ÃÀÆæ MACKIE 802 VLZ3 802VLZ3µ÷Òǫ̂
²úÆ·Ãû³Æ£º ÃÀÆæ MACKIE 802 VLZ3 802VLZ3µ÷Òǫ̂
²úÆ·Ðͺţº 802 VLZ3
²úÆ·³§ÉÌ£º Mackie
²úÆ·¼Û¸ñ£º 2100Ôª
²úÆ·ÐÅÏ¢£º
802-VLZ3Êdz¬Ð¡Ð͵Ä8·ģÄâµ÷Òǫ̂£¬µ«ÔÚÆ·ÖÊ·½ÃæÃ»ÓÐÈκÎÍ×С£Ê¹ÓÃXDR2»°·Å£¬EQ£¬¼«¸ßµÄ¶¯Ì¬·¶Î§£¬¼«µÍµÄµ×Ô룬¿ÉÁ¬½ÓÏß·ÊäÈë»ò¸ß×輪ËûÊäÈë¡£´ø»ÃÏ๩µç£¬¿ÉÏÔʾ³öÒôÁ¿µçƽ¡£
802-VLZ3ÓÐ5¸öµ¥ÉùµÀµÄÏß·/¸ß×èÊäÈ룬ÆäÖÐÓÐ3¸öÉùµÀÊäÈë´øÓÐXDR2»°·Å£¬¸ßͨÂ˲¨£¬2¶ÎEQ£¬¹ýÔØÖ¸Ê¾µÆ¡£ËùÓÐͨµÀ¶¼´øÇ°ÖûòºóÖø¨Öú·¢ËÍͨµÀ£¬ºÍÒ»¸öÁ¢ÌåÉùµÄ¸¨Öú·µ»Ø¡£³ýÖ÷Êä³öÍ⻹´øÓжîÍâµÄ¿ØÖÆÊÒÊä³ö¡£
We have the mixer for you¡ªthe 8-channel 802-VLZ3.ÎÒÃÇÓе÷Òǫ̂ΪÄãµÄ8ͨµÀ802 - VLZ3 ¡£A professional compact mixer designed just to fit your needs, as well as your workspace, the 802-VLZ3 packs renowned VLZ3 quality into a tight, sleek package.רҵÉè¼Æ½ô´ÕµÄµ÷Òǫֻ̂ÊÇΪÁËÂú×ãÄúµÄÐèÒª£¬ÒÔ¼°ÄúµÄ¹¤×÷£¬ÔÚ802 - VLZ3°üÖøÃûVLZ3ÖÊÁ¿³ÉÒ»¸ö½ôÃÜ£¬¹â»¬·â×°¡£Don¡¯t let the small size fool you¡ªthe 802-VLZ3 is all pro, and all VLZ3.²»ÒªÈùæÄ£Ð¡Éµ¹ÏÄãµÄ802 - VLZ3ÊÇËùÓÐÖ°ÒµÇòÔ±£¬ºÍËùÓÐVLZ3 ¡£It boasts the same signature VLZ3 high headroom / low noise design that makes others in the series prized in studios and stages worldwide, including premium XDR2 preamps, an ultra-musical EQ and modern summing bus architecture.ËüÓµÓÐÏàͬµÄÇ©×ÖVLZ3¾»¿Õ¸ß/µÍÔëÉùÉè¼Æ£¬Ê¹ÆäËû·½ÃæµÄһϵÁÐÕä¹óµÄ¹¤×÷ÊÒºÍÈ«ÊÀ½çµÄ½×¶Î£¬°üÀ¨±£·ÑXDR2¹¦·Å£¬³¬ÒôÀÖ¾ùºâºÍÏÖ´ú×ܽá×ÜÏ߼ܹ¹¡£Ideal for home studio and on-the-go applications, the 802-VLZ3 makes premium mixing capabilities available for setups where space, and money, are tight.ÀíÏëµÄ¼ÒÍ¥¹¤×÷ÊÒ£¬²¢ÔÚ;ÖÐÓ¦Ó㬠802 - VLZ3ʹ±£·Ñ»ìºÏÄÜÁ¦¿ÉÉèÖÃÔÚ¿Õ¼äºÍ½ðÇ®£¬ÊǽôÕÅ¡£It¡¯s all the mixer you need, in a footprint that fits just about anywhere, at a price that fits your budget.ÕâÊÇËùÓеĵ÷Òǫ̂Âú×ãÄãµÄÐèÒª£¬ÔÚÒ»¸ö×ã¼£ÊʺÏÈκεط½£¬¼Û¸ñÊʺÏÄúµÄÔ¤Ëã¡£
XDR2 preampsXDR2¹¦·Å
