÈëÐźŽ«±»ÔëÉùÃÅ×èµ²¡£
Input Gain ÊäÈëÔöÒæ
Limiter ÏÞ·ùÆ÷
Output Gain Êä³öÔöÒæ
Ratio ±È
Release Time »Ö¸´Ê±¼ä£¬µ±ÊäÈëµçƽµÍÓÚѹËõÆ÷Æô¶¯µçƽºó£¬Ñ¹ËõÆ÷»Ö¸´µ½Õý³££¨²»Ñ¹Ëõ£©×´Ì¬ËùÐèÒªµÄʱ¼ä¡£
Side Chain ±ßÁ´µç·
Stereo Link Á¢ÌåÉùÁ¬½Ó
Threshold ãÐ
Æß¡¢ÓйØÀ©Õ¹Æ÷¡¢ÔëÉùÃŵÄרҵӢÎÄ´Ê»ã
Attack Time Æð¶¯Ê±¼ä£¬µ±ÊäÈëµçƽ´ïµ½ÔëÉùÃÅ¿ªÆôµçƽʱ£¬ÔëÉùÃÅ¿ªÆôËùÐèÒªµÄʱ¼ä¡£
Attenuation Ë¥¼õÁ¿
Expander À©Õ¹Æ÷
Exp.Gate À©Õ¹ÃÅ
Expanding Threshold À©Õ¹ãУ¬À©Õ¹Æ÷¿ªÊ¼¹¤×÷µÄµçƽֵ
Expanding Ratio À©Õ¹±È
Gate Threshold ÃÅãÐ
Noise Gate ÔëÉùÃÅ
Release Time »Ö¸´Ê±¼ä£¬µ±ÊäÈëµçƽµÍÓÚÔëÉùÃÅ¿ªÆôµçƽʱ£¬ÔëÉùÃŹرÕËùÐèÒªµÄʱ¼ä¡£
Side Chain ±ßÁ´µç·
°Ë¡¢Óйؼ¤ÀøÆ÷µÄרҵӢÎÄ´Ê»ã
Drive ¼¤Àøµçƽ
Enhancer ÔöÒôÆ÷
Exciter ¼¤ÀøÆ÷
Girth µÍÒôÁ÷Á¿£¨Ó°ÏìÉùÒô·áÂú¶È£©
Harmonic Generator г²¨·¢ÉúÆ÷
Hi-Mix ¸ßƵ»ìºÏ
In/Out ½Óͨ
Low-Mix µÍƵ»ìºÏ
Mix »ìºÏ£¨±ÈÀý£©
Overhang µÍÒô±£³Ö£¨Ó°ÏìÉùÒô»ëºñ¶È£©
Tune µ÷г£¬Ñ¡ÔñÐèÒª¼¤ÀøµÄƵ¶Î
¾Å¡¢Óйط´À¡ÒÖÖÆÆ÷µÄרҵӢÎÄ´Ê»ã
Bandwidth Ƶ´ø¿í¶È
Bypassֱͨ¿ª¹Ø
Clip Level AdjustÏ÷²¨µçƽµ÷Õû
DecayË¥¼õ
Engine L ×óͨµÀ½Óͨ
Engine R ÓÒͨµÀ½Óͨ
Feedback Destroyer ·´À¡Ë¥¼õÆ÷
Feedback terminator ·´À¡ÒÖÖÆÆ÷
Filter Select Â˲¨Æ÷Ñ¡Ôñ
Filter Mode Â˲¨Æ÷¹¤×÷ģʽ
Frequency Fine ƵÂÊ΢µ÷
Gain ÔöÒæ
In/Out ½ÓÈ뿪¹Ø
Lock Fixed Ëø¶¨Ä£Ê½
Store ´¢´æ
Total Number Â˲¨Æ÷×ÜÊý
Ê®¡¢ÓйØÐ§¹ûÆ÷µÄרҵӢÎÄ´Ê»ã
(A/D D/A)Conversion £¨Ä£/Êý Êý/Ä££©×ª»»Æ÷
Bypass ֱͨ£¨ÅÔ·£©
Cathedral ½ÌÌÃʽ»ìÏì
Chamber ÃÜÊÒÐÍ»ìÏì
Channel ͨµÀ
Chord ºÏÏÒ
ChorusºÏ³ªÐ§¹û
Delay ÑÓʱЧ¹û
Delay Effect Processor ÑÓʱЧ¹û´¦ÀíÆ÷
