DPA d:facto II ÊÖ³ÖÈËÉù»°Í²
תÌû
·Ç³£×ÔÈ»µÄÉùÒô
¸ß·ÖÀë¶È
¼«¸ßÉùѹ¼¶³ÐÊÜÁ¦
¼«µÍµÄÊÖ³ÖÔëÉù
¿ÉÑ¡ÅäÎÞÏßϵͳÊÊÅä
d:factoϵÁл°Í²Äܹ»ÎªÎę̀ÏÖ³¡´øÀ´ÕæÊµµÄ¼ÒôÅï¼¶±ðÉùÒôÆ·ÖÊ£¬ÏȽøµÄÊÊÅäÆ÷¿ÉÒÔÈøèÊÖºÍÒôÏìʦÃÇÎÞ·ìÁ¬½Ó¶àÖÖרҵ¼¶ÎÞÏßϵͳ¡ª¡ª²¢ÇÒ²»»áÓÐË¿ºÁµÄÒôÖÊËðʧ¡£
ÐÂÒ»´úd:facto II»°Í²ÎªÊ¹ÓÃÕß¼ÌÐø·îÉÏ·Ç·²µÄDPAÒôÖʲ¢ÇÒ¿ÉÒÔÓë¶àÖÖÏÖÓеÄÎÞÏßϵͳÁ¬½Ó£¬ÀýÈçWisycom¡¢Shure¡¢Sony¡¢Sennheiser¡¢Lectrosonic¡£d:facto IIÌṩÁ˸üºÃµÄÉùÒô±íÏÖ£¬·Ç³£Æ½Ö±µÄÔÚÖáÓëÆ«ÖáÆµÂʺÍÏàλÏìÓ¦£¬³öÉ«µÄÇåÎú¶ÈºÍ¾«×¼¶È¿ÉÒÔÊ®·ÖÇáËɵÄÖØÏÖ¸èÊÖµÄÉùÒô¡£
¾ÍÏñÔÚ¼ÒʹÓû°Í²À©Éù»ò¼ÒôÒ»Ñù£¬d:facto IIÒ²¿Ï¶¨ÄÜÁ¢¼´³ÉΪÏÖ³¡ÒôÏìʦµÄ×î°®¡£Ëü¼òµ¥µÄ¼´²å¼´Óù¦ÄÜ»¹ÄÜÖØÏÖ¼«Æä×ÔÈ»µÄÉùÒô£¬Éùѹ¼¶¿ÉÒÔ´ïµ½¼«¸ßµÄ160dB£¬d:facto IIÄÜÌṩ×ã¹»¸ßµÄÔöÒæ¶ø²»ÈÝÒײúÉúÐ¥½Ð£¬²¢ÇÒÔÚ»°Í²Öл¹ÖÃÈë¸ßÃܶÈÈý¼¶·ÀÅç±£»¤ÍøÀ´Â˳ý²»ÐèÒªµÄÔëÒô¡£
The Perfect Wireless Mic Upgrade!
Get amazing sound at home and onstage with the DPA d:facto II Vocal Mic. This supercardioid, condenser vocal mic provides extremely clear sound with superb definition. The d:facto II houses a multi-function capsule. By using an optional adapter you can use the supercardioid capsule with various wireless microphone systems including Sony, Lectrosonics, Shure, Wisycom, Sennheiser, and more. Onstage, you&££39;ll really appreciate the mic&££39;s supercardioid polar pattern, which maximizes gain-before-feedback. DPA is well known for the exceptional quality of its studio mics. Now you can get that great sound live, with the DPA d:facto II Vocal Mic.
DPA d:facto II Supercardioid Condenser Vocal Mic at a Glance:
Superb sound and performance
Use this mic with your wireless system
DPA studio quality in a handheld mic
No matter what your application, the DPA d:facto II Vocal Mic is ready. Whether you are using it for sound reinforcement or in the studio, this mic has the sound and definition you want. The supercardioid capsule delivers an exceptionally natural sound and great separation from other sound sources onstage. The DPA d:facto II Vocal Mic was designed to give you the best performance and shine through on any stage.
Have you been wishing your wireless mic sounded better? DPA designed the d:facto II Vocal Mic to be the perfect solution. You get the amazing sound, definition, and sound separation of the supercardioid capsule and the versatility of setting it up for your wireless system. Simply remove the capsule, and with an optional adapter, you can use it with your favorite wireless mic. Adapters are available for wireless mics by Sony, Line 6, Lectrosonics, Shure, Wisycom, and Sennheiser.
DPA has a long history of producing amazing studio and live condenser microphones. Now they bring their experience and knowledge to handheld mics. The supercardioid design of the DPA d:facto II Vocal Mic makes it extremely usable in any recording or live situation. It minimizes bleed from other instruments while delivering natural-sounding vocals with amazing definition. Best of all you can use this mic&££39;s capsule in your favorite wireless mic to get the same versatility and sound. Grab the DPA d:facto II vocal Mic and see what you&££39;ve been missing!
DPA d:facto II Supercardioid Condenser Vocal Mic Features:
Supercardioid, condenser vocal mic with built-in wireless adapter system
Superb definition and natural sound
Extremely high SPL rating of 160dB
Offers superb gain-before-feedback
Phenomenal separation from other sound sources
Three-stage pop screen kills unwanted noise
Mic can be used with wireless systems by changing the wireless adapter
Requires 48V phantom power
Works with Sony, Lectrosonics, Shure, Wisycom, Sennheiser wireless units and more
Get a great-sounding mic that can be converted to work with your wireless system with the DPA d:facto II Vocal Mic! 3_596_57323_750_301.jpg
Tech Specs
Microphone TypeCondenser
Polar PatternSupercardioid
Frequency Response20 Hz - 20 kHz
Max SPL160dB SPL
Signal to Noise Ratio75dB
ColorBlack
ConnectorXLR
Weight10.9 oz.
ÆÀÂÛÁÐ±í£¨2£©
Ö§³Ö£¡£¡£¡:victory::victory:
2010-5-1 01:42:25 »Ø¸´
ÔÙÀ´¸Ðл£¡DPA d:facto II ÊÖ³ÖÈËÉù»°Í²
2010-5-4 15:31:23 »Ø¸´