Extended Dynamic Range=Extended Sonic PossibilitiesÀ©Õ¹¶¯Ì¬·¶Î§=Éù²¨ÑÓ³¤µÄ¿ÉÄÜÐÔ
Among the features that have earned the VLZ3 mixers their stellar reputation are the XDR2 ¡°Extended Dynamic Range¡± mic preamps.ÔÚ¹¦ÄÜ£¬ÒѾӮµÃVLZ3µ÷Òǫ̂ÆäÒ»Á÷µÄ¿Ú±®ÊÇXDR2 ¡°À©Õ¹¶¯Ì¬·¶Î§¡±Ç°Ö÷ŴóÆ÷¡£That¡¯s because serious amounts of time and energy went into their design, and the result is phenomenal.ÕâÊÇÒòΪÑÏÖØµÄ´óÁ¿µÄʱ¼äºÍ¾«Á¦×ß½øËûÃǵÄÉè¼Æ£¬Æä½á¹ûÊǾªÈ˵ġ£You simply won¡¯t find preamps this good on any other mixer in this price range.ÄúÖ»Ð轫ÎÞ·¨ÕÒµ½ÕâÖÖÁ¼ºÃµÄǰÖÃÈÎºÎÆäËûµ÷Òǫ̂Ôڴ˼۸ñ·¶Î§ÄÚ¡£The XDR2 preamps deliver pure, clean studio-grade sound¡ªthe kind of quality you¡¯d expect to find in pricey boutique mic pres.ǰÖõÄXDR2Ìṩ´¿£¬¸É¾»µÄÅï¼¶µÄÉùÒôʲôÑùµÄÖÊÁ¿ÄúÏ£ÍûÕÒµ½ÔÚ°º¹óµÄ¾«Æ·Âó¿Ë·çѹÁ¦¡£They have an incredibly wide frequency range, especially in the low end, and even at extremely high gain settings.ËûÃÇÓÐÁîÈËÄÑÒÔÖÃÐŵįµÂÊ·¶Î§¿í£¬ÌرðÊÇÔڵͶˣ¬ÉõÖÁÔڷdz£¸ßÔöÒæÉèÖá£They offer incredibly low noise, amazing RFI rejection, and with 60dB of available gain per channel, the 802-VLZ3 can handle inputs ranging from a whisper to a scream.ËûÃÇÌṩÄÑÒÔÖÃÐŵĵÍÔëÒô£¬¾ªÈ˵ÄÉ䯵¸ÉÈÅÒÖÖÆ£¬²¢ÓëÏÖÓеÄÁù¡ð·Ö±´Ã¿Í¨µÀÔöÒæµÄ802 - VLZ3¿ÉÒÔ´¦ÀíµÄͶÈ룬´Ó¶úÓïµ½¼â½Ð¡£With the superior sound of the 802-VLZ3¡¯s three XDR2 preamps, rest assured you will always get optimum performance out of your professional ribbon, dynamic, and condenser mics.Read more.ÓÉÓÚ׿ԽµÄÉùÒôµÄ802 - VLZ3µÄÈý¸öXDR2¹¦·Å£¬·ÅÐÄÄãÓÀÔ¶µÃµ½×î¼ÑµÄÐÔÄÜÁËÄãµÄרҵ²Ê´ø£¬³äÂú»îÁ¦£¬ºÍÀäÄýÆ÷Âó¿Ë·ç¡£ÔĶÁ¸ü¶à¡£
Super-Musical EQ for Super Tweaking Latitude³¬¼¶ÒôÀÖÇéÉ̵ij¬¼¶µ÷Õûγ¶È