Digital Êý×Ö»¯
Dual ˫·
Dynamic Doubling ¶¯Ì¬Ë«ÉùЧ¹û
Echo »ØÉùЧ¹û
Edit ±à¼­Ä£Ê½
Effect Ч¹ûÆ÷
Effect Processor Ч¹û´¦ÀíÆ÷
EQ=Equalizer ¾ùºâ
ER=Early Reflection ÔçÆÚ·´ÉäÉù
Footswitch Jack ½Å̤°åЧ¹ûÆ÷¿ª¹Ø½ÓÈë²å×ù
Fullness ·áÂú¶È
Gate Rev. ÃÅ»ìÏì
Guitar ¼ªËû
Gymnasium ÌåÓý¹Ý»ìÏìЧ¹û
Hall´óÌü»ìÏìЧ¹û
Hold ±£³Ö
InterparameterÄÚ²¿²ÎÊý
Inversive Rev. ·´Ïò»ìÏì
Key control ¼ü¿Ø
Long ³¤£¨»ìÏì¡¢»ØÉù£©
Memory ¼ÇÒä
MIDI=Music Instrument Digital Interface Êý×ÖÀÖÆ÷½çÃæ
Mix »ìºÏ
Modulation µ÷ÖÆ
Multi-Tap ¶àÖØ»ØÉù£¨Ò»°ãÓÃÓÚÑÓʱЧ¹û£©
Once Touch µ¥´Î´¥·¢
Phase Ïàλ
Piano ¸ÖÇÙ
Pitch ±äµ÷
Plate ½ðÊô°å»ìÏì
Predelay Ô¤ÑÓʱʱ¼ä
Preset Ô¤Éè
RecallÄÚ´æµ÷³ö
Reinforcement ·Å´ó
Remote ControlÒ£¿Ø
Resonance ¹²Õñ
Rev.Time»ìÏìʱ¼ä£¨¼ò³ÆRT£©
Reverberation »ìÏì
Reverberation Effect Processor »ìÏìЧ¹û´¦ÀíÆ÷
Reverse Reverberation ·­×ª»ìÏì
Room·¿¼ä»ìÏìģʽ
Sample ²ÉÑù
Saxophone Èø¿Ë˹
Short ¶ÌµÄ£¨»ØÉù»òÑÓʱ£©
Singlelµ¥Â·
SlapÅÄ´ò£¬Çû÷
Slope Ë¥¼õбÂÊ
Sound Pressure Éùѹ
Stereo Flange Á¢ÌåÉùÏâ±ßЧ¹û
Store´¢´æ
TempoËÙ¶È£¨½ÚÅĵÄËÙ¶È£©
Thru =Through ֱͨ£¨ÓÃÓÚMIDI½Ó¿Ú£©
Trigger ´¥·¢
ʮһ¡¢ÆäËû³£ÓÃרҵӢÎÄ´Ê»ã
Adapterת½ÓÆ÷£¬Ò»°ãÓÃÓÚµçԴת»»
AntennaÌìÏß
Beat Signal²îÅÄÐźÅ
BrightnessÃ÷ÁÁ¶È
CD=Compact Disc¼¤¹â³ª»ú
Clear ButtonÇå³ý¼ü
ClockÖÓÂö³å
Compensate²¹³¥
ConnectorÁ¬½ÓÆ÷
Continued PlayÁ¬Ðø²¥·Å
Contrast¶Ô±È¶È
De-emphasisÈ¥¼ÓÖØ
De-esserÈ¥¡°ßÐßС±Éùµç·»ò¹¦ÄÜ
DisplayÏÔʾ
Drum¹Ä
Dry¸ÉÉù
Dynamic Range¶¯Ì¬·¶Î§
EraseĨ³ý
F&B Search ButtonsǰºóËÑË÷¼ü
