KRK ROKIT ϵÁмàÌýÒôÏä RP6
²úÆ·Ãû³Æ£º KRK ROKIT ϵÁмàÌýÒôÏä RP6
²úÆ·Ðͺţº RP6
²úÆ·³§ÉÌ£º ÆäËû
²úÆ·¼Û¸ñ£º 2999Ôª
²úÆ·ÐÅÏ¢£º
KRKÈ«ÊÀ½ç×îÊÜ»¶ÓµÄDJ¼àÌýÒôÏä
| RP6G2 | 6"µÍÒôÀ®°È[size=+0](²£Á§ÏËά¸´ºÏ²ÄÁÏ[size=+0]) | 1"¸ßÒôÀ®°È[size=+0](îÏÖÆÔ²¶¥[size=+0]) | ÊäÈë½Ó¿Ú:XLR(3pin), 1/4" TRS, RCA | ¿ØÖÆ:µçƽ¿ØÖÆ,¸ßµÍƵ¿ØÖÆ | 100Íß,Ë«¹¦·Å | ƵÂÊ:53Hz - 20kHz | ³ß´ç:32.1cm x 22.5cm x 29 cm | ÖØÁ¿:11kg |
[/td][/tr]
[/table]
Drivers: Woofer:5" Glass Aramid Composite Woofer
Tweeter:1" Neodymium Soft Dome Tweeter with Ferro Fluid
Input: XLR (3-pin), RCA & 1/4" TRS - 10k Ohm, Balanced / Unbalanced
Amplification: 100 Watt Dynamic Power Bi-amp, 24 dB Octave Filters
Freq Response: 49Hz - 20kHz (+/- 1.5 db)
Video Shielding: Yes
Dimensions:(H x W x D) 12 11/16" x 8 7/8" x 11 1/2"
Shipping Weight:
23 lbs (11 Kg)