The 802-VLZ3¡¯s ultra-musical 3-band Active EQ provides precise control over the full frequency spectrum, giving you ultimate sound shaping latitude.802 VLZ3µÄ³¬ÒôÀÖµÄ3Ƶ¶ÎÓÐÔ´¾ùºâÆ÷ÌṩÁ˾«È·µÄ¿ØÖÆ£¬³ä·ÖƵÆ×£¬ÈÃÄúµÄ×îÖÕÒôÉ«µÄγ¶È¡£We invested tremendous resources into optimizing the center frequencies of our EQs, and improved the interaction of the separate EQ bands, so your tracks can be molded and tweaked for just the right result.ÎÒÃÇͶÈëÁ˾޴óµÄ×ÊԴͶÈëµ½ÓÅ»¯µÄÖÐÐÄÆµÂʵľùºâÆ÷£¬ÒÔ¼°¸Ä½øµÄ»¥¶¯µ¥¶ÀÇéÉÌ´ø£¬ÈÃÄúµÄ¸èÇú¿ÉÒÔËÜÔìºÍ¸Ä±äµÄÖ»ÊÇÕýÈ·µÄ½á¹û¡£Low shelving at 80Hz, mid peaking at 2.5kHz and high shelving at 12kHz mean you can quickly and effectively sculpt your tone for the ultimate in punch, fullness, and brilliance¡ªand with up to 15dB boost/cut capability per band, you get loads of room to move¡and experiment.µÍ¸éÖÃÔÚ80Hz £¬ÖÐÆÚ´ïµ½2.5kHzºÍ¸ßµÄ¼Ü×ÓÉÏ12kHzÒâζ×ÅÄã¿ÉÒÔѸËÙºÍÓÐЧµØËÜÔìÄúµÄ»ùµ÷£¬×îÖÕÔÚ³åѹ£¬·áÂú£¬Óë»Ô»ÍºÍ×î¸ßһʮÎå·Ö±´Ìá¸ß/½µµÍÿ¸ö²¨¶ÎµÄÄÜÁ¦£¬Äã¾Í»áµÃµ½¸ººÉ·¿¼äÒÆ¶¯...ºÍʵÑé¡£There¡¯s also a 100Hz low cut/high pass switch for each mic input, so you can keep the muddiness out of your sound¡ªand give lows that extra punch if used in conjunction with the Low EQ.Read more»¹ÓÐÒ»¸ö100HzµÄµÍÇÐ/¸ßͨ¿ª¹ØÎªÃ¿¸öÂó¿Ë·çÊäÈ룬ÕâÑùÄã¾Í¿ÉÒÔËæÊ±ºýÍ¿ÁËÄãµÄÉùÒô£¬²¢¸øÓè¶îÍâµÄµÍµã³åѹÈç¹û½áºÏʹÓõĵÍÇéÉÌ¡£ÔĶÁ¸ü¶à
Fully pro, fully featuredÍêÈ«Ô޳ɣ¬¹¦ÄÜÆëÈ«
A completely pro mini-desk, the 802-VLZ3 delivers a comprehensive set of mission-critical mixing tools.°¢Íêȫ֧³ÖСÊé×À£¬ÔÚ802 - VLZ3ÌṩÁËÒ»Ì×È«ÃæµÄ¹Ø¼üÈÎÎñ»ìÒô¹¤¾ß¡£Five full channel strips let you easily get your hands on your mix, while bright 12-segment stereo meters allow for ultra-accurate metering.Îå³ä·ÖͨµÀ´øÈÃÄãÇáËɵØÕÒµ½ÄãµÄÊÖÔÚÄúµÄ×éºÏ£¬¶øÃ÷ÁÁµÄ12¿ÅÁ¢ÌåÉùÃ×ÔÊÐí³¬×¼È·¼ÆÁ¿¡£The dedicated Stereo Return channel lets you connect external components, such as effects units or mp3 players, so you can incorporate your favorite sounds or prerecorded material into your tracks.