Stigmatized Productions Stigmatized Drummer v1.1 KONTAKT
ÒôÔ´
Stigmatized DrummerÊÇÒ»¿î¸ß¶Ë½ðÊôµ¼Ïò¹ÄÀÖ¿â¡£¸ù¾ÝÏ꾡µÄϸ½Ú¼Ç¼£¬ËüÌṩÁËÕæÕýµÄ½»Òס£ÔÚ³¢ÊԺͲâÊÔÿ¸ö¿ÉÄܵÄÉèÖÃÖ®ºó£¬Âó¿Ë·ç·ÅÖú͵÷Õû½á¹ûÊǾªÈ˵ġ£ÕæÕýµÄÓлú£¬ÍêÈ«¿ªÁѺ͡°Ö»ÊÇÔÚÄãÁ³ÉÏ¡±µÄÉùÒô¡£
ÿ¸ö¹Ä×é¶¼¼Ç¼×óÓÒÊÖ£¬×î¶à60¸öËٶȲ㣬ÖÊÁ¿ÎÞÓëÂױȡ£Ê¹ÓÃ×î¸ß²ÉÑù¼¼ÊõµÄÐÐÒµ±ê×¼£¬¹¦ÄÜÇ¿´óµÄKontakt 5ÒýÇæ£¬ÒÔ¼°ÖÊÁ¿Ð§¹û£¬Äú¿ÉÒÔ·ÃÎÊÕû¸ö¹¤×÷ÊÒ¡£¸ß¼¶½Å±¾ÎªÄúÌṩÁËÔÚ¶¥¼¶Éè¼Æ½çÃæÖпØÖÆËùÓÐÄÚÈݵÄÕýÈ·¹¤¾ß¡£
Ñ¡Ôñ1500¶à¸ö¡°¾Û½¹¡±½Ú×àÖеÄһЩ£¬Ê¹ÓÃËùÓÐÕâЩ¹¤¾ß£¬Ð§¹û£¬ÎÒÃǶ¥¼¶¸´ÔÓµÄSplit¼¼Êõ£¬16¹ìµÀÁé»îµÄ»ìÒôÆ÷ºÍ¾ØÕó·ÓÉÆ÷ÍÏ×§ÄãµÄDAW£¬ÕâÊÇ×îÖÕµÄÎäÆ÷¡£ÍêÈ«¿ØÖÆStigmatized DrummerµÄÿ¸öÄÚ²¿×ÜÏߣ¬´´ÔìÍêÃÀµÄDrumtrack´ÓδÈç´Ë¼òµ¥¡£
Ô­ÎÄ
Stigmatized Drummer is a high-end metal oriented Drumming Library. Recorded under an exhaustive detail it provides the real deal. After trying and testing every possible setup, mic placement, and tuning the results are phenomenal. Real organic, full cracking and "just in your face" sound.
Every Drum piece is recorded both left and right hand and with up to 60 velocity layers the quality is unparalleled. Using the industry standard of the Highest Sampling technology the powerful Kontakt 5 engine, and it's build in quality effects you have access to a whole Studio. Advanced Scripting gives you the right tools to control everything in a top notch designed interface.
Selecting some of the 1500+ of "focused" grooves, drag'n'drop in your DAW, using all these tools, effects, our top sophisticated Split technology, the 16 track flexible Mixer and the Matrix Router, the ultimate weapon in terms of full control on every internal buss of Stigmatized Drummer, creating the perfect Drumtrack has never been so easy.
Stigmatized Productions Stigmatized Drummer v1.1 KONTAKT | 4,55 GB
ÏÂÔØµØÖ·£º
Óοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë»Ø¸´
ÆÀÂÛÁÐ±í£¨2£©
ÐÀÉÍ¡ª¡ª
2010-3-23 18:53:56 »Ø¸´
Õâ¸ö²»´í£¬ÐÀÉÍ£¬Ö§³Ö:victory:
2010-3-25 16:03:10 »Ø¸´