Flow ChartÁ÷³Ìͼ
Forward & Backward Skip ButtonsǰºóÌøÔ¾¼ü
Hum and Noise½»Á÷¡°ºßºß¡±ÔëÉù
Index ButtonË÷Òý¼ü
Keyboard¼üÅÌ
KnobÐýÅ¥
Multipurpose¶àÖØÄ¿µÄ£¬¶à¹ì·ÅÉù
PauseÔÝÍ£
Pedal̤°å
Programmable¿É±à³ÌÐòµÄ
Projector TVͶӰµçÊÓ
PulseÂö³å
Push-PullÍÆÍìµç·
QuantizationÁ¿»¯
Random PlayËæ»ú²¥·Å
Racks»úÏä
Receiver½ÓÊÕ»ú
Remaining TimeÊ£Óàʱ¼ä
Repeat PlayÖØ¸´²¥·Å
RF=Radio FrequencyÉ䯵
Scan PlayɨÃè²¥·Å
SelectorÑ¡ÔñÆ÷
Servo SystemËÅ·þϵͳ
Shuffle PlayËæ»ú²¥·Å
Stage MonitorÎę̀¼àÌýÒôÏä
Standby×¼±¸
Stands»ú¼Ü
StopÍ£»ú
SynthesizerºÏ³ÉÆ÷£¬×ÛºÏÆ÷
Tape Background noise´Å´ø±¾µ×ÔëÉù
Theatre¾ç³¡
Time Codeʱ¼äÂë
Timer¶¨Ê±Æ÷
Tip-Ring-Sleeveо-»·-Ì×Ͳ
Video Signal ÊÓÆµÐźÅ
WetʪÉù
Ê®¶þ¡¢ÓйØÒôÖÊÆÀ¼Û·½ÃæµÄרҵӢÎÄ´Ê»ã
Bright LightÃ÷ÁÁµÄ
Brilliant»Ô»ÍµÄ
ColdËÀ°åµÄ£¬±ùÀäµÄ
Dark»Ò°µ
DistinctÇåÎúµÄ
FineÏËϸµÄ
Graceful ¸ßÑŵÄ
Hard Ó²µÄ
Heavy Éî³Á
Joyful »¶¿ìµÄ
Mellow ÈáÈíµÄ
Powerful Ç¿¾¢µÄ
Rich¡¢Full ·áÂú
Rough ´Ö²ÚµÄ
Round Ô²ÈóµÄ
Sonorous àÚÁÁµÄ
tirring »îÆÃµÄ£¬ÈÈÁÒµÄ
Suitable ºÏÊʵÄ
Sweet ÔöúµÄ£¬ÌðÌðµÄ
Transparent Ç峺µÄ
Weak ÈíÈõÎÞÁ¦
Îę̀¾ç³¡³£ÓÃÊõÓï
¾ç³¡ Theatre
Îę̀ Stage
Ö÷Îę̀ Main stage
¸±Îę̀ Wing space
´óÄ»Ïß Curtain line
ÖÐÐÄÏß Center line
±íÑÝÇø Acting space
Éϳ¡Çø Stage right
ϳ¡Çø Stage left
ת̨ Revoling Stage
Éý½µÌ¨ Elevator stage
̨¿Ú Proscenium Arch
¼Ų̀¿Ú False Proscenium
ÀÖ³Ø Orchestra Pit
̨´½ Apron
»¨µÀ Flower Way
ǰÌü Lobby
´óÄ» House Curtain
¶þµÀÄ» In Two
±ßÄ» Tormenter
ÑØÄ» Teaser
ÌìÄ» Hrizont