רÓÃÁ¢ÌåÉù·µ»ØÍ¨µÀ£¬Äú¿ÉÒÔÁ¬½ÓÍⲿԪ¼þ£¬ÈçÓ°Ï쵥λ»òMP3²¥·ÅÆ÷£¬Òò´Ë£¬Äú¿ÉÒÔ°ÑÄú×îϲ°®µÄÉùÒô£¬»òÊÂÏȲÄÁϵ½ÄúµÄ¹ìµÀ¡£You also get Hi Z inputs on channels 1 and 2 for recording instruments such as electric guitar and basses direct¡ªno external gear required¡ªand phantom power is provided for your studio condenser mics.Äú»¹¿ÉÒÔ£¬ÄúºÃ?ͶÈëÇþµÀ1ºÍµÚ2¿îµÄ¼Ç¼ÊֶΣ¬Èçµç¼ªËûºÍ±´Ë¾Ö±½ÓÈκÎÍⲿÉ豸ÐèÒªºÍ»ÃÏñµçÔ´ÊÇΪÄúÌṩµçÈÝÂó¿Ë·ç¼Òô¡£The PFL solo function lets you easily set your gain to perfect levels, and high pass filters allow you to cut low frequency rumble¡ª100Hz and below¡ªon channels 1 to 3.Âö³åÐγÉÏß¶À×àµÄ¹¦ÄÜ£¬Äú¿ÉÒÔÇáËɵØÉèÖÃÄúµÄÔöÒæ£¬ÒÔÍêÃÀµÄˮƽ£¬¸ßͨÂ˲¨Æ÷¿ÉÈÃÄú½«µÍƵÕð¶¯- 100HzµÄºÍµØÏµÄÇþµÀ£¬ 1ÖÁ3 ¡£The 802-VLZ3 also gives you essential engineering features including separate control room volume and phones knobs.802 VLZ3»¹ÎªÄúÌṩÁ˱ØÒªµÄ¹¤³ÌÌØÐÔ£¬°üÀ¨¶ÀÁ¢µÄ¿ØÖÆÊÒÊýÁ¿ºÍÊÖ»úÐýÅ¥¡£And thanks to our clever engineers, the ¡°mute¡± button actually serves a dual purpose¡ª signals from muted channels are secretly routed to the Alt 3-4 outputs and also into the Control Room section, ideal for creating submixes, previewing channels, or creating a ¡°mix minus¡± for broadcast applications.²¢¸ÐлÎÒÃÇ´ÏÃ÷µÄ¹¤³Ìʦ£¬ ¡°¾²Òô¡±°´Å¥£¬Êµ¼ÊÉÏ·þÎñµÄË«ÖØÄ¿µÄ£¬¾²ÒôÐźÅÃØÃÜÇþµÀ´«Ë͸ø3-4µÄAlt²ú³öÒ²½øÈë¿ØÖÆÊÒ²¿·Ö£¬Îª´´ÔìÀíÏëµÄsubmixes £¬Ô¤ÀÀÇþµÀ£¬»ò½¨Á¢Ò»¸ö¡°»ìºÏ¼õ¡±µÄ¹ã²¥Ó¦Óá£
Ultra-compact, sleek, rugged chassis³¬½ô´Õ£¬¹â»¬£¬¼á¹ÌÄÍÓõĵ×ÅÌ
Now you can have your pro mixer, and fit it in your workspace, too.ÏÖÔÚ£¬Äã¿ÉÒÔÓÐÄãµÄÇ×»ìÆµÆ÷£¬²¢ÊʺÏÔÚÄúµÄ¹¤×÷ÁË¡£The 802-VLZ3 features a tight, low-profile design that fits the most modest¡ªor congested¡ªof areas perfectly.802 VLZ3¹¦Äܽô´Õ£¬µÍÂÖÀªÉè¼Æ£¬×îÊʺÏÖеȻòÓµ¼·µÄÁìÓòÍêÃÀ¡£Like all VLZ3 mixers, the 802-VLZ3 is built like a tank, too.ÏñËùÓÐVLZ3»ìƵÆ÷£¬ÔÚ802 - VLZ3Êǽ¨Á¢Ò»¸ö̹¿ËÒ»ÑùÁË¡£Our legendary solid-steel chassis can take the kind of abuse that would turn our competitors¡¯ flimsy boxes into twisted chunks of debris.ÎÒÃǵĴ«Ææ¹Ì̬¸ÖÌúµ×ÅÌ¿ÉÒÔ²ÉȡʲôÑùµÄŰ´ý£¬ÕâÖÖÇé¿ö½«Ê¹ÎÒÃǵľºÕù¶ÔÊÖ»áÕ¾²»×¡½ÅµÄ·½¿éŤÇú³É¿éË鯬¡£Instead of cheap, unsealed potentiometers, we use co-molded pots, which offer substantial strain and impact relief.²»ÊÇÁ®¼ÛµÄ£¬¹«¿ªµÄµçλÆ÷£¬ÎÒÃÇʹÓù²Í¬Ä£ËÜ»¨Å裬Ìṩ´óÁ¿Ó¦±äºÍÓ°ÏìÁ¦¾È¼Ã¡£By design, our control knobs ¡®ride¡¯ just above the surface of the chassis, so if something falls onto the mixer, the impact is transferred from the knobs to the chassis¡ªnot to the potentiometers or circuit board.°´ÕÕÉè¼Æ£¬ÎÒÃǵĿØÖÆÐýÅ¥'Æï'Ö»ÊǶ³öË®ÃæµÄµ×ÅÌ£¬Òò´Ë£¬Èç¹ûÓÐÆÙ²¼ÉÏ»ìÆµÆ÷£¬ÆäÓ°ÏìÊÇ´ÓÐýÅ¥µÄµ×Å̲»ÊǵçλÆ÷»òµç·°å¡£Finally, we use thick, horizontally mounted fiberglass PC boards to eliminate the potential for damage and brace them with a shock-absorbing support structure.×îºó£¬ÎÒÃÇʹÓúñ£¬ºáÏò°²×°²£Á§PC°å£¬ÒÔÏû³ýDZÔÚµÄË𺦺ÍÖ§³ÅËüÃǵļõÕðÖ§³Å½á¹¹¡£And not only is the 802-VLZ3 tough, but it can be flexibly positioned, thanks to a bottom panel that lets you easily mount an optional mic stand adapter with just a few screws.²»½öÊÇ802 - VLZ3¼èÄѵ쬵«Ëü¿ÉÒÔÁé»îµÄλÖã¬ÓÉÓڵײ¿Ãæ°å£¬Äú¿ÉÒÔÇáËɵØ×°ÈëÒ»¸ö¿ÉÑ¡µÄÂó¿Ë·çÊÊÅäÆ÷µÄÁ¢³¡£¬Ö»Ð輸¸öÂÝË¿¶¤¡£Attach your 802-VLZ3 to a mic stand, and you can adjust its height and angle to suit your unique¡ªor weird¡ªwork style.¸½ÉÏÄúµÄ802 - VLZ3Ò»¸öÂó¿Ë·çµÄÁ¢³¡£¬²¢¿ÉÒÔµ÷ÕûÆä¸ß¶ÈºÍ½Ç¶È£¬ÒÔÂú×ãÄúµÄ¶ÀÌØ»ò¹ÖÒ죬¹¤×÷×÷·ç¡£
The ¡°V¡± stands for VersatilityÔÚ¡° V ¡±Ðδú±íµÄ¶à¹¦ÄÜ
Okay, not really, but the 802-VLZ3 is just that¡ªversatile.ºÃÁË£¬Ã»ÓÐÕæÕý£¬µ«802 - VLZ3¾ÍÊÇÕâÑù£¬¶à²Å¶àÒÕ¡£With its pro features and small footprint, it¡¯s ideal for a variety of applications, including home and project studio recording, sound reinforcement, multimedia projects, field mixing, broadcast use, and post-production work.ƾ½èÆäÖ°ÒµÌØÐԺͽÏСµÄÕ¼µØÃæ»ý£¬ÕâÊÇÊʺ϶àÖÖÓ¦Ó㬰üÀ¨¼ÒÍ¥ºÍÏîĿ¼ÒôÅï¼Òô£¬À©Òô£¬¶àýÌåÏîÄ¿£¬ÍâµØ»ìºÏ£¬ÀûÓù㲥£¬¼°ºóÆÚÖÆ×÷¹¤×÷¡£(Wanna see how you can put it all together? Check out ourhookup guide.) And the includedTracktion 3 Project Bundlemusic production software makes it that much easier to get right to work, and get inspired.£¨ÏëÁ˽âÄã¿ÉÒÔ°ÑËüËùÓÐÔÚÒ»ÆðÂ𣿼ì²éÎÒÃÇÁª²¥Ö¸ÄÏ¡££©ÒÔ¼°°üÀ¨Tracktion 3ÏîÄ¿À¦°óÒôÀÖÖÆ×÷Èí¼þʹµÃÕâ¸üÈÝÒ×»ñµÃ¹¤×÷Ȩ£¬²¢»ñµÃÆô·¢¡£Boot up T3, connect the VLZ3 to your computer¡¯s sound card, and start recording straight away with a host of creativity-inducing loops, samples, and plug-ins.¿ª»úµÄT3 £¬Á¬½ÓVLZ3¼ÆËã»úµÄÒôЧ¿¨£¬²¢¿ªÊ¼Â¼ÖÆÂíÉÏÓë¶«µÀ¹úµÄ´´ÔìÁ¦ÓÕµ¼Ñ»·£¬ÑùÆ·£¬ºÍ²å¼þ¡£
Less Really Is MoreÕæµÄÊÇÉÙ¶à
The 802-VLZ3 gives new meaning to the old adage,less is more.While there are other under-12-channel mixers out in the world these days, none provide the performance or sound quality of the 802-VLZ3.802 VLZ3ÌṩÁËеĺ¬Ò壬¾ÉµÄ¸ñÑÔ£¬ÉÙ¼´ÊǶࡣËäÈ»»¹ÓÐÆäËû¸ù¾Ý- 12 -ͨµÀ»ìƵÆ÷ÔÚÊÀ½çÉÏÕâЩÈÕ×Ó£¬Ã»ÓÐÌṩÁ¼ºÃµÄÐÔÄÜ»òÖÊÁ¿µÄ802 - VLZ3 ¡£Thanks to its ultra-compact, pro design, you get the low input count you want, the extra space you need, and the quality you deserve¡ªall at an unbelievably low price.ÓÉÓÚËüµÄ³¬½ô´Õ£¬ÓÐÀûÓÚÉè¼Æ£¬Äú»ñµÃµÍͶÈëÖ¸ÍûÄúÏëÒªµÄ£¬¶îÍâµÄ¿Õ¼äÂú×ãÄãµÄÐèÒª£¬ºÍÄãµÄÖÊÁ¿Ó¦¸Ã¶¼ÔÚÒ»¸öÁîÈËÄÑÒÔÖÃÐŵĵͼ۸ñ¡£Put simply, the 802-VLZ3 is the go-anywhere, fit-anywhere professional mixer, delivering superior sound quality¡ªand unbeatable value.¼òÑÔÖ®£¬ 802 - VLZ3ÊÇÈ¥£¬Èκεط½£¬ÊʺÏÖУ¬ËæÊ±ËæµØ×¨Òµµ÷Òǫ̂£¬Ìṩ׿ԽµÄÒôÖʺÍÎÞÓëÂױȵļÛÖµ¡£
